查看: 1262|回复: 1
[符号表] vb.net如何通过实体得到其所属的组的名字
发表于 2015-9-6 10:32:52 | 显示全部楼层 |阅读模式
求大侠指点
发表于 2015-9-22 16:12:23 | 显示全部楼层
  1. Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
  2.         Dim PromptResult As PromptEntityResult = doc.Editor.GetEntity("选择对象")
  3.         If PromptResult.Status <> PromptStatus.OK Then
  4.             Exit Sub
  5.         End If
  6.         Using doc.LockDocument
  7.             Using Trans As Transaction = doc.TransactionManager.StartTransaction
  8.                 Dim SelectedEnt As Entity = Trans.GetObject(PromptResult.ObjectId, OpenMode.ForRead)
  9.                 Dim GroupDict As DBDictionary = Trans.GetObject(doc.Database.GroupDictionaryId, OpenMode.ForRead)
  10.                 For Each GroupEnt As DBDictionaryEntry In GroupDict
  11.                     Dim Grp As Group = Trans.GetObject(GroupDict(GroupEnt.Key), OpenMode.ForRead)
  12.                     If Grp.Has(SelectedEnt) Then
  13.                         MsgBox(Grp.Name) '通过此处来判断
  14.                     End If
  15.                 Next
  16.                 Trans.Abort()
  17.             End Using
  18.         End Using
GMT+8, 2025-5-1 21:19 , Processed in 0.293301 second(s), 27 queries , Gzip On.
