查看: 1397|回复: 3
vba提示类型不匹配,如何解决?
发表于 2015-8-13 10:37:26 | 显示全部楼层 |阅读模式
运行子程序aaa,到下面红色代码处提示“类型不匹配”,请问如何解决?
Public Declare PtrSafe Function SetTimer Lib "user32.dll" (ByVal hwnd As Long, ByVal nIDEvent As Long, ByVal uElapse As Long, ByVal lpTimerFunc As Long) As Long
Public Declare PtrSafe Function KillTimer Lib "user32.dll" (ByVal hwnd As Long, ByVal nIDEvent As Long) As Long
Public lTimerID As Integer
Public Sub Start_Timer()
    If lTimerID = 0 Then
        lTimerID = SetTimer(0&, 0&, 3000, AddressOf Ontime)
    Else
        Call Stop_Timer
    End If
End Sub
Public Sub Stop_Timer()
    KillTimer 0&, lTimerID
End Sub
Public Sub Ontime()
    Dim R As Integer
   R = MsgBox("ok", vbOKCancel)
   If R = vbCancel And lTimerID <> 0 Then Call Stop_Timer
End Sub
Private Sub aaa()
Call Start_Timer
End Sub
我猜你是在64位系统64位cad下用32位系统的代码  发表于 2015-8-13 12:06
发表于 2015-8-13 12:05:14 | 显示全部楼层
Public Declare PtrSafe Function SetTimer Lib "user32.dll" (ByVal hwnd As Long, ByVal nIDEvent As Long, ByVal uElapse As Long, ByVal lpTimerFunc As Longptr) As Long
    Else
        Call Stop_Timer
    End If
End Sub
End Sub
Public Sub Ontime()
    Dim R As Integer
End Sub
Private Sub aaa()
Call Start_Timer
End Sub
发表于 2015-8-13 15:53:59 | 显示全部楼层
帮顶,希望楼主尽快得到解决办法!
 楼主| 发表于 2015-8-13 16:28:19 | 显示全部楼层
zzyong00 发表于 2015-8-13 12:05
Public Declare PtrSafe Function SetTimer Lib "user32.dll" (ByVal hwnd As Long, ByVal nIDEvent As Lon ...
非常感谢
我把long改成any,也通过调试了。
再次感谢!
GMT+8, 2025-5-26 03:16 , Processed in 0.193777 second(s), 28 queries , Gzip On.
