- 积分
- 26283
- 明经币
- 个
- 注册时间
- 2011-10-3
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2017-8-18 18:12:01
显示全部楼层
把主要源码给大家,有想学的可以看看,写的比较烂,大家对付看吧
 - // (C) Copyright 2002-2007 by Autodesk, Inc.
- // Permission to use, copy, modify, and distribute this software in
- // object code form for any purpose and without fee is hereby granted,
- // provided that the above copyright notice appears in all copies and
- // that both that copyright notice and the limited warranty and
- // restricted rights notice below appear in all supporting
- // documentation.
- // AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
- // AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
- // MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
- // DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
- // UNINTERRUPTED OR ERROR FREE.
- // Use, duplication, or disclosure by the U.S. Government is subject to
- // restrictions set forth in FAR 52.227-19 (Commercial Computer
- // Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
- // (Rights in Technical Data and Computer Software), as applicable.
- //----- acrxEntryPoint.cpp
- #include "StdAfx.h"
- #include "resource.h"
- #include "CApplication.h"
- #include "CWorkbook.h"
- #include "CWorkbooks.h"
- #include "CWorksheet.h"
- #include "CWorksheets.h"
- #include "CRange.h"
- #include "CBorder.h"
- #include "CBorders.h"
- #include "CFont0.h"
- #include <comdef.h>
- #include <list>
- #include <vector>
- #include "Calculation.h"
- #define szRDS _RXST("YCL")
- using namespace std;
- bool IsExitThreade = false;
- // 边框的类型 Borders[N]
- // xlEdgeLeft 左=1
- // xlEdgeRight 右=2
- // xlEdgeTop 顶=3
- // xlEdgeBottom 底=4
- // xlDiagonalUp 左上右下=5
- // xlDiagonalDown 左下右上=6
- // xlEdgeLeft 外部左边框=7
- // xlEdgeTop 外部上边框=8
- // xlEdgeBottom 外部下边框=9
- // xlEdgeRight 外部右边框=10
- // xlInsideVertical 内部竖线=11
- // xlInsideHorizontal 内部横线=12
- // (其中1:为左 2:右 3:顶 4:底 5:斜\ 6:斜/)
- // #define xlEdgeLeft 1
- // #define xlEdgeTop 2
- // #define xlEdgeBottom 3
- // #define xlEdgeRight 4
- // #define xlDiagonalUp 5
- // #define xlDiagonalDown 6
- // #define xlEdgeLeft 7
- // #define xlEdgeTop 8
- // #define xlEdgeBottom 9
- // #define xlEdgeRight 10
- // #define xlInsideVertical 11
- // #define xlInsideHorizontal 12
- #define Aligndefault 0
- #define Alignleft 1
- #define AlignCenter 2
- #define AlignRight 3
- //定义几个传递表信息所需要的结构体
- struct TableLine
- //线的起始点
- bool IsRowcontinue;
- bool IsColcontinue;
- AcGePoint3d TopStartPoint;
- AcGePoint3d TopEndPoint;
- AcGePoint3d BottomStartPoint;
- AcGePoint3d BottomEndPoint;
- AcGePoint3d TopCurentPoint;
- AcGePoint3d BottomCurentPoint;
- //单元格信息
- struct TextInfo
- //行号
- int RowNum;
- //列号
- int ColNum;
- //行高
- float rowheiht;
- //列宽
- float colwidth;
- //单元格内容
- TCHAR text[512];
- //单元格字高
- float texthight;
- //是否是合并单元格
- bool IsMergeCells;
- //合并单无格的行数
- int UnionRowNums;
- //合并单元格的列数
- int UnionColNums;
- //合并单元格的起始行
- int UnionStartRowNum;
- //合并单元格的起始列
- int UnionStartColNum;
- AcGePoint3d LUPoint;
- AcGePoint3d RUPoint;
- AcGePoint3d LBPoint;
- AcGePoint3d RBPoint;
- bool IsTop;
- bool IsBottom;
- bool IsLeft;
- bool IsRight;
- int HorizontalAlignment;
- AcDbObjectId Objectid;
- AcGePoint3d ptInsert;
- ads_real Scale =1;
- // 将实体添加到图形数据库的模型空间
- AcDbObjectId PostToModelSpace(AcDbEntity* pEnt)
- AcDbBlockTable *pBlockTable;
- acdbHostApplicationServices()->workingDatabase()->getBlockTable(pBlockTable, AcDb::kForRead);
- AcDbBlockTableRecord *pBlockTableRecord;
- acDocManager->lockDocument(curDoc());
- if(pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite) == Acad::eOk)
- AcDbObjectId entId;
- pBlockTableRecord->appendAcDbEntity(entId, pEnt);
- pBlockTable->close();
- pBlockTableRecord->close();
- pEnt->close();
- // 解锁文档
- acDocManager->unlockDocument(curDoc());
- return entId;
- // 解锁文档
- return NULL;
- //其中CurrTextStyle(styleName)是得到当前字体样式,函数如下:
- bool FindTextStyle(TCHAR* textStyle)
- bool ret = false;
- AcDbTextStyleTable *pTextStyleTbl = NULL;
- acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pTextStyleTbl, AcDb::kForRead);
- AcDbTextStyleTableIterator *pIt = NULL;
- pTextStyleTbl->newIterator(pIt);
- for (;!pIt->done();pIt->step())
- AcDbTextStyleTableRecord *pRcd = NULL;
- if (pIt->getRecord(pRcd, AcDb::kForRead) == Acad::eOk)
- TCHAR *szName = NULL;
- pRcd->getName(szName);
- if (_tcscmp(szName,textStyle) == 0)
- pRcd->close();
- ret = true;
- break;
- acutDelString(szName);
- pRcd->close();
- delete pIt;
- pTextStyleTbl->close();
- return ret;
- bool CurrTextStyle(TCHAR *&styleName,TCHAR *&fontName,TCHAR *&bigFontName,AcDbObjectId &Id)
- Id = acdbHostApplicationServices()->workingDatabase()->textstyle();
- AcDbTextStyleTableRecord* pStyleRecord;
- if(acdbOpenObject((AcDbObject *&)pStyleRecord, Id, AcDb::kForRead) == Acad::eOk) {
- const TCHAR *name;
- pStyleRecord->getName(name);
- _tcscpy(styleName, name);
- pStyleRecord->fileName(name);
- _tcscpy(fontName, name);
- pStyleRecord->bigFontFileName(name);
- _tcscpy(bigFontName, name);
- pStyleRecord->close();
- return true;
- return false;
- // else _tcscpy(styleName, _T("STANDARD"));
- //===========================创建文字样式===========================================
- AcDbObjectId createTextStyle(TCHAR* fontName,TCHAR* bigFontName,TCHAR* textStyleName)
- AcGiTextStyle *TextStyle=new AcGiTextStyle
- (fontName,
- bigFontName,
- 0,
- 1,
- 0,
- 0,
- Adesk::kFalse,
- Adesk::kFalse,
- Adesk::kFalse,
- Adesk::kFalse,
- Adesk::kFalse,
- Adesk::kFalse,
- textStyleName); //字体名
- AcDbObjectId textStyleId;
- toAcDbTextStyle(*TextStyle,textStyleId);
- return textStyleId;
- //函数 CreateText,用于创建文字对象
- AcDbObjectId CreateText(const AcGePoint3d& LUInsert,const AcGePoint3d& RBInsert, const TCHAR *text, AcDbObjectId style, double height, double rotation,int HorizontalAlignment)
- AcGePoint3d InsertPoint;
- switch (HorizontalAlignment)
- case Aligndefault:
- InsertPoint =CCalculation::MiddlePoint(LUInsert,RBInsert);
- AcDbText *pText = new AcDbText(InsertPoint,text, style, height,rotation);
- pText->setJustification(pText->kTextAlignmentMiddle);
- pText->setAlignmentPoint(InsertPoint);
- return PostToModelSpace(pText);
- case Alignleft:
- InsertPoint.x = LUInsert.x;
- // InsertPoint.y -= height * 0.5;
- pText->setJustification(pText->kTextAlignmentMiddleLeft);
- case AlignCenter:
- pText->setJustification(pText->kTextAlignmentMiddleCenter);
- case AlignRight:
- InsertPoint.x = RBInsert.x;
- pText->setJustification(pText->kTextAlignmentMiddleRight);
- return NULL;
- //CreateMText 函数,用于添加多行文字
- AcDbObjectId CreateMText(const AcGePoint3d& LUInsert,const AcGePoint3d& RBInsert, const TCHAR *text, AcDbObjectId style, double height, int HorizontalAlignment,const AcGePoint3d& PointInsert,CString Caption,CString BookName,CString SheetName,int start_row,int start_col,int row_num,int col_num)
- AcDbMText *pMText = new AcDbMText();
- double width = RBInsert.x - LUInsert.x - height * 0.4;
- //向对象写入扩展数据
- TCHAR AppName[] ={ _T("ReadeEXCEL")};
- ads_point pt;
- pt[0] = PointInsert.x;
- pt[1] = PointInsert.y;
- pt[2] = PointInsert.z;
- struct resbuf* pRb = acutBuildList(AcDb::kDxfRegAppName, AppName, // 应用程序名称
- AcDb::kDxfXdAsciiString, Caption, // Excel标题
- AcDb::kDxfXdAsciiString, BookName, // 字符串
- AcDb::kDxfXdAsciiString, SheetName, // 字符串
- AcDb::kDxfXdInteger32,start_row,
- AcDb::kDxfXdInteger32,start_col,
- AcDb::kDxfXdInteger32,row_num,
- AcDb::kDxfXdInteger32,col_num,
- AcDb::kDxfXdWorldXCoord,pt,
- RTNONE);
- pMText->setXData(pRb);
- // 设置多行文字的特性
- pMText->setTextStyle(style);
- pMText->setContents(text);
- pMText->setLocation(InsertPoint);
- pMText->setTextHeight(height);
- pMText->setWidth(width);
- pMText->setAttachment(AcDbMText::kMiddleCenter);
- return PostToModelSpace(pMText);
- case Alignleft:
- InsertPoint.x = LUInsert.x + height * 0.2;
- pMText->setAttachment(AcDbMText::kMiddleLeft);
- case AlignCenter:
- case AlignRight:
- InsertPoint.x = RBInsert.x - height * 0.2;
- pMText->setAttachment(AcDbMText::kMiddleRight);
- return NULL;
- // 创建直线
- AcDbObjectId CreateLine(AcGePoint3d ptStart, AcGePoint3d ptEnd)
- AcDbLine *pLine = new AcDbLine(ptStart, ptEnd);
- // 将实体添加到图形数据库
- AcDbObjectId lineId;
- lineId = PostToModelSpace(pLine);
- return lineId;
- //该函数根据两个角点和线宽来创建矩形
- AcDbObjectId CreateRectangle(AcGePoint2d pt1, AcGePoint2d pt2, double width)
- // 提取两个角点的坐标值
- double x1 = pt1.x, x2 = pt2.x;
- double y1 = pt1.y, y2 = pt2.y;
- // 计算矩形的角点
- AcGePoint2d ptLeftBottom(CCalculation::Min(x1, x2), CCalculation::Min(y1, y2));
- AcGePoint2d ptRightBottom(CCalculation::Max(x1, x2), CCalculation::Min(y1, y2));
- AcGePoint2d ptRightTop(CCalculation::Max(x1, x2), CCalculation::Max(y1, y2));
- AcGePoint2d ptLeftTop(CCalculation::Min(x1, x2), CCalculation::Max(y1, y2));
- // 创建对应的多段线
- AcDbPolyline *pPoly = new AcDbPolyline(4);
- pPoly->addVertexAt(0, ptLeftBottom, 0, width, width);
- pPoly->addVertexAt(1, ptRightBottom, 0, width, width);
- pPoly->addVertexAt(2, ptRightTop, 0, width, width);
- pPoly->addVertexAt(3, ptLeftTop, 0, width, width);
- pPoly->setClosed(Adesk::kTrue);
- // 将多段线添加到模型空间
- AcDbObjectId polyId;
- polyId = PostToModelSpace(pPoly);
- return polyId;
- //表格到处到Excel
- int DynamicWriteToExcel()
- ads_name ssname;
- struct resbuf *rb;
- rb = acutBuildList(RTDXF0,_T("TEXT,LWPOLYLINE,LINE"),RTNONE);
- if(acedSSGet(NULL,NULL,NULL,rb,ssname) != RTNORM)
- acutRelRb(rb);
- else
- acutRelRb(rb);
- Adesk::Int32 sslength;
- acedSSLength(ssname, &sslength);
- // acutPrintf(_T("%d\n"),sslength);
- AcDbObjectId objId;
- AcDbObjectIdArray LWpolyLineObjectIdArray ,LineObjectIdArray,TextObjectIdArray;
- for(int i = 0;i < sslength;i++)
- ads_name ent;
- acedSSName(ssname, i, ent);
- acdbGetObjectId(objId, ent);
- AcDbEntity *pEnt;
- //将对象按类型分类
- if(acdbOpenAcDbEntity((AcDbEntity *&)pEnt, objId, AcDb::kForRead) == Acad::eOk)
- if (pEnt->isKindOf(AcDb2dPolyline::desc()))
- LWpolyLineObjectIdArray.append(objId);
- else if(pEnt->isKindOf(AcDbLine::desc()))
- LineObjectIdArray.append(objId);
- TextObjectIdArray.append(objId);
- pEnt->close();
- return 0;
- BOOL CALLBACK EnumChildProc(
- HWND hwnd, // handle to child window
- LPARAM lParam // application-defined value
- TCHAR szText[50];
- CString strBuffer;
- ::GetWindowText(hwnd,szText,50);
- strBuffer.Format(szText);
- if (strBuffer.Find(_T("Book")) != -1)
- ::PostMessage(hwnd,WM_KEYDOWN,VK_TAB,0);
- ::PostMessage(hwnd,WM_KEYUP,VK_TAB,0);
- Sleep(500);
- ::PostMessage(hwnd,WM_KEYDOWN,VK_LEFT,0);
- ::PostMessage(hwnd,WM_KEYUP,VK_LEFT,0);
- // PWINDOWINFO pwindowinfo = NULL;
- // ::GetWindowInfo(hwnd,pwindowinfo);
- // if (pwindowinfo != NULL)
- // if( pwindowinfo->dwWindowStatus == 0)
- // IsContinue = true;
- // else
- // IsContinue = false;
- return TRUE;
- // //需要枚举子窗口,因为状态栏为子窗口,获取状态栏的句柄
- // TCHAR temp1[50];
- // if(hwnd)
- // ::GetClassName(hwnd,temp1,255);
- // if(_tcscmp(temp1,_T("NetUIHWND")))//这个字符串使用spy++或者spyxx获得的状态栏类名
- // int nItemCount;
- // int i;
- // TCHAR chBuffer[50];
- // DWORD dwProcessID;
- // HANDLE hProcess;
- // void * Pointer;
- // SIZE_T nNumberOfBytesRead;
- // nItemCount = ::SendMessage(hwnd, SB_GETPARTS, 0, 0);
- // ::GetWindowThreadProcessId(hwnd, &dwProcessID);//和dwProcessID=pID效果一样
- // hProcess = OpenProcess(PROCESS_VM_OPERATION|PROCESS_VM_READ|PROCESS_VM_WRITE,false,dwProcessID);
- // Pointer = VirtualAllocEx(hProcess,NULL,4096,MEM_RESERVE | MEM_COMMIT,PAGE_READWRITE);
- // for(i= 0 ; i < 4 ; ++i)
- // ::SendMessage(hwnd, SB_GETTEXT, i, (LPARAM)Pointer);
- // ::ReadProcessMemory(hProcess, Pointer,chBuffer, sizeof(chBuffer), &nNumberOfBytesRead);
- // AfxMessageBox(chBuffer);
- // VirtualFreeEx(hProcess,Pointer,0, MEM_RELEASE);
- // CloseHandle(hProcess);
- // return true;
- // return true;
- //关联线程函数
- DWORD WINAPI ThreadProc(
- LPVOID lpParameter // thread data
- // //检查当前字体样式
- // TCHAR StrStyleName[50];
- // TCHAR* CurStyleName = new TCHAR[40];
- // TCHAR* StrFileName = new TCHAR[40];
- // TCHAR* StrBigFontFileName =new TCHAR[40];
- // AcDbObjectId CurSthyleID=NULL,StyleID=NULL;
- // if (CurrTextStyle(CurStyleName,StrFileName,StrBigFontFileName,CurSthyleID))
- // _tcscpy_s(StrStyleName,CurStyleName);
- // _tcscat(StrStyleName,_T("_xls"));
- // if (!FindTextStyle(StrStyleName))
- // if (_tcscmp(StrFileName,_T("")) == 0)
- // StyleID = createTextStyle(_T("arial.ttf"),_T("gbcbig.shx"),StrStyleName);
- // else
- // StyleID = createTextStyle(StrFileName,StrBigFontFileName,StrStyleName);
- // else
- // _tcscpy_s(StrStyleName,_T("Standard_xls"));
- // createTextStyle(_T("gbenor.shx"),_T("gbcbig.shx"),StrStyleName);
- // delete [] StrFileName;
- // delete [] StrBigFontFileName;
- //常用变量定义
- CApplication app;
- CWorkbooks Workbooks;
- CWorkbook Workbook;
- CWorksheets Worksheets;
- CWorksheet Worksheet;
- CRange ranges;
- CRange iCell;
- LPDISPATCH lpDisp;
- COleVariant
- covTrue((short)TRUE),
- covFalse((short)FALSE),
- covOptional((long)DISP_E_PARAMNOTFOUND, VT_ERROR);
- COleVariant vResult;
- TextInfo* TextInfoArr =(TextInfo*)lpParameter;
- //采用MFC方式初始化COM库,程序结束时COM库会自动释放
- // if(!AfxOleInit())
- // MessageBox(NULL,_T("初始化COM支持库失败!\n无法控制Excel!更新线程退出!"),_T("警告"),MB_ICONERROR | MB_OK);
- // delete[] TextInfoArr;
- // ::ExitThread(1);
- // return 0;
- //关联已经运行的Excel实例
- CString str = TextInfoArr[0].text;
- int booknamelen = str.Find(_T(","));
- CString BookName = str.Left(booknamelen);
- CString Caption = str.TrimLeft(BookName);
- Caption = Caption.TrimLeft(_T(","));
- booknamelen = Caption.Find(_T(","));
- CString SheetName=Caption.Left(booknamelen);
- Caption = Caption.TrimLeft(SheetName);
- int start_row = TextInfoArr[0].UnionStartRowNum;
- int start_col = TextInfoArr[0].UnionStartColNum;
- int row_nums = TextInfoArr[0].RowNum;
- int col_nums = TextInfoArr[0].ColNum;
- bool IsContinue = false;
- HWND hExcel = NULL;
- while (TRUE)
- if (IsExitThreade)
- app.ReleaseDispatch ();
- delete[] TextInfoArr;
- AfxOleTerm();
- return 2;;
- //如果当前窗口是Excel窗口,则不读取
- HWND hwnd = FindWindow(TEXT("XLMAIN"),Caption);
- HWND Forehwnd =GetForegroundWindow();
- if (hwnd == NULL)
- AfxOleTerm();
- ::MessageBox(NULL, _T("关联的Excel关闭或有其它Excel打开,关联线程退出!"), _T("警告"), MB_ICONHAND);
- return 2;
- else if(Forehwnd == hwnd)
- Sleep(2000);
- IsContinue = true;
- continue;
- else if(FindWindow(NULL,TEXT("Microsoft Office Excel")) != Forehwnd)
- if(IsContinue)
- EnumChildWindows(hwnd,EnumChildProc,NULL);
- IsContinue = false;
- else
- Sleep(2000);
- continue;
- else
- Sleep(2000);
- continue;
- CLSID clsid;
- CLSIDFromProgID(L"Excel.Application", &clsid);
- IUnknown *pUnk = NULL;
- IDispatch *pRunDisp = NULL;
- for(long i=1;i<=5;i++) //做5次尝试
- HRESULT hr = GetActiveObject(clsid, NULL, (IUnknown**)&pUnk);
- if(SUCCEEDED(hr))
- hr = pUnk->QueryInterface(IID_IDispatch, (void **)&pRunDisp);
- break;
- ::Sleep(10);
- if (!pRunDisp)
- ::MessageBox(NULL, _T("没有发现Excel!更新线程退出!"), _T("警告"), MB_ICONHAND);
- //如果VectorTableinfo不为空则将其清空
- /* delete[] CurStyleName;*/
- AfxOleTerm();
- return 2;
- if (pUnk) pUnk->Release();
- //关联Excel
- app.AttachDispatch (pRunDisp);
- //获取当前激活的workbooks
- lpDisp=app.get_Workbooks();
- if(lpDisp==NULL)
- MessageBox(NULL,_T( "没有发现有效的Book!"), _T("TrueTable"),MB_ICONERROR | MB_OK);
- AfxOleTerm();
- return 2;
- Workbooks.AttachDispatch(lpDisp);
- for (int i=0;i<Workbooks.get_Count();i++)
- bool IsBreak=false;
- lpDisp=Workbooks.get_Item(COleVariant((long)i+1));
- if(lpDisp==NULL)
- continue;
- Workbook.AttachDispatch(lpDisp);
- CString WorkBookName = Workbook.get_Name();
- if(_tcscmp(WorkBookName,BookName) != 0)
- continue;
- lpDisp = Workbook.get_Worksheets();
- if(lpDisp == NULL)
- Workbooks.ReleaseDispatch();
- AfxOleTerm();
- return 2;
- Worksheets.AttachDispatch(lpDisp);
- for (int j=0;j<Worksheets.get_Count();j++)
- lpDisp = Worksheets.get_Item(COleVariant((long)j+1));
- Workbook.ReleaseDispatch();
- AfxOleTerm();
- return 2;
- Worksheet.AttachDispatch(lpDisp);
- if (_tcscmp(Worksheet.get_Name(),SheetName) != 0)
- continue;
- ranges.AttachDispatch(Worksheet.get_Cells());
- //已经获取了想要的sheet,下一步就需要对表格的内容进行检测和修改了
- for (int m=1;m<=TextInfoArr[0].RowNum * TextInfoArr[0].ColNum;m++)
- TextInfo textinfo= TextInfoArr[m];
- iCell.AttachDispatch(ranges.get_Item (COleVariant((long)textinfo.RowNum),COleVariant((long)textinfo.ColNum)).pdispVal );
- CString text = iCell.get_Text();
- iCell.ReleaseDispatch ();
- if (_tcscmp(text,textinfo.text) == 0)
- continue;
- if (_tcscmp(_T(""),text) == 0)
- AcDbObjectId ObjectId = textinfo.Objectid;
- AcDbText* pEnt=NULL;
- // 锁定文档
- Acad::ErrorStatus es = acdbOpenObject((AcDbEntity *&)pEnt,ObjectId,AcDb::kForWrite);
- if (es == Acad::eOk)
- pEnt->erase();
- _tcscpy(TextInfoArr[m].text,text);
- TextInfoArr[m].Objectid = NULL;
- pEnt->close();
- //更新屏幕显示
- // acedUpdateDisplay();
- else if(es == Acad::eWasErased)
- // 解锁文档
- ranges.ReleaseDispatch();
- Worksheet.ReleaseDispatch ();
- Worksheets.ReleaseDispatch ();
- Workbook.ReleaseDispatch ();
- Workbooks.ReleaseDispatch ();
- ::MessageBox(NULL, _T("有手动删除对象,线程退出!"), _T("警告"), MB_ICONHAND);
- AfxOleTerm();
- return 2;
- // 解锁文档
- else
- if (_tcscmp(_T(""),textinfo.text) == 0)
- _tcscpy(textinfo.text,text);
- // AcGePoint3d InsertPoint =CCalculation::MiddlePoint(textinfo.LUPoint,textinfo.RBPoint);
- AcDbObjectId Obj = CreateMText(textinfo.LUPoint,textinfo.RBPoint,textinfo.text,AcDbObjectId::kNull,textinfo.texthight,textinfo.HorizontalAlignment,ptInsert,Caption,BookName,SheetName,start_row,start_col,row_nums,col_nums);
- if (Obj != NULL)
- TextInfoArr[m].Objectid = Obj;
- else
- AcDbMText* pEnt=NULL;
- // 锁定文档
- AcDbObjectId StyleObjectId;
- pEnt->setContents(text);
- // pEnt->adjustAlignment(acdbHostApplicationServices()->workingDatabase());
- // pEnt->recordGraphicsModified(true);
- // StyleObjectId = pEnt->textStyle();
- // if (StyleID != NULL && StyleObjectId != StyleID)
- // pEnt->setTextStyle(StyleID);
- // else if (CurSthyleID != NULL && CurSthyleID != StyleObjectId)
- // pEnt->setTextStyle(StyleObjectId);
- pEnt->close();
- // 解锁文档
- AfxOleTerm();
- return 2;
- // 解锁文档
- IsBreak=true;
- break;
- if(IsBreak)
- break;
- //释放Dispatch
- return 1;
- //动态从Excel读取数据
- int DynamicReadFromExcel()
- //常用变量定义
- CApplication app;
- CWorkbooks books;
- CWorkbook book;
- CWorksheets sheets;
- CWorksheet sheet;
- CRange ranges,range;
- CRange iCell,UnionRange,UnionRanges;
- CRange RangeRow,RangeCol;
- CFont0 Font0;
- LPDISPATCH Workbooks;
- COleVariant
- acdbRegApp(_T("ReadeEXCEL"));
- if(!AfxOleInit())
- MessageBox(NULL,_T("初始化COM支持库失败!\n无法控制Excel!"),_T("TrueTable"),MB_ICONERROR | MB_OK);
- return RTERROR;
- //关联已经运行的Excel实例
- CLSID clsid;
- if(SUCCEEDED(hr))
- break;
- ::Sleep(10);
- if (!pRunDisp)
- ::MessageBox(NULL, _T("没有发现Excel!"), _T("TrueTable"), MB_ICONHAND);
- return RTERROR;
- //关联Excel
- CString Caption = app.get_Caption();
- //获取当前激活的sheet
- lpDisp=app.get_ActiveSheet();
- if(lpDisp==NULL)
- MessageBox(NULL,_T( "没有发现有效的表格!"), _T("TrueTable"),MB_ICONERROR | MB_OK);
- return RTERROR;
- sheet.AttachDispatch(lpDisp);
- //读取sheet名
- lpDisp=sheet.get_Parent();
- if(lpDisp==NULL)
- sheet.ReleaseDispatch();
- return RTERROR;
- book.AttachDispatch(lpDisp);
- CString BookName = book.get_Name();
- CString SheetName=sheet.get_Name();
- //获取选择区
- LPDISPATCH Selectioned = app.get_Selection();
- if (Selectioned == NULL)
- book.ReleaseDispatch();
- return RTERROR;
- vector<vector<TextInfo>>VectorTableinfo;
- //选择的行数、列数:
- long row_num,col_num,StartRow,StartCol;
- ranges.AttachDispatch(Selectioned);
- range.AttachDispatch(ranges.get_Rows());
- row_num=range.get_Count();
- range.AttachDispatch(ranges.get_Columns());
- col_num=range.get_Count();
- // ranges.AttachDispatch(Selectioned);
- StartRow=range.get_Row(); //起始行
- StartCol=range.get_Column(); //起始列
- if(col_num<2 && row_num<2) //未选中区域
- MessageBox(NULL,_T("\n当前表格未选中区域数据!"),_T("TrueTable"),MB_ICONERROR | MB_OK);
- return RTERROR;
- else
- ads_printf(_T("\n表格%s共选中%d行,%d列"),SheetName,row_num,col_num);
- acutPrintf(_T("\nSheet名称:%s\n"),SheetName);
- //得到全部Cells,此时,range是cells的集合
- range.AttachDispatch(sheet.get_Cells());
- int rowhight,colwide;
- CString cstr;
- TableLine tableline;
- //表格信息二维数组
- AcGePoint3d RowStartPoint = ptInsert;
- AcGePoint3d ColStartPoint;
- for(long i=StartRow;i<StartRow+row_num;i++)
- vector<TextInfo>Vectortextinfo;
- AcGePoint3d ptRowCurren = RowStartPoint;
- for(long j=StartCol;j<StartCol+col_num;j++)
- TextInfo textinfo;
- // _tcscpy_s(textinfo.SheetName,SheetName);
- // _tcscpy_s(textinfo.BookName,BookName);
- AcGePoint3d ptColCurren = ColStartPoint;
- //读取单元格文本
- iCell.AttachDispatch(range.get_Item (COleVariant(i),COleVariant(j)).pdispVal );
- RangeRow.AttachDispatch(iCell.get_EntireRow());
- COleVariant hReasult = RangeRow.get_Hidden();
- if (hReasult.boolVal == VARIANT_TRUE)
- break;
- RangeCol.AttachDispatch(iCell.get_EntireColumn());
- hReasult = RangeCol.get_Hidden();
- continue;
- //获取单元格的对齐方式
- hReasult.lVal=0;
- hReasult=iCell.get_HorizontalAlignment();
- if(hReasult.lVal!=0)
- switch (hReasult.lVal)
- case 1: //默认
- textinfo.HorizontalAlignment =Aligndefault;
- break;
- case -4108: //居中
- textinfo.HorizontalAlignment = AlignCenter;
- break;
- case -4131 : //靠左
- textinfo.HorizontalAlignment = Alignleft;
- break;
- case -4152 : //靠右
- textinfo.HorizontalAlignment = AlignRight;
- break;
- //获取单元格所处的行号列号和文字
- textinfo.RowNum = i;
- textinfo.ColNum = j;
- vResult =iCell.get_Text();
- cstr=vResult.bstrVal;
- _tcscpy(textinfo.text,cstr);
- //获取单元格字体
- Font0 = iCell.get_Font();
- COleVariant varFontInfo;
- //字体高度
- varFontInfo = Font0.get_Size();
- textinfo.texthight = abs(varFontInfo.dblVal * Scale * 0.7);
- //单元格行高列宽
- COleVariant Var=iCell.get_RowHeight();
- //行高
- textinfo.rowheiht=Var.dblVal * Scale;
- Var=iCell.get_ColumnWidth();
- //列宽
- textinfo.colwidth = Var.dblVal * 5 * Scale;
- vResult = iCell.get_MergeCells();
- if (vResult.boolVal == -1)
- { //是合并单元格
- textinfo.IsMergeCells = true;
- UnionRanges.AttachDispatch(iCell.get_MergeArea());
- //合并单元格的行数
- UnionRange.AttachDispatch(UnionRanges.get_Rows());
- textinfo.UnionRowNums = UnionRange.get_Count();
- //合并单元格的列数
- UnionRange.AttachDispatch(UnionRanges.get_Columns());
- textinfo.UnionColNums = UnionRange.get_Count();
- //合并单元格的起始行列号
- textinfo.UnionStartRowNum = UnionRanges.get_Row();
- textinfo.UnionStartColNum = UnionRanges.get_Column();
- //合并单元格的行判断
- if (textinfo.UnionRowNums >1)
- if (textinfo.RowNum == textinfo.UnionStartRowNum)
- { //如果当前单元格的行是合并单元格第一行
- textinfo.IsTop = true;
- textinfo.IsBottom = false;
- textinfo.LUPoint = ptRowCurren;
- textinfo.RUPoint = textinfo.LUPoint;
- textinfo.RUPoint.x += textinfo.colwidth;
- else if(textinfo.RowNum == textinfo.UnionStartRowNum + textinfo.UnionRowNums-1)
- { //如果当前单元格的行是合并单元格最后一行
- textinfo.IsBottom = true;
- textinfo.IsTop = false;
- textinfo.LBPoint = ptRowCurren;
- textinfo.LBPoint.y -= textinfo.rowheiht;
- textinfo.RBPoint = textinfo.LBPoint;
- textinfo.RBPoint.x += textinfo.colwidth;
- else
- { //如果当前单元格的行不是合并单元格第一行也不是最后一行
- else
- textinfo.LBPoint = textinfo.LUPoint;
- //合并单元格的列判断
- if (textinfo.UnionColNums>1)
- if (textinfo.ColNum == textinfo.UnionStartColNum)
- { //如果当前单元格的行是合并单元格第一列
- textinfo.IsLeft = true;
- textinfo.IsRight = false;
- else if(textinfo.ColNum == textinfo.UnionStartColNum + textinfo.UnionColNums-1)
- { //如果当前单元格的行是合并单元格最后一列
- textinfo.IsRight = true;
- textinfo.IsLeft = false;
- textinfo.RUPoint = ptRowCurren;
- textinfo.RBPoint = textinfo.RUPoint;
- textinfo.RBPoint.y -= textinfo.rowheiht;
- else
- else
- else
- { //不是合并单元格
- textinfo.IsMergeCells = false;
- textinfo.IsTop= true;
- Vectortextinfo.push_back(textinfo);
- ptRowCurren.x += textinfo.colwidth;
- if (!Vectortextinfo.empty())
- VectorTableinfo.push_back(Vectortextinfo);
- RowStartPoint.y -= Vectortextinfo.back().rowheiht;
- //释放Dispatch
- range.ReleaseDispatch ();
- RangeRow.ReleaseDispatch();
- RangeCol.ReleaseDispatch();
- UnionRanges.ReleaseDispatch();
- UnionRange.ReleaseDispatch();
- sheet.ReleaseDispatch ();
- sheets.ReleaseDispatch ();
- book.ReleaseDispatch ();
- books.ReleaseDispatch ();
- Font0.ReleaseDispatch();
- //行表格线列表
- //行表格线列表
- vector<list<TableLine>>lRow;
- vector<list<TableLine>>lCol;
- AcGePoint3d StartPoint = ptInsert;
- AcGePoint2d ptlu,ptrb;
- ptlu.x = ptInsert.x;
- ptlu.y=ptInsert.y;
- TextInfo * TextInfoArry = new TextInfo[VectorTableinfo.size() * VectorTableinfo[0].size()+1];
- int number =1;
- TextInfoArry[0].RowNum = VectorTableinfo.size() * VectorTableinfo[0].size();
- BookName.Append(_T(","));
- BookName.Append(SheetName);
- BookName.Append(Caption);
- _tcscpy(TextInfoArry[0].text,BookName);
- TextInfoArry[0].RowNum=row_num;
- TextInfoArry[0].ColNum=col_num;
- TextInfoArry[0].UnionStartRowNum =StartRow;
- TextInfoArry[0].UnionStartColNum=StartCol;
- for (int i = 0;i < VectorTableinfo.size();i++)
- vector<TextInfo>Vectortextinfo = VectorTableinfo[i];
- list<TableLine> ListTableRowline;
- bool iscontinue = false;
- TableLine RowTableLine;
- for (int j = 0;j<Vectortextinfo.size();j++)
- TextInfo textinfo = Vectortextinfo[j];
- list<TableLine> ListTableColline;
- TableLine RowTableLine,ColTableLine;
- if (i > 0)
- { //第一行顶线不用判断
- if (textinfo.IsMergeCells)
- { //是合并单元格
- if (textinfo.IsTop)
- if (ListTableRowline.empty() || iscontinue)
- RowTableLine.TopStartPoint=textinfo.LUPoint;
- RowTableLine.TopEndPoint = textinfo.RUPoint;
- ListTableRowline.push_back(RowTableLine);
- iscontinue = false;
- else
- ListTableRowline.back().TopEndPoint=textinfo.RUPoint;
- else
- iscontinue =true;
- else
- { //不是合并单元格
- if (ListTableRowline.empty()|| iscontinue)
- else
- //列向竖线
- if (j>0)
- //是合并单元格
- if (textinfo.IsLeft)
- { //单元格有左线
- if (i == 0)
- //当前单元格未创建左线链表
- ColTableLine.TopStartPoint=textinfo.LUPoint;
- ColTableLine.BottomEndPoint=textinfo.LBPoint;
- ColTableLine.IsColcontinue = true;
- ListTableColline.push_back(ColTableLine);
- lCol.push_back(ListTableColline);
- else
- { //当前单元格已创建左线链表
- if (lCol[j-1].back().IsColcontinue)
- { //上段线连续
- lCol[j-1].back().BottomEndPoint=textinfo.LBPoint;
- else
- { //上段线不连续
- lCol[j-1].push_back(ColTableLine);
- else
- if (i == 0)
- //当前单元格未创建左线链表
- ColTableLine.TopStartPoint=AcGePoint3d(0,0,0);
- ColTableLine.BottomEndPoint=AcGePoint3d(0,0,0);
- ColTableLine.IsColcontinue = false;
- if (j<lCol.size())
- // CreateLine(lCol[i].back().TopStartPoint,lCol[i].back().BottomEndPoint);
- lCol[j-1].back().IsColcontinue = false;
- else
- {//不是合并单元格
- if (i == 0)
- //当前单元格未创建左线链表
- else
- { //当前单元格已创建左线链表
- { //上段线连续
- else
- { //上段线不连续
- //表的右下角点
- if (i+1 == VectorTableinfo.size() && j+1 == Vectortextinfo.size())
- ptrb.x = textinfo.RBPoint.x;
- ptrb.y = textinfo.RBPoint.y;
- //向CAD中写字
- if (_tcscmp(textinfo.text,_T("")) != 0)
- if (textinfo.ColNum == textinfo.UnionStartColNum && textinfo.RowNum == textinfo.UnionStartRowNum)
- AcGePoint3d InsertPt1 =textinfo.LUPoint;
- AcGePoint3d InsertPt2 = VectorTableinfo[i + textinfo.UnionRowNums-1][j + textinfo.UnionColNums-1].RBPoint;
- textinfo.RBPoint = InsertPt2;
- // AcGePoint3d InsertPoint =CCalculation::MiddlePoint(InsertPt1,InsertPt2);
- AcDbObjectId Obj = CreateMText(InsertPt1,InsertPt2,textinfo.text,AcDbObjectId::kNull,textinfo.texthight,textinfo.HorizontalAlignment,ptInsert,Caption,BookName,SheetName,StartRow,StartCol,row_num,col_num);
- if (Obj != NULL)
- textinfo.Objectid = Obj;
- // AcDbText* pEntity;
- // if(acdbOpenObject(pEntity,Obj,AcDb::kForRead) == Acad::eOk)
- // AcGePoint3d position;
- // position = pEntity->position();
- // position = pEntity->alignmentPoint();
- // pEntity->close();
- else
- AcDbObjectId Obj = CreateMText(textinfo.LUPoint,textinfo.RBPoint,textinfo.text,AcDbObjectId::kNull,textinfo.texthight,textinfo.HorizontalAlignment,ptInsert,Caption,BookName,SheetName,StartRow,StartCol,row_num,col_num);
- if (Obj != NULL)
- else
- { //如果单元格为空
- { //单元格为合并单元格
- { //设置第一个合并单元格左上角和右下角的坐标
- TextInfoArry[number]=textinfo;
- number++;
- lRow.push_back(ListTableRowline);
- ListTableRowline.clear();
- //画列线
- for (int i =0;i<lCol.size();i++)
- list<TableLine> ListTableColline = lCol[i];
- list<TableLine>::const_iterator Iterator;
- for (Iterator=ListTableColline.begin();Iterator != ListTableColline.end();Iterator++)
- if (Iterator->TopStartPoint != Iterator->BottomEndPoint)
- CreateLine(Iterator->TopStartPoint,Iterator->BottomEndPoint);
- //画行线
- for (int i =0;i<lRow.size();i++)
- list<TableLine> ListTableRowline = lRow[i];
- for (Iterator=ListTableRowline.begin();Iterator != ListTableRowline.end();Iterator++)
- CreateLine(Iterator->TopStartPoint,Iterator->TopEndPoint);
- CreateRectangle(ptlu,ptrb,0);
- LPVOID lpParameter =(LPVOID)TextInfoArry;
- HANDLE hThreade = ::CreateThread(
- NULL, // pointer to security attributes
- NULL, // initial thread stack size
- ThreadProc, // pointer to thread function
- lpParameter, // argument for new thread
- NULL, // creation flags
- NULL // pointer to receive thread ID
- ::CloseHandle(hThreade);
- if (!VectorTableinfo.empty())
- for (int i=0;i<VectorTableinfo.size();i++)
- VectorTableinfo[i].clear();
- VectorTableinfo.clear();
- return RTNORM;
- //----- ObjectARX EntryPoint
- class CExcelApp : public AcRxArxApp {
- public:
- CExcelApp () : AcRxArxApp () {}
- virtual AcRx::AppRetCode On_kInitAppMsg (void *pkt) {
- // TODO: Load dependencies here
- // You *must* call On_kInitAppMsg here
- AcRx::AppRetCode retCode =AcRxArxApp::On_kInitAppMsg (pkt) ;
- // TODO: Add your initialization code here
- return (retCode) ;
- virtual AcRx::AppRetCode On_kUnloadAppMsg (void *pkt) {
- // TODO: Add your code here
- // You *must* call On_kUnloadAppMsg here
- AcRx::AppRetCode retCode =AcRxArxApp::On_kUnloadAppMsg (pkt) ;
- // TODO: Unload dependencies here
- virtual void RegisterServerComponents () {
- // - YCLExcel.ReadExcel command (do not rename)
- static void YCLExcelReadExcel(void)
- // Add your code for command YCLExcel.ReadExcel here
- IsExitThreade = true;
- acutPrintf(_T("本插件由孤帆制作,仅供试用!用前请保存工作,CAD随时可能崩溃!\n"));
- ads_real ScaleBak=1.0;
- TCHAR str[30]={0};
- TCHAR str1[10] = {0};
- _tcscpy(str, _T("请输入生成表格的比例:<"));
- _stprintf(str1,_T("%f"),Scale);
- _tcscat(str,str1);
- _tcscat(str,_T(">:"));
- if (acedGetReal(str,&ScaleBak) == RTNORM)
- Scale = ScaleBak;
- ads_point pt;
- if(acedGetPoint(NULL,_T("请拾取插入点:\n"),pt)!= RTNORM)
- return;
- ptInsert.x=pt[0];
- ptInsert.y=pt[1];
- ptInsert.z=pt[2];
- IsExitThreade = false;
- DynamicReadFromExcel() ;
- // - YCLExcel.WriteExcel command (do not rename)
- static void YCLExcelWriteExcel(void)
- // Add your code for command YCLExcel.WriteExcel here
- DynamicWriteToExcel();
- // // - YCLExcel.ReAccess command (do not rename)
- // static void YCLExcelReAccess(void)
- // // Add your code for command YCLExcel.ReAccess here
- // IsExitThreade = true;
- // CString Caption,BookName,SheetName;
- // int Start_Row,Start_Col,Row_Nums,Col_Nums;
- // AcGePoint3d pt;
- // struct resbuf *rb; // 结果缓冲区链表
- // ads_name ssname;
- // rb = acutBuildList(RTDXF0, _T("MTEXT"), // 实体类型
- // RTNONE);
- // // 选择复合要求的文字
- // if(acedSSGet(NULL,NULL,NULL,rb,ssname) != RTNORM)
- // acutRelRb(rb);
- // AfxMessageBox(_T("选择对象失败!"));
- // return;
- // long sslength;
- // acedSSLength(ssname, &sslength);
- // acutRelRb(rb);
- // bool IsXData = false;
- // for(int i = 0;i < sslength;i++)
- // ads_name ent;
- // AcDbObjectId objId;
- // acedSSName(ssname, i, ent);
- // acdbGetObjectId(objId, ent);
- // AcDbEntity *pEnt;
- // if(acdbOpenAcDbEntity(pEnt, objId, AcDb::kForRead) == Acad::eOk)
- // struct resbuf *pXData,*pTemp;
- // pXData = pEnt->xData(_T("ReadeEXCEL"));
- // pEnt->close();
- // if (pXData != NULL) // 如果已经包含扩展数据,就不再添加新的扩展数据
- // pTemp = pXData->rbnext;
- // Caption = pTemp->resval.rstring;
- // pTemp = pTemp->rbnext;
- // BookName = pTemp->resval.rstring;
- // SheetName = pTemp->resval.rstring;
- // Start_Row = pTemp->resval.rint;
- // Start_Col = pTemp->resval.rint;
- // Row_Nums = pTemp->resval.rint;
- // Col_Nums = pTemp->resval.rint;
- // pt.x = pTemp->resval.rpoint[X];
- // pt.y = pTemp->resval.rpoint[Y];
- // pt.z = pTemp->resval.rpoint[Z];
- // acutRelRb(pXData);
- // IsXData = true;
- // break;
- // acedSSFree(ssname);
- // if (IsXData)
- // ReReadeExcel(Caption,BookName,SheetName,Start_Row,Start_Col,Row_Nums,Col_Nums,pt);
- // else
- // AfxMessageBox(_T("未找到有效的扩展数据!"));
- IMPLEMENT_ARX_ENTRYPOINT(CExcelApp)
- ACED_ARXCOMMAND_ENTRY_AUTO(CExcelApp, YCLExcel, ReadExcel, ReadExcel, ACRX_CMD_TRANSPARENT, NULL)
- ACED_ARXCOMMAND_ENTRY_AUTO(CExcelApp, YCLExcel, WriteExcel, WriteExcel, ACRX_CMD_TRANSPARENT, NULL)
- //ACED_ARXCOMMAND_ENTRY_AUTO(CExcelApp, YCLExcel, ReAccess, ReAccess, ACRX_CMD_TRANSPARENT, NULL)
