查看: 1580|回复: 2
[命令] 命令中监控大到文件变化后打开文件失败
发表于 2016-4-29 16:49:24 | 显示全部楼层 |阅读模式
想做一个利用FileSystemWatcher监控某个文件夹下的dwg文件变化,然后对变化的文件进行处理的命令。
部分代码如下
[CommandMethod("ShowTheWatcher", CommandFlags.Transparent)]
        public void ShowTheWatcher()
            FileSystemWatcher watcher = new FileSystemWatcher();
            watcher.Path = strPath;
            watcher.Filter = "*.dwg";
            watcher.Changed += new FileSystemEventHandler(OnProcess);
            watcher.Created += new FileSystemEventHandler(OnProcess);
            watcher.Deleted += new FileSystemEventHandler(OnProcess);
            watcher.Renamed += new RenamedEventHandler(OnRenamed);
            watcher.EnableRaisingEvents = true;
private void OnProcess(object source, FileSystemEventArgs e)
            if (e.ChangeType == WatcherChangeTypes.Created)
                OnCreated(source, e);
            else if (e.ChangeType == WatcherChangeTypes.Changed)
                OnChanged(source, e);
            else if (e.ChangeType == WatcherChangeTypes.Deleted)
                OnDeleted(source, e);
//测试时删除某个文件,可以进入到事件处理逻辑中,打开指定的文件时报错。
private void OnDeleted(object source, FileSystemEventArgs e)
            try
                Document dcOpeating = Application.DocumentManager.Open(@"E:\Workpath\@测试图纸集\津2分图.dwg", false);
                Database dbOperating = dcOpeating.Database;
                DocumentLock dlock = dcOpeating.LockDocument();
                Transaction transOperating = dbOperating.TransactionManager.StartTransaction();
                Editor edOperating = dcOpeating.Editor;
            catch (System.Exception exx)
执行到Open行时会出现FATAL ERROR.
求助各位大神了,谢谢
 楼主| 发表于 2016-4-29 16:54:55 | 显示全部楼层
如果在一个命令下,直接用上述语句打开文件没有问题,为什么放置到别的消息处理逻辑中就会出现致命错误呢?
发表于 2024-8-29 05:19:59 | 显示全部楼层
GMT+8, 2025-5-1 02:48 , Processed in 0.169779 second(s), 29 queries , Gzip On.
