查看: 1638|回复: 1
[基础] [求助]VB是如何启用英文输入法的?
发表于 2016-9-28 16:47:24 | 显示全部楼层 |阅读模式
如下写法不对,网上也没有搜到VB如何启用英文输入法的(也许有,但不懂VB,所以看不懂)。求高手相助,不胜感激!!!
(defun English_input_method (/ str)
  (setq        str
    "Private Declare Function ActivateKeyboardLayout Lib \"user32\" (ByVal HKL As Long, ByVal flags As Long) As Long
  Private Declare Function LoadKeyboardLayout Lib \"user32\" Alias \"LoadKeyboardLayoutA\" (ByVal pwszKLID As String,ByVal flags As Long) As Long
    Dim hklCurrent As Long
    Const hEnKBDLayout = 67699721 'English (American)
    ActivateKeyboardLayout hEnKBDLayout, 0
    End Sub"
  (or *scr* (setq *scr* (vlax-create-object "ScriptControl")))
  (vlax-put *scr* 'language "VBS")
  (vlax-invoke *scr* 'ExecuteStatement str)
 楼主| 发表于 2016-9-28 16:49:06 | 显示全部楼层
发错板块了,是想发到vb版块的
GMT+8, 2025-5-1 08:17 , Processed in 0.161181 second(s), 24 queries , Gzip On.
