查看: 4854|回复: 13
将所有图层的线宽一键改为0.00mm
发表于 2016-6-9 21:25:21 | 显示全部楼层 |阅读模式
5明经币
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
(defun c:cxk0 ( / first lay name ) (vl-load-com) (setq first t) (while (setq lay (tblnext "layer" first)) (setq first nil) (setq name (cdr (assoc 2 lay))) (vla-put-lineweight (vlax-ename->vla-object (tblobjname "layer" name)) acLnWt000) ) (princ) ) (princ "\n 命令是 CXK0 ")(princ) ;|线宽例子;; acLnWtByLayer acLnWtByBlock acLnWtByLwDefault acLnWt000 acLnWt005 ...
发表于 2016-6-9 21:25:22 | 显示全部楼层
  (vl-load-com)
  (setq first t)
    (setq first nil)
;|线宽例子;;
acLnWtByLayer
acLnWtByBlock
acLnWtByLwDefault
acLnWt000
acLnWt005
acLnWt009
acLnWt013
acLnWt015
acLnWt018
acLnWt020
acLnWt025
acLnWt030
acLnWt035
acLnWt040
acLnWt050
acLnWt053
acLnWt060
acLnWt070
acLnWt080
acLnWt090
acLnWt100
acLnWt106
acLnWt120
acLnWt140
acLnWt158
acLnWt200
acLnWt211
发表于 2016-6-9 22:25:08 | 显示全部楼层
public void SetAllLayerWidth()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                try
                    //打开层表
                    LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId,OpenMode.ForWrite);
                    foreach (ObjectId id in lt)//遍历层表
                        //打开层表记录
                        LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(id, OpenMode.ForWrite);
                        //设置图层线宽为0
                        ltr.LineWeight = 0;
                        ltr.DowngradeOpen();
                    lt.DowngradeOpen();
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    Application.ShowAlertDialog(ex.Message);
 楼主| 发表于 2016-6-10 19:29:15 | 显示全部楼层
            var doc = Application.DocumentManager.MdiActi ...
先谢谢阁下 请问如何使用?
发表于 2016-6-12 19:01:56 | 显示全部楼层
有啥意义?
发表于 2016-6-12 20:31:57 | 显示全部楼层
  1. ;;;成功返回 T
  2. (defun c:tt (/ d r)
  3.   (mapcar
  4.     '(lambda (x / la)
  5.       (setq la (tblobjname "Layer" x))
  6.       (not (vla-put-lineweight (vlax-ename->vla-object la) 0.00))
  7.     )
  8.     (while (setq d (tblnext "Layer" (null d)))
  9.       (setq r (cons (cdr (assoc 2 d)) r))
  10.     )
  11.   )
  12. )
发表于 2016-6-12 22:20:31 | 显示全部楼层
图层线宽全部改到0
发表于 2016-6-13 17:05:54 | 显示全部楼层
maiko 发表于 2016-6-12 22:20
图层线宽全部改到0
一句话的事情居然收两个币。。。
  1. 命令: -LAYER
  2. 当前图层:  Q-DIM.
  3. 输入选项 [?/生成(M)/设置(S)/新建(N)/重命名(R)/开(ON)/关(OFF)/颜色(C)/线型(L)/线宽(LW)/透明度(TR)/材质(MAT)/打印(P)/冻结(F)/解冻(T)/锁定(LO)/解锁(U)/状态(A)/说明(D)/协调(E)]: LW
  4. 输入线宽 (0.0mm - 2.11mm): 0
  5. 输入图层名列表,这些图层使用线宽 0.00mm <Q-DIM.>: *
  6. 输入选项 [?/生成(M)/设置(S)/新建(N)/重命名(R)/开(ON)/关(OFF)/颜色(C)/线型(L)/线宽(LW)/透明度(TR)/材质(MAT)/打印(P)/冻结(F)/解冻(T)/锁定(LO)/解锁(U)
复制代码
  1. (DEFUN C:00 ()
  2. (setvar "cmdecho" 0)
  3. (command "-layer" "LW" "0" "*" "")
  4.   (princ)
  5. )
zhangcan0515 + 1
发表于 2016-6-13 19:01:33 | 显示全部楼层
ㄘ丶转裑ㄧ灬 发表于 2016-6-13 17:05
一句话的事情居然收两个币。。。
收几个b是小事,我好不容易写出来.当然要收辛苦费了.况且我用的是纯vlisp写法,没用到COMMAND,愿者上钩.......
发表于 2016-6-13 19:12:34 | 显示全部楼层
maiko 发表于 2016-6-13 19:01
收几个b是小事,我好不容易写出来.当然要收辛苦费了.况且我用的是纯vlisp写法,没用到COMMAND,愿者上 ...
好吧,我错了。。。
GMT+8, 2025-5-1 15:53 , Processed in 0.177582 second(s), 25 queries , Gzip On.
