查看: 2352|回复: 2
[基础] 获取二维多段线的坐标
发表于 2017-8-1 09:05:25 | 显示全部楼层 |阅读模式
我想获取一个二维多段线(Acad2dpolyline)的坐标,用的是C#+COM组件方式开发
  1. foreach (AcadObject acadObj in mySelectionSet)
  2.                 {
  3.                if (acadObj.ObjectName == "AcDbPolyline")
  4.                     {
  5.                         AcadLWPolyline polyline = (AcadLWPolyline)acadObj;
  6.                         double[] polylineCoords = (double[])polyline.Coordinates;
  7.
  8.                     }
  9.                     else if (acadObj.ObjectName == "AcDb2dPolyline")
  10.                     {
  11.                         //**********怎么获取 二维多段线类型的坐标啊
  12.                     }
  13. }
发表于 2017-8-9 17:13:55 | 显示全部楼层
明经通道AutoCad ActiveX 和VBA  中示例:
Sub Example_Coordinate()
    ' This example creates a polyline in model space and
    ' queries and changes the coordinate in the first index position.
    Dim plineObj As AcadPolyline
    Dim points(0 To 14) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ZoomAll
    ' Find the coordinate in the first index position
    Dim coord As Variant
    coord = plineObj.Coordinate(0)
    MsgBox "The coordinate in the first index position of the polyline is: " & coord(0) & ", " _
        & coord(1) & ", " & coord(2)
    ' Change the coordinate
    coord(0) = coord(0) + 1
    plineObj.Coordinate(0) = coord
    plineObj.Update
    ' Query the new coordinate
    MsgBox "The coordinate in the first index position of the polyline is now: " & coord(0) & ", " _
End Sub
发表于 2017-8-9 17:17:59 | 显示全部楼层
"AcDbPolyline"    点以两个一组存储
"AcDb2dPolyline"   点以三个一组存储
GMT+8, 2025-5-1 20:02 , Processed in 0.175383 second(s), 24 queries , Gzip On.
