查看: 1031|回复: 3
“AutoCAD.Application”未定义,求解
发表于 2015-8-6 15:51:13 | 显示全部楼层 |阅读模式
上码先:
  1. Sub Drawline()
  2.
  3.    Dim AutoCADApp As AutoCAD.Application
  4.    Set AutocadApp = CreateObject("AutoCAD.Application")
  5.    Dim Aline As AcadLine
  6.    Dim PointS(2) As Double
  7.    Dim PointE(2) As Double
  8.
  9.    PointS(0) = ThisWorkbook.Sheets("Sheet1").Cells(2, 2).Value
  10.    PointS(1) = ThisWorkbook.Sheets("Sheet1").Cells(2, 3).Value
  11.    PointS(2) = ThisWorkbook.Sheets("Sheet1").Cells(2, 4).Value
  12.
  13.    PointE(0) = ThisWorkbook.Sheets("Sheet1").Cells(3, 2).Value
  14.    PointE(1) = ThisWorkbook.Sheets("Sheet1").Cells(3, 3).Value
  15.    PointE(2) = ThisWorkbook.Sheets("Sheet1").Cells(3, 4).Value
  16.
  17.    AutocadApp.Visible = True
  18.    Set Aline = AutocadApp.ModelSpace.AddLine(PointS, PointE)
  19.    Aline.Highlight = True
  20.
  21. End Sub
这段代码是在Excel VBA环境下编写的,目的是将Excel表格中的两个点的数据传递到AutoCAD中并画出直线。
代码运行至第一句“Dim AutocadApp As AutoCAD.Application”就卡主了,提示如下:
然而,在运行这段代码前我已经加载了“AutoCAD 2008 Type library”库:
烦请请各位指教!
发表于 2015-8-7 11:07:36 | 显示全部楼层
发表于 2015-8-7 11:29:26 | 显示全部楼层
发表于 2015-8-7 11:55:07 | 显示全部楼层
  1. Sub drawline2()
  2. Dim acadApp As Object
  3. Dim acadDoc As Object
  4. On Error Resume Next
  5. Set acadApp = GetObject(, "AutoCAD.Application")
  6. If err Then
  7. err.Clear
  8. Set acadApp = CreateObject("AutoCAD.Application")
  9. If err Then End
  10. End If
  11. Set acadDoc = acadApp.ActiveDocument
  12.    Dim Aline As Object
  13.    Dim PointS(2) As Double
  14.    Dim PointE(2) As Double
  15.    PointS(0) = Cells(2, 2)
  16.    PointS(1) = Cells(2, 3)
  17.    PointS(2) = Cells(2, 4)
  18.    PointE(0) = Cells(3, 2)
  19.    PointE(1) = Cells(3, 3)
  20.    PointE(2) = Cells(3, 4)
  21.
  22.    acadApp.Visible = True
  23.    Set Aline = acadDoc.ModelSpace.AddLine(PointS, PointE)
  24.    Aline.Highlight = True
  25.    'acadDoc.Application.ZoomExtents
  26. End Sub
GMT+8, 2025-5-26 06:12 , Processed in 0.170616 second(s), 24 queries , Gzip On.
