查看: 2991|回复: 5
转别人的 cad展点号
发表于 2017-8-9 15:41:22 | 显示全部楼层 |阅读模式
;;;;数据文件格式【1、(点号,南北,东西,高程) 2、(点号  南北  东西  高程)】
(defun   c:kszd ()   ;;;cad展点号
  (setq        ff   (open (getfiled "请选择要展点的数据文件" "" "txt" 2) "r")
        fhb  nil
        t0   (getvar "cdate")
        cm   (getvar "cmdecho")
        os   (getvar "osmode")
        tcm1 "ZDH"
        tcm2 "PO"
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setvar "pdmode" 35)
  (setvar "pdsize" 0.3)
  (if (= (tblsearch "layer" tcm1) nil)
    (command "layer" "n" tcm1 "")
  (if (= (tblsearch "layer" tcm2) nil)
    (command "layer" "n" tcm2 "")
  (while (setq zb (read-line ff))
      (while (vl-string-search "," zb)
      (setq zb (vl-string-subst " " "," zb))
    (setq zb  (read (strcat "(" zb ")"))
           zb  (list (list (nth 2 zb) (nth 1 zb))  (vl-princ-to-string (car zb)) )                ;提示:注记点号请用该行
           ;;;zb  (list (list (nth 2 zb) (nth 1 zb)) (vl-princ-to-string (last zb)))                ;提示:注记高程  请用该行
          fhb (append fhb (list zb))
  (setq t1 (getvar "cdate"))
  (close ff)
  (setq        zb (vl-sort fhb
                    '(lambda (e1 e2) (< (car (car e1)) (car (car e2))))
        x0 (car (car (car zb)))
        x1 (car (car (last zb)))
        zb (vl-sort fhb
                    '(lambda (e1 e2) (< (cadr (car e1)) (cadr (car e2))))
        y0 (cadr (car (car zb)))
        y1 (cadr (car (last zb)))
  (command "zoom" "w" (list x0 y0) (list x1 y1))
  (setq t2 (getvar "cdate"))
  (foreach zb fhb
    (setq zfc (last zb)
          ;pt  (mapcar '+ (car zb) '(1.5 -1.25));这行改为如下
          pt  (car zb)
    (entmake (list '(0 . "TEXT")
                   '(100 . "AcDbEntity")
                   '(100 . "AcDbText")
                   '(62 . 1)
                   '(40 . 0.3)
                   '(50 . 0.0)
                                        ;(cons 8 tcm1)   (cons 1 zfc)  (cons 10 pt);这行改为如下
                   (cons 8 tcm1)
                   (cons 1 zfc)
                   (cons 10 (mapcar '+ pt '(-0.20 +0.3)))
    (entmake (list '(0 . "POINT")
                   '(100 . "AcDbPoint")
                   '(62 . 2)
                   (cons 8 tcm2)
                   (cons 10 pt)
  (setq        t3  (getvar "cdate")
        dt1 (* 1000000 (- t1 t0))
        dt2 (* 1000000 (- t3 t2))
  (princ (strcat "读入数据共耗时:"
                 (rtos dt1 2 3)
                 "秒   展点共耗时"
                 (rtos dt2 2 3)
                 "秒   展点数:"
                 (itoa (length fhb))
                 "个   每展一点耗:"
                 (rtos (/ dt2 (length fhb)) 2 10)
                 "秒"
  (setvar "cmdecho" cm)
  (setvar "osmode" os)
发表于 2017-8-28 09:46:00 | 显示全部楼层
CAD插件管理程序
发表于 2017-11-7 08:10:46 | 显示全部楼层
谢谢楼主分享!
发表于 2020-7-15 10:57:08 | 显示全部楼层
还看不懂。需要学习啊
发表于 2024-1-7 11:27:08 | 显示全部楼层
这个好像展不出高程来
发表于 2024-2-28 13:54:23 | 显示全部楼层
还看不懂。需要学习啊
GMT+8, 2025-5-23 09:53 , Processed in 0.172589 second(s), 22 queries , Gzip On.
