查看: 10649|回复: 24
求一个不等比缩放的lISP程序,不用输入比例因子,直接输入X. Y缩放的尺寸就好
发表于 2015-10-20 09:59:06 | 显示全部楼层 |阅读模式
1明经币
发表于 2015-10-22 13:21:10 | 显示全部楼层
;x,y方向不同比例缩放
; ***  XSCALE   [Version 1.0] 6/22/2005  ***
;Copyleft Gu Wenwei
; ****  Author:  Apooollo            ****
; ****  Wuxi Jiangsu China           ****
; This program takes selected objects, defines an anonymous block,
; then inserts the block at the original location, Scale by X,Y
(defun C:XSCALE(/ bp ss xscal yscal entL)
  (defun errexit (s)
    (princ "\nError:  ")
    (princ s)
    (restore)
  (defun restore ()
    (setvar "CMDECHO" (car oldvar))
    (setq *error* olderr)
(defun MAKEUNBLOCK (ss ip / tmp errexit mbx BLAYER)
  (setq T (not nil))
  (setq olderr  *error*
        *error* errexit
  (setq oldvar
    (list
      (getvar "CMDECHO")
  (setvar "CMDECHO" 0)
  (terpri)
  (if BLAYER
    (command "._LAYER"
      (if (tblsearch "LAYER" BLAYER) "_S" "_M")
      BLAYER
  (if (and ip ss)
      (entmake (list
        (cons '0 "BLOCK")
        (cons '2 "*U")
        (cons '70 1)
        (cons '10 ip)
      (setq cnt (sslength ss))
      (while (>= (setq cnt (1- cnt)) 0)
        (setq tmp (ssname ss cnt))
        (entmake (setq el (entget tmp)))
        (if (> (cdr (assoc 66 el)) 0)
          (while
            (/= "SEQEND"
              (cdr
                (assoc 0
                  (entmake (setq el (entget (entnext (cdr (assoc -1 el))))))
        (entdel tmp)
      (setq tmp (entmake (list (cons '0 "ENDBLK"))))
      (entmake (list
        (cons '0 "INSERT")
        (cons '2 tmp)
        (cons '10 ip)
  (restore)
  (setq ss (ssget))    ;;; 选择缩放实体
  (if ss
      (setvar "cmdecho" 0)
      (setq bp (getpoint "缩放基准点 (<0,0,0>): "))
      (if (not bp) (setq bp (list 0 0 0)))
      (setq xscal (getreal "X向比例因子 <1>: "))
      (if (not xscal) (setq xscal 1))
      (setq yscal (getreal "Y向比例因子 <1>: "))
      (if (not yscal) (setq yscal 1))
      (MAKEUNBLOCK ss bp)
      (setq entL (entget (entLast))
          entL (subst (cons 41 xscal) (assoc 41 entL) entL)
          entL (subst (cons 42 yscal) (assoc 42 entL) entL)
      (entmod entL)
      (command "_explode" "l" "")
  (princ "X,Y不同比例缩放, 命令:XSCALE")
 楼主| 发表于 2015-10-22 21:31:32 | 显示全部楼层
zjy2999 发表于 2015-10-22 13:21
;x,y方向不同比例缩放
这程序试用了下,还是要输入X,Y比例因子才行。我想找的是输入命令,指定基点,再输入X,Y的尺寸就可以的程序。记得原来论坛好像有的,当时也下过就是丢失了找不到了。
发表于 2016-3-12 02:37:38 | 显示全部楼层
看看是不是这样的
 楼主| 发表于 2016-3-21 21:17:45 | 显示全部楼层
laorenhao999 发表于 2016-3-12 02:37
看看是不是这样的
就是这个终于找到了,以前有过的丢了,很久没来了竟然一来就有收获
发表于 2016-7-2 16:32:41 | 显示全部楼层
是很强大,但感觉不如动态块好用吧。可能用到的范围不一样!
发表于 2017-11-3 08:40:33 | 显示全部楼层
回帖是一种美德!感谢楼主的无私分享 谢谢
发表于 2017-12-13 18:15:38 | 显示全部楼层
感谢楼主的无私分享 正需要 谢谢!
 楼主| 发表于 2017-12-15 16:39:35 | 显示全部楼层
(defun C:xysc (/ bp ss xscal yscal entL)
  (setvar "qaflags" 0)
  (defun errexit (s)
    (princ "\nError:  ")
    (princ s)
    (restore)
  (defun restore ()
          *error* errexit
    (setq oldvar (list (getvar "CMDECHO")))
    (terpri)
    (if        BLAYER
      (command "._LAYER"
                 "_S"
                 "_M"
               BLAYER
    (if        (and
          ip
          ss
        (entmake (list (cons '0 "BLOCK")
                       (cons '2 "*U")
                       (cons '70 1)
                       (cons '10 ip)
                   0
            (while (/= "SEQEND"
                       (cdr (assoc 0
                                   (entmake (setq el
                                                   (entget
                                                     (entnext
                                                       (cdr
                                                         (assoc -1 el)
          (entdel tmp)
        (entmake
          (list (cons '0 "INSERT") (cons '2 tmp) (cons '10 ip))
    (restore)
  (setq ss (cadr (ssgetfirst)))
  (while (= ss nil)
    (setq ss (ssget))                        ; 选择缩放实体
  (setq        i 0
        dwcorn nil
        upcorn nil
  (repeat (sslength ss)
    (setq ent (ssname ss i))
    (setq obj (vlax-ename->vla-object ent))
    (vla-GetBoundingBox obj 'pta 'ptb)
    (setq dwcorn (cons (vlax-safearray->list pta) dwcorn))
    (setq upcorn (cons (vlax-safearray->list ptb) upcorn))
    (setq i (1+ i))
  (setq        ptlist (append
                 dwcorn
                 upcorn
  (setq        x (mapcar
            'car
            ptlist
  (setq        y (mapcar
            'cadr
            ptlist
  (setq        x1 (apply
             'min
  (setq        y1 (apply
             'min
             y
  (setq        x2 (apply
             'max
  (setq        y2 (apply
             'max
             y
  (setq xx (- (car (list x2 y2)) (car (list x1 y1))))
  (setq yy (- (cadr (list x2 y2)) (cadr (list x1 y1))))
  (if ss
      (setq bp (polar (list x1 y1)
                      (angle (list x1 y1) (list x2 y2))
                      (/ (distance (list x1 y1) (list x2 y2)) 2)
      (setq xx1 (getdist "\n指定新的X方向尺寸:"))
      (setq yy1 (getdist "\n指定新的Y方向尺寸:"))
      (setq xscal (/ xx1 xx))
      (setq yscal (/ yy1 yy))
      (MAKEUNBLOCK ss bp)
            entL (subst
                   (cons 41 xscal)
                   (assoc 41 entL)
                   entL
            entL (subst
                   (cons 42 yscal)
                   (assoc 42 entL)
                   entL
      (entmod entL)
      (command "_explode" "l")
 楼主| 发表于 2017-12-15 16:40:19 | 显示全部楼层
htlaser 发表于 2017-12-13 18:15
感谢楼主的无私分享 正需要 谢谢!
不知道发的对不对,自己复制保存下
GMT+8, 2025-5-1 03:19 , Processed in 0.179569 second(s), 26 queries , Gzip On.
