查看: 1568|回复: 1
选择异常飞时达方格-飞时达方格分割后产生的BUG
发表于 2017-8-4 21:25:23 | 显示全部楼层 |阅读模式
  1. (defun trans2dda (ename / AcadObject AcadDocument mSpace ent_data str_0 obj pts sngSArea)
  2.   (VL-LOAD-COM)
  3.
  4.   (setq AcadObject (vlax-get-acad-object))
  5.   (setq AcadDocument (vla-get-ActiveDocument Acadobject))
  6.   (setq mSpace (vla-get-ModelSpace Acaddocument))
  7.   ;(setq ename (car (entsel "选择要转换的三维多段线:")))
  8.   (setq ent_data (entget ename))
  9.   (setq str_0 (cdr (assoc 0 ent_data)))
  10.   (while (/= str_0 "POLYLINE")
  11.     (setq ename (car (entsel "选择的实体非三维多段线,请重新选择!:")))
  12.     (setq ent_data (entget ename))
  13.     (setq str_0 (cdr (assoc 0 ent_data)))
  14.    )
  15.       (setq obj (vlax-ename->vla-object ename))
  16.       (setq pts (vlax-variant-value (vla-get-coordinates obj)))
  17.
  18.   ;(vlax-ename->vla-object (vla-AddPolyline mSpace pts) )
  19.   ;(setq vlaSTrigon (vlax-ename->vla-object objSTrigon));将转化成VLA 对象
  20.      (setq sngSArea (vlax-curve-getArea  (vla-AddPolyline mSpace pts) ))
  21.   (entdel (entlast))
  22.       ;(princ)
  23.      sngSArea
  24. )
  25. (defun xyp-CurveLength (s1) (vlax-curve-getDistAtParam s1 (vlax-curve-getEndParam s1)))
  26. ;;;;;;;;;;;;;;;;;;;;;;;;;
  27. (defun c:xzfgw ( / ss fgmj ee i sss fgzc)  ;飞时达异常方格删除
  28. (setq fgmj (getreal "\n请输入方格面积5位小数如25.00000:") )
  29.   (setq fgzc (getreal "\n请输入方格周长5位小数如20.00000:") )
  30. ;(setq fgmj (trans2dda (car (entsel "\n请选择样板方格:"))) )
  31.
  32. (setq ss (ssget '( (0 . "polyline")  (8 . "tf-fg1")  ))
  33.           i  0
  34.     )
  35.   (setq sss (ssadd))
  36.     (while (setq ee (ssname ss i))
  37.
  38.       (if (or (> (-(xyp-CurveLength ee) 0.001) fgzc) (> (- (trans2dda ee) 0.001) fgmj)      )
  39.       (progn  (ssadd ee sss)   )
  40.       )
  41.
  42.       (setq i (1+ i))
  43.     )
  44.   (sssetfirst nil sss)
  45.
  46.
  47. )
发表于 2017-12-13 11:59:18 | 显示全部楼层
飞时达用来算量还是好用的,就是D版不好找。
GMT+8, 2025-5-1 07:55 , Processed in 0.157285 second(s), 29 queries , Gzip On.
