帖子
查看: 6722|回复: 15
[提问] 求一个特殊的“合并多段线”lisp
发表于 2015-11-18 11:48:18 | 显示全部楼层 |阅读模式
效果就如图中所示,多段线1可能是封闭的,也可能是不封闭的。多断线2和多段线1有两个交点。我希望实现的功能是,把多段线1删除掉两个交点之间的部分,然后剩下的部分和多段线1合并(join命令)。
还有就是多段线1和多段线2之间可能有微小的间隙,并没有实际相交,最好能给一个模糊距离的判定,类似于pedit命令中合并多段线的那种。
有大神能解决的,我充值10个明经币悬赏给他,以表示我的感激之情!
发表于 2015-11-21 04:31:40 | 显示全部楼层
;;重合打断消重
发表于 2022-3-31 22:49:59 来自手机 | 显示全部楼层
其实也简单得爆,全部炸开,直线从短到长,排序。从头遍历,找到重合的就用长直线减短直线留下剩下的,短的就一并丢掉。至于重合,一个trans把直线搞成加减法就搞定了
发表于 2022-3-31 10:33:39 | 显示全部楼层
经典经典,院长大人能否贴上码,厉害了
发表于 2015-11-18 12:53:53 | 显示全部楼层
;;-----------------------=={ Outline Objects  }==-----------------------;;
;;  This program enables the user to generate one or more closed        ;;
;;  polylines or regions outlining all objects in a selection.          ;;
;;  Following a valid selection, the program calculates the overall     ;;
;;  rectangular extents of all selected objects and constructs a        ;;
;;  temporary rectangular polyline offset outside of such extents.      ;;
;;  Using a point located within the offset margin between the extents  ;;
;;  of the selection and temporary rectangular frame, the program then  ;;
;;  leverages the standard AutoCAD BOUNDARY command to construct        ;;
;;  polylines and/or regions surrounding all 'islands' within the       ;;
;;  temporary bounding frame.                                           ;;
;;  Author:  Lee Mac, Copyright ?2014  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2014-11-30                                      ;;
;;  First release.                                                      ;;
(defun c:outline ( / *error* sel )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
    (if (setq sel (ssget))
            (LM:startundo (LM:acdoc))
            (LM:outline sel)
;; Outline Objects  -  Lee Mac
;; Attempts to generate a polyline outlining the selected objects.
;; sel - [sel] Selection Set to outline
;; Returns: [sel] A selection set of all objects created
(defun LM:outline ( sel / app are box cmd dis enl ent lst obj rtn tmp )
    (if (setq box (LM:ssboundingbox sel))
            (setq app (vlax-get-acad-object)
                  dis (/ (apply 'distance box) 20.0)
                  lst (mapcar '(lambda ( a o ) (mapcar o a (list dis dis))) box '(- +))
                  are (apply '* (apply 'mapcar (cons '- (reverse lst))))
                  dis (* dis 1.5)
                  ent
                (entmakex
                    (append
                       '(   (000 . "LWPOLYLINE")
                            (100 . "AcDbEntity")
                            (100 . "AcDbPolyline")
                            (090 . 4)
                            (070 . 1)
                        (mapcar '(lambda ( x ) (cons 10 (mapcar '(lambda ( y ) ((eval y) lst)) x)))
                           '(   (caar   cadar)
                                (caadr  cadar)
                                (caadr cadadr)
                                (caar  cadadr)
            (apply 'vlax-invoke
                (vl-list* app 'zoomwindow
                    (mapcar '(lambda ( a o ) (mapcar o a (list dis dis 0.0))) box '(- +))
            (setq cmd (getvar 'cmdecho)
                  enl (entlast)
                  rtn (ssadd)
            (while (setq tmp (entnext enl)) (setq enl tmp))
            (setvar 'cmdecho 0)
            (command
                "_.-boundary" "_a" "_b" "_n" sel ent "" "_i" "_y" "_o" "_p" "" "_non"
                (trans (mapcar '- (car box) (list (/ dis 3.0) (/ dis 3.0))) 0 1) ""
            (while (< 0 (getvar 'cmdactive)) (command ""))
            (entdel ent)
            (while (setq enl (entnext enl))
                (if (and (vlax-property-available-p (setq obj (vlax-ename->vla-object enl)) 'area)
                         (equal (vla-get-area obj) are 1e-4)
                    (entdel enl)
                    (ssadd  enl rtn)
            (vla-zoomprevious app)
            (setvar 'cmdecho cmd)
            rtn
;; Selection Set Bounding Box  -  Lee Mac
;; Returns a list of the lower-left and upper-right WCS coordinates of a
;; rectangular frame bounding all objects in a supplied selection set.
;; s - [sel] Selection set for which to return bounding box
(defun LM:ssboundingbox ( s / a b i m n o )
    (repeat (setq i (sslength s))
        (if
            (and
                (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
                (vlax-method-applicable-p o 'getboundingbox)
                (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))))
            (setq m (cons (vlax-safearray->list a) m)
                  n (cons (vlax-safearray->list b) n)
    (if (and m n)
        (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list m n))
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com) (princ)
;;                             End of File                              ;;
 楼主| 发表于 2015-11-18 14:17:34 | 显示全部楼层
非常感谢,我在程序的末尾自行加了一句(command "erase" sel "")
对应左边的图形来说除了模糊距离设置外几乎是完美的。但是对右边的图形,就达不到理想的效果了。
貌似程序只能针对“外扩”的情况,不能用于“内缩”啊。
发表于 2015-11-18 15:15:19 | 显示全部楼层
你贴出来的程序是生成轮廓线,当然不能内凹了。
如果是封闭多义线,可考虑转换为面域然后求并集、差集等操作再转换为多义线。
发表于 2015-11-18 16:25:18 | 显示全部楼层
对应左边的图形来说除了模糊距离设置 ...
http://bbs.mjtd.com/thread-170194-1-1.html
你看看这个,我在国外找的。
http://autocadtips1.com/2012/02/ ... -a-closed-polyline/
 楼主| 发表于 2015-11-18 20:05:49 | 显示全部楼层
你看看这个,我在国外找的。
好吧,还是有一定的局限性,不知道还有没有其他大神能出手的。
发表于 2015-11-19 08:17:16 | 显示全部楼层
针对LZ例举的两种情况,只需要短的多段线两端点之间剪切,然后合并段线,这样程序就简单多了。
 楼主| 发表于 2015-11-19 09:26:22 | 显示全部楼层
小弟新手,能力有限,只会一些简单的command命令,大神可否给一个完整的代码,感激不尽!
发表于 2015-11-19 21:24:26 | 显示全部楼层
;边界轮廓线
(defun c:bjlkx ()
(setvar "CMDECHO" 0)
(if (and (setq p1 (getpoint "\n第一角点: "))
               (setq p2 (getcorner p1 "\n另一角点: "))) (progn
  (setq s1 (entlast))
  (command "_.RECTANG" p1 p2)
  (setq p3 (polar p1 (angle p1 p2) 5));;;数字5设置跟图形大小有关,如图形较大可设置100或1000
  (command "_.BOUNDARY" p3 "")
  (command "_.ERASE" "C" p1 p1 "")
  (setq ss (ssadd))
  (while (setq s1 (entnext s1)) (ssadd s1 ss))
  (if (> (sslength ss) 0)
   (command "_.ERASE" "W" p1 p2 "R" ss "")
   (princ "\n无法生成边界!")
(setvar "CMDECHO" 1)
(vl-load-com)
(defun c:fzbf(/ oo st_pt end_pt pt1 pt2 pt_tmp l_ss)
(setq oo (entsel "请选择线上第一个点"))
  (setq ss (car oo))
  (setq pt1 (osnap (cadr oo) "near"))
  (setq st_pt (vlax-curve-getStartPoint ss)
        end_pt (vlax-curve-getEndPoint ss)
        pt2 (getpoint "线上第二个点")
      (if (>  (vlax-curve-getParamAtPoint ss pt1) (vlax-curve-getParamAtPoint ss pt2))
      (setq pt_tmp pt2
             pt2 pt1
             pt1 pt_tmp)
          (command "undo" "be")
          (command "_break" ss st_pt pt1)
            (command "_break" ss end_pt pt2)
          (command ".copy" ss "" '(0 0) '(0 0))
          (setq l_ss (entget (entlast)))
          (command "undo" "end")
          (command "undo" "")
          (entmake l_ss)
            (setq ss (entlast))
          (vla-put-Color (vlax-ename->vla-object ss) 1)
                (command "_move"  ss "" pt1 )
 楼主| 发表于 2015-11-20 09:29:11 | 显示全部楼层
香田里浪人 发表于 2015-11-19 21:24
;边界轮廓线
(defun c:bjlkx ()
大哥的程序好像只是拉出轮廓的一部分啊
GMT+8, 2025-7-8 23:57 , Processed in 0.218281 second(s), 28 queries , Gzip On.
