帖子
查看: 1569|回复: 1
【求助】多段线图形生成后实现外轮廓的选择标注
发表于 2015-11-8 19:57:54 | 显示全部楼层 |阅读模式
   本人在工作中学习改进一点VBA代码,画图多段线图形后,能否选择生成的图形,实现多段线的标注类似论坛高手zzyong00的实现效果,
  1. '使用点数组创建轻量多段线
  2. Public Function AddLWPline(ByRef pt() As Double, ByVal width As Double) As AcadLWPolyline
  3.     Dim objPline As AcadLWPolyline
  4.
  5.     '错误处理
  6.     If (UBound(pt) + 1) Mod 2 <> 0 Then
  7.         MsgBox "数组元素个数必须为偶数!"
  8.         Exit Function
  9.     End If
  10.
  11.     Set objPline = ThisDrawing.ModelSpace.AddLightWeightPolyline(pt)
  12.     objPline.ConstantWidth = width
  13.     objPline.Update
  14.     Set AddLWPline = objPline
  15. End Function
  1. '多短线类型1
  2. Public Sub Polyline()
  3.     Dim ptArr1(0 To 9) As Double
  4.     Dim objLWPline  As AcadLWPolyline
  5.     '多段线定点坐标数组
  6.     ptArr1(0) = 0: ptArr1(1) = 0
  7.     ptArr1(2) = 60: ptArr1(3) = 0
  8.     ptArr1(4) = 60: ptArr1(5) = 40
  9.     ptArr1(6) = 0: ptArr1(7) = 60
  10.     ptArr1(8) = 0: ptArr1(9) = 0
  11.     Set objLWPline = AddLWPline(ptArr1, 0)
  12.     '设置多段线的凸出参数,1为半圆,0表示直线
  13.     objLWPline.SetBulge 1, 0.414
  14.     objLWPline.Update
  15. End Sub
如果能实现选择后标注,标注的样式能否一起定义?
 楼主| 发表于 2015-11-8 20:03:00 | 显示全部楼层
图形代码已经附上,实现效果就是图形生成后,选择图形,能够生成图片对应的选择后及出现标注的效果。
GMT+8, 2025-7-13 21:30 , Processed in 0.154187 second(s), 24 queries , Gzip On.
