帖子
查看: 1088|回复: 0
鼠标拉框事件问题
发表于 2015-7-22 09:16:59 | 显示全部楼层 |阅读模式
鼠标拉框后  1 绘制出这个框
2 不让entity被选中
下面代码有异常,框没有绘制出来,另外 2 没有解决
全局变量   Point3d startPt;
    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.PromptingForCorner += new PromptPointOptionsEventHandler(Editor_PromptingForCorner);
            Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.PromptedForCorner += new PromptPointResultEventHandler(Editor_PromptedForCorner);
   void Editor_PromptingForCorner(object sender, PromptPointOptionsEventArgs e)
            startPt = e.Options.BasePoint;
  void Editor_PromptedForCorner(object sender, PromptPointResultEventArgs e)
            Point3d endPt = e.Result.Value;
            Editor ed=Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            //Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(startPt.X.ToString() + ":" + startPt.Y.ToString() + ":" + endPt.X.ToString());
            //PromptSelectionResult res = ed.SelectImplied();
            //if (res.Status != PromptStatus.OK) return;
            //if (res.Value.Count == 0) return;
            //Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("d2d");
            Database db = ed.Document.Database;
            Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
            using (Transaction tr = tm.StartTransaction())
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("d1d");
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                Polyline entity = new Polyline();
                //之前的代码出现异常
                entity.AddVertexAt(entity.NumberOfVertices, new Point2d(startPt.X, startPt.Y), 0, -1, -1);
                entity.AddVertexAt(entity.NumberOfVertices, new Point2d(endPt.X, startPt.Y), 0, -1, -1);
                entity.AddVertexAt(entity.NumberOfVertices, new Point2d(endPt.X, endPt.Y), 0, -1, -1);
                entity.AddVertexAt(entity.NumberOfVertices, new Point2d(startPt.X, endPt.Y), 0, -1, -1);
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("d3d");
                entity.Closed = true;
                entity.ColorIndex = 1;
                entity.LineWeight = LineWeight.LineWeight005;
                //entity.Layer = layername;// layer.Name;
                btr.AppendEntity(entity);
                tr.AddNewlyCreatedDBObject(entity, true);
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("d4d");
                //for (int i = 0; i < res.Value.Count; i++)
                //    Entity entity = tr.GetObject(res.Value[i].ObjectId, OpenMode.ForWrite) as Entity;
                //    entity.Unhighlight();
                //    Autodesk.AutoCAD.ApplicationServices.Application.UpdateScreen();
                tr.Commit();
各位大神,帮助看下。谢谢
GMT+8, 2025-6-9 11:49 , Processed in 0.181268 second(s), 23 queries , Gzip On.
