查看: 3016|回复: 9
求帮忙合并一下程序
发表于 2017-10-17 16:18:41 | 显示全部楼层 |阅读模式
3明经币
;;;旋转视图 by ucuc2003
(defun C:XZST (/ ro_ang)
  (setvar "cmdecho" 0)
  (princ "旋转模型空间的视图")
  (if (equal (getvar "TILEMODE") 1)
      ;;记忆参数old_ro_ucs_z_ang (这个值在本LSP文件内必须唯一,不能有重名的)
      (if (= old_ro_ucs_z_ang nil) (setq old_ro_ucs_z_ang (/ pi 2)))
      (princ (strcat "\n指定视口绕 Z 轴的旋转角度<" (angtos old_ro_ucs_z_ang 0 6) ">: "))
      (setq ro_ang (getangle))
      (if ro_ang (setq old_ro_ucs_z_ang ro_ang)(setq ro_ang old_ro_ucs_z_ang))
      (command "_.undo" "_group")
      (command "_.ucs" "_Z" (angtos ro_ang 0 8))
      (command "_.Plan" "")
      (command "_.undo" "_end")
    (princ "\n*请切换到模型空间*")
;;;旋转视图end
;;;恢复视图 by ucuc2003
(defun C:HFST (/ ro_ang)
  (princ "恢复视图")
  (vl-load-com)
(setq  acadobject   (vlax-get-acad-object)
         acaddocument (vla-get-activedocument acadobject))
      (command "_.Plan" "w" "_.ucs" "w")
    (if (= (vla-get-mspace acaddocument) :vlax-false)
      (command "mspace" "_.Plan" "w" "_.ucs" "w")
;;;恢复视图end
要求输入命令后,输入角度或者点击两个点执行第一个旋转视图的程序,什么都不输入直接按空格或者回车执行第二个恢复视图的程序
或者,在输入命令后,点击左键执行第一个程序,点击右键执行第二个程序
发表于 2017-10-17 16:18:42 | 显示全部楼层
  1. ;;;第一个旋转视图 by ucuc2003
  2. (defun XZST (ro_ang / )
  3.   (setvar "cmdecho" 0)
  4.   (princ "旋转模型空间的视图")
  5.   (if (equal (getvar "TILEMODE") 1)
  6.     (progn
  7.       (command "_.undo" "_group")
  8.       (command "_.ucs" "_Z" (angtos ro_ang 0 8))
  9.       (command "_.Plan" "")
  10.       (command "_.undo" "_end")
  11.       )
  12.     (princ "\n*请切换到模型空间*")
  13.     )
  14.   (princ)
  15.   )
  16. ;;;旋转视图end
  17. ;;;第二恢复视图 保存全局变量old_ro_ucs_z_ang
  18. (defun C:ST (/ ro_ang)
  19.   ;;记忆参数old_ro_ucs_z_ang (这个值在本LSP文件内必须唯一,不能有重名的)
  20.   (if (= old_ro_ucs_z_ang nil) (setq old_ro_ucs_z_ang (/ pi 2)))
  21.   (if ro_ang (setq old_ro_ucs_z_ang ro_ang)(setq ro_ang old_ro_ucs_z_ang))
  22.   (princ (strcat "\n指定视口绕 Z 轴的旋转角度<" (angtos old_ro_ucs_z_ang 0 6) ">(默认为恢复视图): "))
  23.   (setq ang (getangle))
  24.   (if ang
  25.     (XZST ang);什么也不输入,回车/空格
  26.     ;else
  27.     (progn
  28.       (setvar "cmdecho" 0)
  29.       (princ "恢复视图")
  30.       (vl-load-com)
  31.       (setq  acadobject   (vlax-get-acad-object)
  32.              acaddocument (vla-get-activedocument acadobject))
  33.       (if (equal (getvar "TILEMODE") 1)
  34.         (progn
  35.           (command "_.undo" "_group")
  36.           (command "_.Plan" "w" "_.ucs" "w")
  37.           (command "_.undo" "_end")
  38.           )
  39.         (if (= (vla-get-mspace acaddocument) :vlax-false)
  40.           (command "mspace" "_.Plan" "w" "_.ucs" "w")
  41.           (command "_.Plan" "w" "_.ucs" "w")
  42.           )
  43.         )
  44.       (princ)
  45.       );progn
  46.     );if
  47.   )
  48. ;;;恢复视图end
 楼主| 发表于 2017-10-17 17:25:15 | 显示全部楼层
没有知道的吗?
 楼主| 发表于 2017-10-17 21:06:58 | 显示全部楼层
谢谢回复,我自己根据你的思路修改了一下,加入了记忆缩放位置的功能,现在更好用了,用着别人的代码,我也不好意思私藏,决定共享出来
 楼主| 发表于 2017-10-17 21:08:26 | 显示全部楼层
  1. (defun C:st (/ ro_ang)
  2. (princ (strcat "\n输入角度或指定视口绕 Z 轴的旋转角度(默认为恢复视图): "))
  4.   (defun xzst (ro_ang / )
  5.   (setvar "cmdecho" 0)
  6.   (if (equal (getvar "TILEMODE") 1)
  7.     (progn
  8.       (command "_.undo" "_group")
  9.       (setq viewcenter (getvar "VIEWCTR")
  10.        viewsize (getvar "VIEWSIZE")
  11.        zoom1 (polar viewcenter (* pi 0.5) viewsize)
  12.        zoom2 (polar viewcenter (* pi 3.5) viewsize)
  13.        zoom1 (trans zoom1 1 0)
  14.        zoom2 (trans zoom2 1 0)
  15.       )
  16.       (command "_.ucs" "_Z" (angtos ro_ang 0 8))
  17.       (command "_.Plan" "")
  18.       (command "zoom" "w" (trans zoom1 0 1) (trans zoom2 0 1))
  19.       (command "_.undo" "_end")
  20.       )
  21.     (princ "\n*请切换到模型空间*")
  22.     )
  23.   (princ)
  24.   )
  25.   (if ang
  26.     (xzst ang)
  27.     (progn
  29.   (if (equal (getvar "TILEMODE") 1)
  30.     (progn
  31.       (command "_.undo" "_group")
  32.       (setq viewcenter (getvar "VIEWCTR")
  33.        viewsize (getvar "VIEWSIZE")
  34.        zoom1 (polar viewcenter (* pi 0.5) viewsize)
  35.        zoom2 (polar viewcenter (* pi 3.5) viewsize)
  36.        zoom1 (trans zoom1 1 0)
  37.        zoom2 (trans zoom2 1 0)
  38.       )
  39.       (command "_.Plan" "w" "_.ucs" "w")
  40.       (command "zoom" "w" (trans zoom1 0 1) (trans zoom2 0 1))
  41.       (command "_.undo" "_end")
  42.     )
  43.     (princ "\n*请切换到模型空间*")
  44.   )
  45.   (princ)
  46. ))
  47. )
发表于 2017-10-18 19:04:46 | 显示全部楼层
挺好用的,谢谢楼主,但我喜欢逆时针为正,上面的正好是反的,有点别扭,不知别的人啥感觉。。。
发表于 2017-10-21 09:07:47 | 显示全部楼层
回帖是一种美德!感谢楼主的无私分享 谢谢
发表于 2018-2-6 14:57:39 | 显示全部楼层
发表于 2018-7-1 23:06:45 | 显示全部楼层
能不能帮我合并下程序。工作中用得比较多。
http://bbs.mjtd.com/forum.php?mo ... hlight=%BA%CF%B2%A2
发表于 2025-2-25 03:41:48 | 显示全部楼层
谢谢大师分享
GMT+8, 2025-5-1 03:16 , Processed in 0.158819 second(s), 22 queries , Gzip On.
