查看: 1001|回复: 1
批量绘图出现问题请教
发表于 2016-1-4 14:17:43 | 显示全部楼层 |阅读模式
原来写的用VBA作对话框调用LSP批量绘断面图在CASS8 FOR ACAD2006上运行的很好,现在将他移植到CASS9.1 FOR ACAD2012 上时,出现自动化错误,该按钮的代码如下,请高人指教!
Private Sub Button1_Click()
  Dim ffdmjs As Integer, CXM As String, F As String, i As Integer, k As Integer, kk As String, cbz As String
  Dim dm() As String
  On Error GoTo a0
    cbz = ""
    If Opt98.Value = True Then cbz = "Y"
     XMMC = RText1: ddmc = RText2
    pmzbx = RText3: gczbx = RText4
      TZG = Text1: TZK = Text2
      zxb = Text3: HXB = Text4
      yy0 = Text5: xx0 = Text7
     dmjg = Val(Text6.Text)
      CXM = CASS9PathB & "/system/断面绘图91.LSP"
        F = wjjmc1
      绘横断面对话框.Hide
     Ccs = ListBox2.Text
    Ccs0 = Val(Mid$(Ccs, 3, 1))
    bchtcswj
    Call bchtqtcswj(Ccs0)
      ffdms(0) = 0: ffdmjs = 1: djf = 0
   For i = 0 To ListBox1.ListCount - 1
         djf = djf + 1
         Application.Documents.Add  '执行这句时出现自动化错误
        tfh0 = ListBox1.List(i)
      If tfh0 = tfh(djf) Then
         ffdmjs = ffdmjs + ffdms(i)
         ffdms(0) = ffdms(djf)
         Call wffwj(ffdmjs)
         Call wdmwj(ffdmjs)
         ThisDrawing.SendCommand "(" & "LOAD" & Chr(34) & CXM & Chr(34) & ")" & vbCr
          ThisDrawing.SendCommand "(setq cbz0 " & Chr(34) & cbz & Chr(34) & ")" & vbCr
         ThisDrawing.SendCommand "_dmt" & vbCr
      End If
        kk = qtfh(tfs, djf)
      Application.ActiveDocument.Close True, F & kk & ".dwg"
   Next i
a0:
End Sub
 楼主| 发表于 2016-1-4 18:15:25 | 显示全部楼层
这一句 Application.Documents.Add 已经解决:
Application.Documents.Add 【加模板图,如 “acadiso.dwt”】
GMT+8, 2025-5-26 07:10 , Processed in 0.170247 second(s), 27 queries , Gzip On.
