查看: 1494|回复: 0
遇到几个ReverseCurve无法换向的polyline,原因不明,请大神研究下
发表于 2015-8-4 16:17:41 | 显示全部楼层 |阅读模式
附件已上传,不存在重复点问题
在CASS中使用H命令换向也没有用
  1. public static bool Clockwise(this Polyline pline)//判断Polyline是否顺时针绘制
  2.     {
  3.       Polyline pline1 = (Polyline)pline.Clone();
  4.       double bulge0 = pline1.GetBulgeAt(0);
  5.       double area0 = pline1.Area;
  6.       if (bulge0 == 0.0)
  7.       {
  8.         pline1.SetBulgeAt(0, 0.5);
  9.         double area1 = pline1.Area;
  10.         if (area1 > area0)
  11.           return false;
  12.         else
  13.           return true;
  14.       }
  15.       else
  16.       {
  17.         pline1.SetBulgeAt(0, 0);
  18.         double area1 = pline1.Area;
  19.         if (bulge0 > 0)
  20.         {
  21.           if (area1 > area0)
  22.             return true;
  23.           else
  24.             return false;
  25.         }
  26.         else
  27.         {
  28.           if (area1 > area0)
  29.             return false;
  30.           else
  31.             return true;
  32.         }
  33.       }
  34.     }
复制代码
  1. [CommandMethod("FX")]
  2.     public void FX()
  3.     {
  4.       Autodesk.AutoCAD.ApplicationServices.Document DOC = AcadApp.DocumentManager.MdiActiveDocument;
  5.       Autodesk.AutoCAD.EditorInput.Editor ed = DOC.Editor; Database db = HostApplicationServices.WorkingDatabase;
  6.       PromptEntityOptions CADentity_PEO = new PromptEntityOptions("\n请准确选择PL线");
  7.       CADentity_PEO.SetRejectMessage("\n所选实体非PL线.");
  8.       CADentity_PEO.AddAllowedClass(typeof(Polyline), true);
  9.       PromptEntityResult CADentity_RST = ed.GetEntity(CADentity_PEO);
  10.       if (CADentity_RST.Status == PromptStatus.OK)
  11.       {
  12.         using (DocumentLock DOClock = DOC.LockDocument())
  13.         {
  14.           using (Transaction trans = db.TransactionManager.StartTransaction())
  15.           {
  16.             BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead); //以读方式打开块表.
  17.             BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
  18.             Polyline ZDline = CADentity_RST.ObjectId.GetObject(OpenMode.ForWrite) as Polyline; //宗地线
  19.             if (!(ZDline.Clockwise())) { ZDline.ReverseCurve(); MessageBox.Show("逆时针已成顺时针"); }
  20.             else { MessageBox.Show("SSZ"); }
  21.             trans.Commit();
  22.           }
  23.         }
  24.       }
  25.     }
GMT+8, 2025-5-1 21:17 , Processed in 0.182348 second(s), 25 queries , Gzip On.
