查看: 945|回复: 1
请教VBA 中使用CopyObjects复制CAD出错
发表于 2016-10-14 15:52:43 | 显示全部楼层 |阅读模式
sub test
Dim doc As AcadDocument, docA3 As AcadDocument
Dim  ssetObjA3 As AcadSelectionSet, DestCopy  As AcadSelectionSet
Set docA3 = acadApp.Documents.Open(Sheets(Sn).Cells(4, 3).Value)
With docA3.SelectionSets
While .count > 0
   .Item(0).Delete
Wend
End With
Set ssetObjA3 = docA3.SelectionSets.Add("tukuangA3")
'省略给PtMina3, PtMaxa3赋值
docA3.Application.ZoomExtents
ssetObjA3.Select acSelectionSetWindow, PtMina3, PtMaxa3
Set doc = acadApp.Documents.Open(Sheets(Sn).Cells(5, 3).Value)
Set DestCopy = docA3.CopyObjects(ssetObjA3, doc.ModelSpace) ‘出错,INVALID OBJECT ARRAY’
end sub
如果将ssetObjA3改成AcadEntity数组能够通过,但是DestCopy不匹配,请教该怎么处理?
发表于 2016-10-15 16:10:22 来自手机 | 显示全部楼层
返回值也是数组
GMT+8, 2025-5-26 02:01 , Processed in 0.192738 second(s), 23 queries , Gzip On.
