查看: 1006|回复: 1
如何把三个文字合成一个块参照???求理解???
发表于 2016-3-26 18:48:19 | 显示全部楼层 |阅读模式
我有三个字体的 坐标  怎么注记出来直接成一个块参照???
下面的代码怎么不对?
   Dim blockRefObj As AcadBlockReference
  Dim blockObj As AcadBlock, ccccc As AcadText, ccc As AcadText, cccc As AcadText
  Set blockObj = ThisDrawing.Blocks.Add(zbd, "sb")
  '------------------------创建块---------------------------------------------------------------------
        zbd(0) = porinta(0) - 7.5: zbd(1) = porinta(1): zbd(2) = porinta(2) '户主编号、坐标不变'''''''''''''''''''''''
      Set ccc = blockObj.AddText(en(0), zbd, 2.5)
      entt.color = 7
        zbd(0) = porinta(0) + 2.1: zbd(1) = porinta(1) + 1.2: zbd(2) = porinta(2)   '面积亩、x坐标不变,y坐标-2'''''''''''''''''''''''''
      Set cccc = blockObj.AddText(en(2), zbd, 2.5)
       entt.color = 7
    zbd(0) = porinta(0) - 8.5: zbd(1) = porinta(1) + 3.5: zbd(2) = porinta(2) '户主权利人、x坐标-3,y坐标+3'''''''''''''''''''''''
      Set ccccc = blockObj.AddText(en(1), zbd, 2.5)
       entt.color = 7
    '  Set entt = blockObj.AddPolyline(zx) ''''''''画直线
      entt.ConstantWidth = 0.2
       entt.color = 7
       '--------------------------------注记文字、和编号---------------------------------------------------
       Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(zbd, "sb", 1#, 1#, 1#, 0)
 楼主| 发表于 2016-3-27 17:12:14 | 显示全部楼层
虽然blocks集合继承Delete方法,用户仍然无法真正删除集合。 企图删除blocks集合会产生错误,因此文件中已经删除了集合的Delete方法
问题已解决
GMT+8, 2025-5-26 06:50 , Processed in 0.161792 second(s), 24 queries , Gzip On.
