查看: 1320|回复: 0
73哥函数,文字反转
发表于 2015-10-16 17:07:55 | 显示全部楼层 |阅读模式
  1. (defun c:wzfz ( / ent lst i ii zhc ent1 lsta)
  2. (setq lsta (ssget '((0 . "text"))))
  3.   (setq ii 0)
  4.
  5. (defun str->chrs(str / a  c i zhc)
  6. (setq a(vl-string->list str))
  7. (while a
  8.   (if(<(car a)129)(setq c(cons(chr(car a))c)a(cdr a))
  9.     (setq c(cons(strcat(chr(car a))(chr(cadr a)))c)a(cddr a))))
  10. (reverse c)
  11. (setq i 0)
  12.   (setq zhc "" )
  13. (repeat (length (reverse (reverse c)))
  14. (setq zhc (strcat zhc (nth i (reverse (reverse c))) ))
  15.   (setq i (1+ i))
  16.   )
  17.   zhc
  18.   )
  19.
  20. (repeat (sslength lsta)
  21.   (setq ent (ssname lsta ii))
  22.   (setq ent1 (cdr(assoc 1(entget ent))))
  23. (setq lst (str->chrs ent1))
  24.   (entmod (subst (cons 1 lst) (assoc 1(entget ent)) (entget ent) ))
  25. (setq ii (1+ ii))
  26. )
  27. )
GMT+8, 2025-5-1 07:43 , Processed in 0.159717 second(s), 28 queries , Gzip On.
