查看: 1453|回复: 1
求助:如何通过代码来选择标注样式
发表于 2016-5-27 15:13:41 | 显示全部楼层 |阅读模式
本人机械设计人员,想自己做点二次开发自己用,用的vs2012中的vb.net。
请问如何用过代码在工具栏中选择标注样式呢?
目前已用代码生成了1:1,和1:2两个标注样式,用类似选择图层和文字样式的语句会报错。eInvalidinput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.EditorInput
Public Class Class1
    <CommandMethod("mb")>
    Public Sub SCMB()
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim acDimStyleTbl As DimStyleTable
            acDimStyleTbl = acTrans.GetObject(acCurDb.DimStyleTableId, OpenMode.ForRead)
            Dim acDimStyleTblRec As DimStyleTableRecord = Nothing
            If acDimStyleTbl.Has("1:1") = False Then
                acDimStyleTblRec = New DimStyleTableRecord()
                acDimStyleTblRec.Name = "1:1"
                acDimStyleTbl.UpgradeOpen()
                acDimStyleTbl.Add(acDimStyleTblRec)
                acTrans.AddNewlyCreatedDBObject(acDimStyleTblRec, True)
            End If
            acTrans.Commit()
        End Using
            If acDimStyleTbl.Has("1:2") = False Then
                acDimStyleTblRec.Name = "1:2"
            End If
            acTrans.Commit()
        End Using
            acCurDb.Clayer = acDimStyleTbl("1:1")
            acTrans.Commit()
        End Using
    End Sub
End Class
 楼主| 发表于 2016-5-28 19:35:48 | 显示全部楼层
问题以解决,作为一个外行,错误实在太多了。
GMT+8, 2025-5-1 19:42 , Processed in 0.169152 second(s), 24 queries , Gzip On.
