楼主: 冒个烟圈
[已解答] “反向隐藏”达不到‘反向’的效果
 楼主| 发表于 2015-10-13 19:20:07 | 显示全部楼层
ZZXXQQ 发表于 2015-10-13 08:47
谢谢。。终于可以了。。
发表于 2015-10-13 21:01:59 | 显示全部楼层
(defun c:ycqt ()
(setvar "cmdecho" 0)
(setq ss (ssget))
(command "SELECT" "ALL" "R" ss "")
(setq ss (ssget "P"))
(setq i 0)
(repeat (sslength ss)
  (setq sn (ssname ss i))
  (setq ent (entget sn))
  (setq lx (cdr (assoc 60 ent)))
  (if (= lx nil) (progn
   (setq a (list (cons 60 1)))
   (setq ent (append ent a))
   (entmod ent)
  (if (/= lx nil) (progn
   (setq ent (subst (cons 60 1) (assoc 60 ent) ent))
   (entmod ent)
  (setq i (1+ i))
发表于 2015-10-14 12:25:44 | 显示全部楼层
ymcui 发表于 2015-10-13 11:40
;[恢复隐藏]
(defun c:xs (/ AcadObject AcadDocument LayersObj ss n i ent ob lay vlay lay-tn)
(set ...
谢谢!刚开始没注意看
发表于 2015-10-14 14:18:01 | 显示全部楼层
  1. ;[隐藏物体]
  2. (defun c:yc ( / AcadObject AcadDocument LayersObj ss n n-yc i ent ob lay vlay )   ;lay-tn
  3. (setq AcadObject (vlax-get-acad-object)
  4.               AcadDocument (vla-get-ActiveDocument AcadObject)
  5.               LayersObj (vla-get-layers AcadDocument)
  6. );end setq
  7. (princ "\n请选择需要隐藏的物体" )
  8. (if (setq ss (ssget))
  9.                (progn
  10.                       (setq n (sslength ss)
  11.                                                         n-yc 0 )
  12.                       (setq i (- n 1))
  13.                       (repeat n
  14.                              (setq ent (ssname ss i)
  15.                                     ob (vlax-ename->vla-object ent)
  16.                                     lay (vla-get-layer ob)
  17.                                     vlay (vla-item LayersObj lay)
  18.                             );end setq
  19.
  20.
  21.                              ; (if (= (setq lay-tn (vla-get-lock vlay)) :vlax-true);如果图层锁定
  22.                                     ; (vla-put-lock vlay :vlax-false);先解锁图层
  23.                             ; );end if
  24.                              ; (vla-put-visible ob :vlax-false)
  25.                              ; (if (= lay-tn :vlax-true)
  26.                                     ; (vla-put-lock vlay :vlax-true);再锁定图层,恢复图层状态
  27.                             ; );end if
  28.                                                         ;当图层未锁定时,执行隐藏操作
  29.                                                      (if (= (vla-get-lock vlay) :vlax-false)
  30.        (progn
  31.        (vla-put-visible ob :vlax-false)
  32.        (setq n-yc (+ n-yc 1))
  33.        )
  34.                                                          )
  35.                              (setq i (1- i))
  36.                      );end repeat
  37.                       (princ (strcat "\n已隐藏"  (itoa n-yc)   "物体" ))
  38. ));end if
  39. (princ)
  40. );end defun
发表于 2018-8-30 18:51:19 | 显示全部楼层
谢谢大神,牛牛牛牛!!!
GMT+8, 2025-7-13 20:46 , Processed in 0.161455 second(s), 18 queries , Gzip On.
