查看: 8228|回复: 17
[图形系统] 怎样获取CAD绘图区域左上角的屏幕坐标
发表于 2016-1-22 15:02:45 | 显示全部楼层 |阅读模式
通过 PointToScreen 只能获取某点相对于绘图区域 左上角屏幕坐标,要想获取此点在屏幕上的绝对坐标,还必须获取左上角的屏幕坐标。
发表于 2023-12-23 21:00:11 | 显示全部楼层
  1. from pycad.system import *
  2. from pycad.runtime import *
  3. import ctypes
  4. import clr
  5. clr.AddReference("System.Drawing")
  6. clr.AddReference("System.Windows.Forms")
  7. clr.AddReference("PresentationCore")
  8. clr.AddReference("PresentationFramework")
  9. clr.AddReference("WindowsBase")
  10. clr.AddReference("OpenCvSharp")
  11. clr.AddReference("OpenCvSharp.Extensions")
  12. import OpenCvSharp as cv
  13. from OpenCvSharp import Cv2
  14. from OpenCvSharp.Extensions import BitmapConverter
  15. from System.Windows.Forms import Form, Control, NativeWindow
  16. from System.Drawing import Point, Bitmap, Graphics
  17. from System.Windows.Forms import Screen
  18. class POINT(ctypes.Structure):
  19.     _fields_ = [("x", ctypes.c_long), ("y", ctypes.c_long)]
  20. def get_mouse_position():
  21.     pt = POINT()
  22.     ctypes.windll.user32.GetCursorPos(ctypes.byref(pt))
  23.     return pt.x, pt.y
  24. x_offset = 0
  25. y_offset = 0
  26. @Command()
  27. def InitialScreen(doc: Document):
  28.     """屏幕坐标校准"""
  29.     global x_offset, y_offset
  30.     ed = doc.Editor
  31.     res = getpoint()
  32.     if not res.ok:
  33.         return
  34.     cad_pt = res.value  # tpye:Point3d
  35.     windowpt = get_mouse_position()  # 屏幕的绝对坐标
  36.     view_pt = ed.PointToScreen(cad_pt, 0)  # CAD视口的相对坐标
  37.     # 求出坐标偏移值
  38.     x_offset = windowpt[0] - view_pt.X
  39.     y_offset = windowpt[1] - view_pt.Y
  40. def capture_screen(pt1: Point, pt2: Point):
  41.     """截屏"""
  42.     x1, x2, y1, y2 = int(pt1.X), int(pt2.X), int(pt1.Y), int(pt2.Y)
  43.     xmin = min(x1, x2) - 1
  44.     xmax = max(x1, x2) + 1
  45.     ymin = min(y1, y2) - 1
  46.     ymax = max(y1, y2) + 1
  47.     width = xmax - xmin
  48.     height = ymax - ymin
  49.     bitmap = Bitmap(width, height)
  50.     graphics = Graphics.FromImage(bitmap)
  51.     graphics.CopyFromScreen(xmin, ymin, 0, 0, bitmap.Size)
  52.     return bitmap
  53. @Command()
  54. def CaptureScreen(doc: Document):
  55.     global x_offset, y_offset
  56.     ed = doc.Editor
  57.     res = getpoint()
  58.     if not res.ok:
  59.         return
  60.     pt1 = res.value
  61.     res = getcorner(basept=pt1)
  62.     if not res.ok:
  63.         return
  64.     pt2 = res.value
  65.     winpts = []
  66.     for pt in [pt1, pt2]:
  67.         screenpt = ed.PointToScreen(pt, 0)
  68.         windowpt = Point(int(screenpt.X + x_offset), int(screenpt.Y + y_offset))
  69.         winpts.append(windowpt)
  70.     screenshot = capture_screen(winpts[0], winpts[1])
  71.     mat = BitmapConverter.ToMat(screenshot)
  72.     prinf(mat)
  73.     Cv2.ImShow("img", mat)
复制代码
发表于 2019-5-30 13:54:45 | 显示全部楼层
  1. using System;
  2. using System.Runtime.InteropServices;
  3. using System.Windows.Forms;
  4. using Application = Autodesk.AutoCAD.ApplicationServices.Core.Application;
  5. namespace 取得CAD绘图区域屏幕坐标
  6. {
  7. public partial class Form1 : Form
  8. {
  9. public Form1()
  10. {
  11. InitializeComponent();
  12. }
  13. [DllImport("user32.DLL", EntryPoint = "GetTopWindow", SetLastError = true, CharSet = CharSet.Unicode,
  14. ExactSpelling = true, CallingConvention = CallingConvention.StdCall)]
  15. public static extern IntPtr GetTopWindow(IntPtr hWnd);
  16. [DllImport("user32.dll", SetLastError = true, CharSet = CharSet.Auto)]
  17. public static extern IntPtr GetWindow(IntPtr hWnd, UInt32 uCmd);
  18. [DllImport("user32.dll")]
  19. [return: MarshalAs(UnmanagedType.Bool)]
  20. static extern bool GetWindowRect(IntPtr hWnd, ref Rect lpRect);
  21. [StructLayout(LayoutKind.Sequential)]
  22. public struct Rect
  23. {
  24. public int Left; //最左坐标
  25. public int Top; //最上坐标
  26. public int Right; //最右坐标
  27. public int Bottom; //最下坐标
  28. }
  29. private void button1_Click(object sender, EventArgs e)
  30. {
  31. Rect rect = new Rect();
  32. IntPtr intPtr1 = GetTopWindow(Application.DocumentManager.MdiActiveDocument.Window.Handle);
  33. textBox1.Text = intPtr1.ToString();
  34. IntPtr intPtr2 = GetWindow(intPtr1, 2);
  35. GetWindowRect(intPtr2, ref rect);
  36. textBox2.Text = rect.Left.ToString();
  37. textBox3.Text = rect.Top.ToString();
  38. textBox4.Text = (rect.Right - rect.Left).ToString();
  39. textBox5.Text = (rect.Bottom - rect.Top).ToString();
  40. }
  41. }
  42. }
发表于 2023-12-26 09:11:20 | 显示全部楼层
可以参考一下
CAD坐标转为屏幕坐标
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=189169&fromuid=7329732
(出处: 明经CAD社区)
发表于 2016-1-22 21:24:22 | 显示全部楼层
读取系统变量"VIEWSIZE" "SCREENSIZE" "VIEWCTR"计算
 楼主| 发表于 2016-1-22 21:39:25 | 显示全部楼层
此方法不行
发表于 2016-1-23 07:28:10 | 显示全部楼层
同步学习中…………谢谢
发表于 2016-1-23 21:56:32 来自手机 | 显示全部楼层
CPoint pt(0,0);
acedDwgPoint ptOut;
acedCoordFromPixelToWorld(pt,ptOut);
 楼主| 发表于 2016-1-24 22:43:13 | 显示全部楼层
ivde 发表于 2016-1-23 21:56
CPoint pt(0,0);
acedDwgPoint ptOut;
不好意思 ,我在.net 中没有找到此方法呢acedCoordFromPixelToWorld  ,能说详细点不?谢谢!!
 楼主| 发表于 2016-1-24 23:32:43 | 显示全部楼层
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedCoordFromWorldToPixel@@YAHHQBNAAVCPoint@@@Z")]
private static extern bool acedCoordFromWorldToPixel(int viewportNumber, ref Point3d worldPt, out Point pixel);
经查证,acedCoordFromPixelToWorld   与 Editor.PointToScreen 方法得到的结果一样。
发表于 2016-1-25 14:39:34 | 显示全部楼层
  1.             var pt= doc.Window.Location;
  2.             var size = doc.Window.Size;
  3.             var gs = doc.GraphicsManager;
  4.             var gsSize = doc.GraphicsManager.DisplaySize;
  5.             pt.Offset(0, gsSize.Height - size.Height);
复制代码
发表于 2016-1-25 15:28:30 | 显示全部楼层
我也想知道
 楼主| 发表于 2016-1-27 23:34:22 | 显示全部楼层
鱼与熊掌 发表于 2016-1-25 14:39
谢谢,此方法还是不够精确
GMT+8, 2025-5-1 08:11 , Processed in 0.156656 second(s), 26 queries , Gzip On.
