帖子
查看: 3215|回复: 11
求mline多线画双线,鼠标指定方向
发表于 2015-12-10 16:14:30 | 显示全部楼层 |阅读模式
3明经币
求多线画双线,最后一步鼠标指定方向
自己是小白,用老师们的源码堆叠了一下。请大师指点一下,谢谢!
(defun c:tt()
(command "_mline" )
(while (> (getvar "CMDACTIVE") 0) (command PAUSE))
(setq c (entlast))
(command "explode" c )
  (setvar "CMDECHO" 0)
   (if (setq ss (ssget "x"'((0 . "LINE"))))
   (command ".PEDIT" "M" ss "" "J" "0.5" "")
(setvar "CMDECHO" 1)
发表于 2015-12-10 16:14:31 | 显示全部楼层
sj800918 发表于 2015-12-11 16:01
或者是用这个调整一下最后指定线的方向也行,虽说麻烦了点,还要预先设一下多线的封口
(defun c:q()
(c ...
  1. (defun c:tt(/ e a b c)
  2.   (while(<(setq d(if(setq a(getreal(strcat"\n双线宽度["(if d(rtos d)"10")"]")))a(if d d 10)))0))
  3.   (command"pline")
  4.   (while(>(getvar "CMDACTIVE")0)(command PAUSE))
  5.   (setq e(entlast))
  6.   (command"offset"d e pause nil)
  7.   (setq a(entlast)c(entget a)e(reverse(entget e))b(assoc 90 e))
  8.   (entmod(append(reverse(cdr(member b e)))
  9.   (list(cons 90(+(cdr b)(cdr(assoc 90 c))))'(70 . 1))
  10.   (vl-remove-if'(lambda(x)(/=(car x)10))(append e c))))
  11.   (entdel a)
  12.   )
参与人数 1明经币 +1 金钱 +10 收起 理由
sj800918 + 1 + 10 哥呀,再帮我看看7楼的回复吧,谢谢!
 楼主| 发表于 2015-12-11 08:54:20 | 显示全部楼层
晕啊,之前那个代码加了个“X”基本实现了自已选直线
但还是期待大神能给出更好的解决方案,比如画多线画完后,手动选择(鼠标)多线的方向。之后打散,再组成多段线,谢谢!
发表于 2015-12-11 15:02:32 | 显示全部楼层
  1. (defun c:tt(/ e a p pt)
  2.   (command "_mline" )
  3.   (while(>(getvar "CMDACTIVE")0)(command PAUSE))
  4.   (setq e(entlast)
  5.         a(entget e))
  6.    (entdel e)
  7.   (repeat(car(assoc 72 a))
  8.     (setq p(assoc 11 a)a(cdr(member p a))
  9.           pt(cons(list(cdr p)(cdr(nth 1 a))(abs(cdr(nth 7 a))))pt)))
  10.   (entmakex(append'((0 . "lwpolyline")(100 . "AcDbEntity")(100 . "AcDbPolyline"))
  11.                   (cons(cons 90(length pt))(mapcar'(lambda(x)(cons 10(car x)))pt))))
  12.   (entmakex(append'((0 . "lwpolyline")(100 . "AcDbEntity")(100 . "AcDbPolyline"))
  13.                   (cons(cons 90(length pt))(mapcar'(lambda(x)(cons 10(polar(car x)(angle(cadr x)'(0 0))(last x))))pt))))
  14.   )
好象理解错楼主的意思了,也许下边一个才是楼主的意思,如果还是不对,实在猜不出来了
  1. (defun c:tt(/ d e a)
  2.   (vl-load-com)
  3.   (command"pline")
  4.   (while(<(setq d(if(setq d(getreal"\n双线宽度[10]"))d 10))0))
  5.   (initget "C L  ")
  6.   (setq a(if(setq a(getkword"\n绘制位置:中间(C)一边(L)[L]"))a"L"))
  7.   (while(>(getvar "CMDACTIVE")0)(command PAUSE))
  8.   (setq e(entlast)d(if(="C"a)(/ d 2)d))
  9.   (if(="C"a)(progn(vla-offset(vlax-ename->vla-object e)d)(vla-offset(vlax-ename->vla-object e)(- d))(entdel e))
  10.   (command"offset"d e pause nil))
  11.   )
 楼主| 发表于 2015-12-11 15:45:45 | 显示全部楼层
第一个运行提示
命令: ; 错误: 参数类型错误: consp nil
第二个大概是这个意思,但能否帮我调整一下
1、双线宽度能否记忆上一次输入的尺寸,直接调用,只有在需要的时候像多线一样输入个S,调整线间距。
2、双线两头需要用直线封口
3、不需要选择线在中间还是边上,直接在一边就可以了
谢谢大神!
 楼主| 发表于 2015-12-11 16:01:30 | 显示全部楼层
(defun c:q()
(command "_mline")
(setq c (entlast))
 楼主| 发表于 2015-12-12 08:53:32 | 显示全部楼层
llsheng_73 发表于 2015-12-10 16:14
您给的代码完美解决了我的问题,但能否再麻烦给我优化一下?
现在运行的顺序是,输入TT,回车,改线的宽度,回车,再指定第一点。。。
能否实现,输入TT,回车,提示:“指定第一点或输入S改变线宽【10(现在的线宽)】”。如不输入S,就直接开始画线。需要改变线宽时再多输一步S,谢谢!
 楼主| 发表于 2015-12-14 12:49:36 | 显示全部楼层
哪位大神路过给调一下呗,谢谢!
发表于 2020-9-21 12:37:55 | 显示全部楼层
顶一下,谢谢分享
发表于 2020-9-21 13:17:19 | 显示全部楼层
感谢楼主分享下载试试!
GMT+8, 2025-6-8 10:09 , Processed in 0.268239 second(s), 30 queries , Gzip On.
