查看: 2689|回复: 4
cad 自动连线 <数据文件 格式为:[点号,南北,东西,高程,编码(Xn)] txt文件>
发表于 2017-8-4 10:52:21 | 显示全部楼层 |阅读模式
(defun c:cadzdct ()  ;Cad自动成图
  (setq os (getvar "OSMODE"))
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 0)
  (setvar "pdmode" 35)
  (setvar "pdsize" 0.3)
  (setq        FF(open        (getfiled "请选择要展点成图的数据文件  格式为:[点号,南北,东西,高程,编码(Xn)] txt文件" ""        "txt"        2) "r" ))
  (setq xx nil)
  (while
                (SETQ text0 (READ-LINE FF))
    (setq len (strlen text0))
    (setq XX0 (substr text0 (- len 1) 2))
    (setq n  (vl-string-position (ascii ",") text0))
    (setq n1 (vl-string-position (ascii ",") text0 (1+ n )))
    (setq n2 (vl-string-position (ascii ",") text0 (1+ n1)))
    (setq n3 (vl-string-position (ascii ",") text0 (1+ n2)))
    (setq xh (substr text0 1 n)
                        x  (atof (substr text0 (+ n 2)  (- n1 (+ n 2))))
                        y  (atof (substr text0 (+ n1 2) (- n2 (1+ n1))))
                        pt (list y x)
                        p1 (list (- (car pt) 0.50) (+ (cadr pt) 0.20))
                        p2 (list (+ (car pt) 0.26) (- (cadr pt) 0.40))
                        bg (substr text0 (+ n2 2) (- n3 (1+ n2)))
    (entmake (list '(0 . "TEXT")        ;(setq text1 (list
                                                         '(100 . "AcDbEntity")
                                                         '(100 . "AcDbText")
                                                         '(67 . 0)
                                                         '(62 . 1)
                                                         ;'(8 . "0")
                                                         (cons 10 p1)   ;(cons 10 (mapcar '+ pt ' (- 0.50 + 0.20)))
                                                         '(40 . 0.2)
                                                         (cons 1 xh)
    (entmake (list '(0 . "TEXT")        ;(setq text2 (list
                                                         '(100 . "AcDbText")
                                                         ;'(67 . 0)
                                                         '(62 . 1)
                                                         ; '(8 . "0")
                                                         (cons 10 p2)    ; (cons 10 (mapcar '+ pt ' (+ 0.26 - 0.40)))
                                                         '(40 . 0.4)
                                                         (cons 1 bg)
    (entmake (list '(0 . "POINT")
                                                         '(100 . "AcDbPoint")
                                                         '(62 . 2)
                                                         ;;;(cons 8 tcm2)
                                                         (cons 10 pt)
                ;;;    (entmake text1)
                ;;;    (entmake text2)
    (if        (/= xx0 xx)
                                (command "")
                                (command "pline" pt)
      (command pt)
    (setq xx xx0)
  (command "")
  (CLOSE FF)
  (command "zoom" "e" "")
  (setvar "OSMODE" os)
  (setvar "CMDECHO" 1)
        (prin1)
 楼主| 发表于 2017-8-4 10:54:43 | 显示全部楼层
附样例一份:
G1,60147.2569,62044.552,94.3331,X1
G2,60146.4835,62058.8999,94.5603,X1
G3,60147.0962,62062.1774,94.7816,X1
G4,60148.3312,62065.1687,94.8666,X1
G5,60149.0107,62074.3351,94.9963,X1
G6,60146.3431,62093.4724,95.056,X1
G7,60146.0755,62096.8181,95.0341,X1
G8,60145.2671,62101.2077,94.7211,X1
G9,60144.0095,62105.8998,94.9201,X1
G10,60140.2258,62103.7108,94.933,X1
G11,60135.4384,62099.8754,94.9574,X1
G12,60130.6881,62094.3362,94.9934,X1
G13,60125.5123,62083.4144,94.7114,X1
G14,60125.5907,62076.8919,94.861,X1
G15,60125.5622,62063.3476,94.8452,X1
G16,60119.3761,62056.2432,94.2808,X1
G17,60119.4145,62043.6756,94.3599,X1
G18,60131.0393,62043.9197,94.3141,X1
G19,60138.7982,62044.1048,94.3293,X1
保存为   **.txt    ,文件名随便。
发表于 2017-12-3 10:33:46 | 显示全部楼层
前辈 bg的值如何改成编码 而不是高程标注到图
发表于 2017-12-3 11:02:44 | 显示全部楼层
仔细研究了一下,自己解决了,感谢前辈提供程序
发表于 2018-7-19 07:26:58 | 显示全部楼层
程序编复杂了,用vl-string-translate 直接把","替换成空格,然后构成表,是不是比你简单。
GMT+8, 2025-5-24 20:15 , Processed in 0.196976 second(s), 22 queries , Gzip On.
