楼主: 且听风吟09
[源码] 文字动态对齐线(直线、多段线、曲线化的多段线、spl线)
发表于 2018-8-13 22:58:47 | 显示全部楼层
感谢楼主和楼上修改代码的大神!
发表于 2018-10-14 23:55:39 | 显示全部楼层
能帮忙修改为块或者任意实体齐线吗
发表于 2018-10-26 08:53:05 | 显示全部楼层
尘缘一生 发表于 2018-7-22 06:36
我提的问题,还得我来修改?没有明白我得意思的?
下面发上代码:
能帮忙修改为块或者任意实体齐线吗
发表于 2018-10-26 09:02:22 | 显示全部楼层
很少用到曲线,学习了
发表于 2019-3-9 15:25:32 | 显示全部楼层
过来学习学习,谢谢分享
发表于 2019-5-19 15:04:10 | 显示全部楼层
我也上传个文字复制并齐线的工具,出来不支持多段线、圆弧外都很完美、希望大神没改造一下支持多段线
(vl-load-com)
(defun c:wzqx (/ ent enl pt1 pt2 mid_pt ang)
  (defun emk_t (layer pt1 pt2 text ang n72 n73 h w sty /)
    (entmake (list '(0 . "text")
     '(100 . "AcDbEntity")
     (cons 8 layer)
     '(100 . "AcDbText")
     (cons 10 pt1)
     (cons 1 text)
     (cons 40 h)
     (cons 41 w)
     (cons 7 sty)
     (cons 72 n72)
     (cons 11 pt2)
     (cons 50 ang)
     (cons 73 n73)
  (setq ent (car (entsel "\n选择文字:")))
  (if (= "TEXT" (cdr (assoc 0 (entget ent))))
      (while (setq enl (entsel "\n选择对齐线:"))
(if (= "LINE" (cdr (assoc 0 (entget (car enl)))))
     (setq pt1  (cdr (assoc 10 (entget (car enl))))
    pt2  (cdr (assoc 11 (entget (car enl))))
    mid_pt (vlax-curve-getClosestPointTo
      (vlax-ename->vla-object (car enl))
      (cadr enl)
    ang  (angle pt1 pt2)
     (if (and (> ang (* 0.5 pi)) (<= ang (* pi 1.5)))
       (setq ang (- ang pi))
     (emk_t (cdr (assoc 8 (entget ent)))
     '(0 0 0)
     (polar mid_pt (+ ang (* 0.5 pi)) 100)
     (cdr (assoc 1 (entget ent)))
     ang
     1
     0
     (cdr (assoc 40 (entget ent)))
     (cdr (assoc 41 (entget ent)))
     (cdr (assoc 7 (entget ent)))
发表于 2019-6-20 21:56:15 来自手机 | 显示全部楼层
收藏了,谢谢分享!!!!!
发表于 2019-7-4 20:23:40 | 显示全部楼层
感谢楼主分享!
发表于 2019-7-5 09:28:52 | 显示全部楼层
感谢楼主分享!
GMT+8, 2025-7-6 23:42 , Processed in 0.161994 second(s), 19 queries , Gzip On.
