查看: 1182|回复: 0
[运行时] 动态创建多段线错误
发表于 2015-10-23 21:56:07 | 显示全部楼层 |阅读模式
Public Sub createpolylinebasic()
'动态创建多段线
   On Error Resume Next
   Dim index As Integer '当前输入点的次数
       index = 2
'提示用户输入第一点
       Dim pt1 As Variant
         pt1 = ThisDrawing.Utility.GetPoint(, "输入第一点:")
            If Err Then    '处理EXc键或者ENTER键的事件
              Err.Clear
              Exit Sub
            End If
         Dim ptprevious As Variant  '拾取点过程中,存储上一点和当前点的变量
      Dim ptcurrent As Variant
      ptprevious = pt1
nextpoint:
              ptcurrent = ThisDrawing.Utility.GetPoint(ptprevious, "输入下一点:")
                       Err.Clear
                       Exit Sub
                    End If
        Dim objpline As AcadLWPolyline
          If index = 2 Then
          '创建多段线
                   Dim points(0 To 3) As Double
                     points(0) = ptprevious(0)
                     points(1) = ptprevious(1)
                     points(2) = ptcurrent(0)
                     points(3) = ptcurrent(1)
                     Set objpiine = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
         ElseIf index > 2 Then
                   Dim ptvert(0 To 1) As Double
                   ptvert(0) = ptcurrent(0)
                   ptvert(1) = ptcurrent(1)
                   objpline.AddVertex index - 1, ptvert
        End If
        index = index + 1
        ptprevious = ptcurrent
  GoTo nextpoint
End Sub
以上代码只能创建一段,想连续创建要怎么改
GMT+8, 2025-5-1 20:46 , Processed in 0.193676 second(s), 25 queries , Gzip On.
