查看: 4626|回复: 9
帮忙编写一个dcl对话框面积计算的lisp程序
发表于 2016-2-5 11:58:03 | 显示全部楼层 |阅读模式
5明经币
  1. mjbz:dialog{
  2.         label="面积标注";
  3.         :boxed_radio_row{
  4.             label="转换单位";
  5.             :radio_button{
  6.                 label="平方米";
  7.                 key="mm";
  8.                          }
  9.             :radio_button{
  10.                 label="亩";
  11.                 key="mu";
  12.                 value="1";      //预设选项
  13.                    }
  14.               }
  15.
  16.         :boxed_row{
  17.              label="标注方式";
  18.              :button{
  19.                      label="单一标注";
  20.                      key="dybz";
  21.                    }
  22.              :button{
  23.                      label="批量标注";
  24.                      key="plbz";
  25.                    }
  26.                  }
  27.         spacer_1;                //空白一行
  28.         ok_cancel;
  29.         }
希望最后提供源码,想要学习一下
发表于 2016-2-6 08:09:18 | 显示全部楼层
  1. mjbz:dialog{
  2. label="面积标注";
  4.   label="转换单位";
  5.         key="zhdw";
  6.   :radio_button{label="平方米";key="mm";}
  7.   :radio_button{label="亩";key="mu";value="1";}      //预设选项
  8. }
  9. :boxed_row{
  10.   label="标注方式";
  11.   :button{label="单一标注";key="dybz";}
  12.   :button{label="批量标注";key="plbz";}
  13. }
  14. spacer_1;                //空白一行
  15. ok_cancel;
  16. }
  1. (defun c:mjbz ()
  2. (setvar "CMDECHO" 0)
  3. (setq re 2)
  4. (if (> (setq dcl_id (load_dialog "mjbz.dcl")) 0) (progn
  5.   (while (> re 1)
  6.    (if (new_dialog "mjbz" dcl_id) (progn
  7.     (action_tile "dybz" "(getdata)(done_dialog 2)")
  8.     (action_tile "plbz" "(getdata)(done_dialog 3)")
  9.     (action_tile "accept" "(done_dialog 1)")
  10.     (action_tile "cancel" "(done_dialog 0)")
  11.     (setq re (start_dialog))
  12.    )
  13.     (princ "\n无法显示对话框!")
  14.    )
  15.    (cond
  16.     ((= re 2)
  17.      (if (setq pt (getpoint "\n区域内一点: ")) (progn
  18.       (command "bondory" pt "")
  19.       (command "area" "e" "l" "" "ERASE" "L" "")
  20.       (setq mj (strcat (rtos (/ (getvar "AREA") x) 2 3) " " zhdw))
  21.       (command "TEXT" pt "" "" 0 mj)
  22.      ))
  23.     )
  24.     ((= re 3)
  25.      (while (setq pt (getpoint "\n区域内一点: "))
  26.       (command "bondory" pt "")
  27.       (command "area" "e" "l" "" "ERASE" "L" "")
  28.       (setq mj (strcat (rtos (/ (getvar "AREA") x) 2 3) " " zhdw))
  29.       (command "TEXT" pt "" "" 0 mj)
  30.      )
  31.     )
  32.    )
  33.   )
  34.   (unload_dialog dcl_id)
  35. )
  36.   (princ "\n无法加载对话框!")
  37. )
  38. (princ)
  39. )
  40. (defun getdata ()
  41. (setq x (if (= (get_tile "zhdw") "mm") 1 666666.667));2000000/3
  42. )
 楼主| 发表于 2016-2-6 14:17:40 | 显示全部楼层
ZZXXQQ 发表于 2016-2-6 08:09
命令: mjbz
区域内一点: 未知命令“MJBZ”。按 F1 查看帮助。
; 错误: 参数类型错误: stringp nil
加载之后会出现这个错误是怎么回事
发表于 2016-10-22 23:27:01 | 显示全部楼层
不错的资料, 谢谢分享啊。
发表于 2019-7-9 09:39:07 来自手机 | 显示全部楼层
试试,谢谢分享!!!!
发表于 2019-8-23 12:29:58 | 显示全部楼层
有问题,~~~~~~~~~~~
发表于 2021-2-28 12:11:24 | 显示全部楼层
试试,谢谢分享!!!!
发表于 2022-6-25 14:21:33 | 显示全部楼层
   (setq dcl_file (open (setq tmp-dcl-file-name (vl-filename-mktemp nil nil  ".DCL")) "w"))
                 (foreach x
                     "mjbz:dialog{"
                     "        label=\"面积标注\";"
                     "        :boxed_radio_row{"
                     "            label=\"转换单位\";"
                     "            :radio_button{"
                     "                label=\"平方米\";"
                     "                key=\"mm\";"
                     "            :radio_button{"
                     "                label=\"亩\";"
                     "                key=\"mu\";"
                     "                value=\"1\";      //默认选项"
                     "        :boxed_row{"
                     "             label=\"标注方式\";"
                     "             :button{"
                     "                     label=\"单一标注\";"
                     "                     key=\"dybz\";"
                     "             :button{"
                     "                     label=\"批量标注\";"
                     "                     key=\"plbz\";"
                     "        spacer_1;                //空白一行"
                     "        ok_cancel;"
     ) (write-line x dcl_file) )
     (setq dcl_file (close dcl_file)))
    (defun c:mjbz ()
     (setq re 2)
     (if (> (setq dcl_id (load_dialog tmp-dcl-file-name)) 0) (progn
      (while (> re 1)
       (cond
        ((= re 2)
        ((= re 3)
    (defun getdata ()
发表于 2022-9-5 15:02:38 | 显示全部楼层
不错,学习、学习
发表于 2022-9-5 19:03:53 | 显示全部楼层
源码大佬已经给你很多了,换种新玩法
需要两个文件同时加载,才有效,一种高效便捷的dcl玩法,嘿嘿嘿!!!!!!
摘自附件文件内的对话框部分的代码,如下:
(defun C:NM (/ acttlst dclcidian key2str lst_str)
        (setq dclcidian "mianji-cidian")
        (setq lst_str
                (append(dcl-name "面积标注" )
                        (dcl-vh '("BH" "转换单位"))
                        (dcl-dan '(("平方米" "INGFANG" "5") ("亩" "MU" "5")) "")
                        (dcl-vh "e")
                        (dcl-vh '("BH" "标注方式"))
                        (dcl-an  '(("单一标注" "DANYI" "8" "2")("批量标注" "ILIANG" "8" "2"))"")
                        (dcl-vh "e")
                        (dcl-oc)        ;确认按钮
        (setq key2str(val2str '(1 0 0 0)))
        (setq acttlst '(("DANYI" "3" "(dcl-DANYI)")("ILIANG" "4" "(dcl-PILIANG)")))
        (xj-dcl-k  dclcidian  lst_str  key2str nil acttlst)
GMT+8, 2025-5-1 10:50 , Processed in 0.207352 second(s), 26 queries , Gzip On.
