查看: 2432|回复: 3
如何用VBA更改字体的字形名称(黑体,宋体等)
发表于 2015-10-11 22:52:55 | 显示全部楼层 |阅读模式
下面代码是通过数据集,fDataArr = Array("MText", "Text"): fTypeArr = Array("0", "0")
通过ReturnAllSelectSet获得MText,Text集。
          Case "AcDbText"
             Set objTxt = objSet.Item(ii)
             With objTxt
               'Debug.Print .TextString
               'Debug.Print .ScaleFactor
               .ScaleFactor = 0.5
             End With
请求帮助,如何更改text的字体字形名,如更改为黑体,宋体字
  1. Sub ls1()
  2.   Dim objSet As AcadSelectionSet
  3.   Dim fDataArr, fTypeArr
  4.   fDataArr = Array("Line", "Arc"): fTypeArr = Array("0", "0")
  5.   fDataArr = Array("Line", "Text"): fTypeArr = Array("0", "0")
  6.   fDataArr = Array("Text"): fTypeArr = Array("0")
  7.   fDataArr = Array("MText", "Text"): fTypeArr = Array("0", "0")
  8.   Dim objLine As AcadLine, objArc As AcadArc, objText As AcadText
  9.   Set objSet = ReturnAllSelectSet(fTypeArr, fDataArr)
  10.   Dim objTxt As AcadText, objMTxt As AcadMText
  11.   ''
  12.   For ii = 0 To objSet.Count - 1
  13.       'Debug.Print objSet.Item(ii).ObjectName
  14.       Select Case objSet.Item(ii).ObjectName
  15.           Case "AcDbText"
  16.              Set objTxt = objSet.Item(ii)
  17.              With objTxt
  18.                'Debug.Print .TextString
  19.                'Debug.Print .ScaleFactor
  20.                .ScaleFactor = 0.5
  21.              End With
  22.           Case "AcDbMText"
  23.              Set objMTxt = objSet.Item(ii)
  24.              With objMTxt
  25.                 Debug.Print .TextString
  26.              End With
  27.       End Select
  28.
  29.   Next ii
  30.
  31. End Sub
  1. Function ReturnAllSelectSet(fTypeArray As Variant, fDataArray As Variant) As AcadSelectionSet
  2.     Dim Sset As AcadSelectionSet
  3.     On Error Resume Next
  4.     '建立选择集
  5.     ThisDrawing.SelectionSets("aa").Delete
  6.     Set Sset = ThisDrawing.SelectionSets.Add("aa")
  7.     '建立过滤器
  8.     Dim fType, fData
  9.     ReDim fType(0 To UBound(fTypeArray) + 2) As Integer
  10.     ReDim fData(0 To UBound(fDataArray) + 2) As Variant
  11.     fType(0) = -4
  12.     For ii = 0 To UBound(fTypeArray)
  13.       fType(ii + 1) = fTypeArray(ii)
  14.     Next ii
  15.     fType(UBound(fType)) = -4
  16.     ''
  17.     fData(0) = "<Or"
  18.     For ii = 0 To UBound(fDataArray)
  19.       fData(ii + 1) = fDataArray(ii)
  20.     Next ii
  21.     fData(UBound(fData)) = "Or>"
  22.     ''
  23.     '选择过滤出图形中所有的标注对象
  24.     Sset.Select acSelectionSetAll, , , fType, fData
  25.     Set ReturnAllSelectSet = Sset
  26. End Function
  1. Private Sub ll()
  2.    Dim Count As Integer
  3.
  4.    Dim Ent As AcadEntity, BlkRef As AcadBlockReference
  5.    Dim mTxtEnt As AcadMText, TxtEnt As AcadText
  6.       For ii = 0 To ThisDrawing.ModelSpace.Count - 1
  7.          Set Ent = ThisDrawing.ModelSpace.Item(ii)
  8.          Select Case Ent.ObjectName
  9.              Case "AcDbBlockReference"
  10.                 Set BlkRef = Ent
  11.              Case "AcDbMText"
  12.                 Set mTxtEnt = Ent
  13.                 Debug.Print mTxtEnt.TextString
  14.          End Select
  15.       Next ii
  16. End Sub
发表于 2015-10-12 10:46:47 | 显示全部楼层
如果没记错的话,不能改text的font,只能改该text所属的textstyle的fontfile。
    For I = 0 To ActiveDocument.TextStyles.Count - 1
        Select Case ActiveDocument.TextStyles.Item(I).Name
               Case "KADER35", "KADER50", "HELVL", "ST1", "ISO2_5"
                    ActiveDocument.TextStyles.Item(I).fontFile = Application.Path & "\fonts\txt.shx"
               Case Else
        End Select
    Next I
 楼主| 发表于 2015-10-12 19:19:20 | 显示全部楼层
谢谢回复
附件第三软件(Solidworks)自动生成的DWG文件。
文字处理格式总会有些问题,只能用AutoCAD的VBA方法处理。
现在解决方法用人工爆炸文字后,用下面代码进行处理。
  1. Private Sub ll3()
  2.
  3.
  4.    Dim Ent As AcadEntity, BlkRef As AcadBlockReference, E() As AcadEntity
  5.    Dim mTxtEnt As AcadMText, TxtEnt As AcadText, Kk As Integer
  9.              Case "AcDbText"
  10.                 Set TxtEnt = Ent
  11.                 TxtEnt.ScaleFactor = 0.7
  12.
  13.          End Select
  14.       Next ii
  15. End Sub
发表于 2015-10-13 09:19:41 | 显示全部楼层
同样问题哈。以下是我的代码
Sub ChangeFontWidth()
    Dim I As Integer, J As Integer, K As Integer
    Dim varAttributes As Variant
    Dim ssetObj As AcadSelectionSet
               Case Else
        End Select
    Next I
    Set ssetObj = CreateSelectionSet("textobj")
    Dim FType, FData
    BuildFilter FType, FData, -4, "<or", 0, "text", 0, "mtext", 0, "insert", -4, "or>"
    'SsetObj.SelectOnScreen ftype, fdata
    ssetObj.Select acSelectionSetAll, , , FType, FData
    For I = 0 To ssetObj.Count - 1
        Select Case ssetObj.Item(I).ObjectName
               Case "AcDbText" ', "AcDbMText"
                    Select Case ssetObj.Item(I).StyleName
                                 ssetObj.Item(I).ScaleFactor = 0.64
                           Case Else
                    End Select
                    ssetObj.Item(I).Update
                    If ssetObj.Item(I).HasAttributes Then
                       varAttributes = ssetObj.Item(I).GetAttributes
                           For J = LBound(varAttributes) To UBound(varAttributes)
                                   Select Case varAttributes(J).StyleName
                                                varAttributes(J).ScaleFactor = 0.64
                                          Case Else
                                   End Select
                                  varAttributes(J).Update
                           Next J
                    End If
        End Select
    Next I
    ssetObj.Clear
    'ActiveDocument.Utility.Prompt vbLf & replacedtext & " text(s) replaced!" & vbLf
End Sub
GMT+8, 2025-5-26 03:16 , Processed in 0.192893 second(s), 28 queries , Gzip On.
