查看: 1407|回复: 0
CAD中打开excel问题
发表于 2016-11-3 20:49:39 | 显示全部楼层 |阅读模式
代码运行的时候出现了
代码如下:
Sub 拱坝平面布置图()
Dim Path As String
Dim Hight, Z_cord, Tc, TaL, TaR As Double '定义拱圈厚度
Dim RcL, RcR, TgL, TgR As Double '定义拱圈半径,角度
Dim LastRow As Long
Dim xlapp As Excel.Application
Dim xlbook As Excel.workbook
Dim xlsheet As Excel.worksheet
On Error GoTo ErrMsg
Set xlapp = CreateObject("excel.application")
   Path = xlapp.GetOpenFilename("Microsoft Office Excel 文件(*.xls),*.xls", , "选择文件")
     If Path = "False" Then
       MsgBox ("Nothing")
       End
     End If
Set xlbook = xlapp.workbooks.Open(Path) '打开的EXCEL路径
Set xlsheet = xlbook.worksheets("参数") '打开EXCEL中的工作表
ErrMsg:
xlbook.Close
xlapp.Quit
Set xlapp = Nothing
End Sub
GMT+8, 2025-5-1 19:38 , Processed in 0.175400 second(s), 29 queries , Gzip On.
