查看: 1313|回复: 0
[界面] ListView 中带有数字的字符串排序问题?
发表于 2015-9-16 01:50:22 | 显示全部楼层 |阅读模式
http://bbs.csdn.net/topics/310046331
上面有,但是不知道为什么用不起来。请指点一二。
https://msdn.microsoft.com/zh-cn ... viewitemsorter.aspx
因为是按字符串排序,遇到数字时就变成,1,100,110,112的排序了。
        #region ListView排序类
        /// <summary>
        /// ListView排序类
        /// </summary>
        public class ListViewItemComparer : System.Collections.IComparer
            //private int col;
            private SortOrder order;
            public ListViewItemComparer()
                //col = 0;
                order = SortOrder.Ascending;
            public ListViewItemComparer(int column, SortOrder order)
                //col = column;
                this.order = order;
            public int Compare(object x, object y)
                int returnVal = -1;
                int col = 0;
                if (ValidateNum(((ListViewItem)x).SubItems[col].Text) && ValidateNum(((ListViewItem)y).SubItems[col].Text))
                    returnVal = decimal.Compare(Convert.ToDecimal(((ListViewItem)x).SubItems[col].Text),
                        Convert.ToDecimal(((ListViewItem)y).SubItems[col].Text));
                    if (order == SortOrder.Descending)
                        returnVal *= -1;
                    return returnVal;
                else
                    returnVal = String.Compare(((ListViewItem)x).SubItems[col].Text, ((ListViewItem)y).SubItems[col].Text);
                        returnVal *= -1;
                    return returnVal;
        public static bool ValidateNum(string InputStr)
            if (InputStr != "")
                if (Regex.IsMatch(InputStr.Trim(' '), @"^(0|[+-]?0\.\d+|[+-]?[1-9]([0-9]+)?(\.\d+)?)$"))
                    return true;
                else
                    return false;
            return true;
        #endregion
GMT+8, 2025-5-1 21:35 , Processed in 0.177452 second(s), 27 queries , Gzip On.
