查看: 1081|回复: 1
VBA中编写块命令的问题
发表于 2015-7-9 21:38:26 | 显示全部楼层 |阅读模式
在CAD中编程块,每次运行一次,在CAD中多增加一个图形,请大神看看程序。谢谢啦。
  1. Private Sub CommandButton1_Click()
  2. Dim PtPick As Variant
  3. UserForm1.hide
  4. PtPick = ThisDrawing.Utility.GetPoint(, "请在屏幕上选择起点:")
  5. TextBox1.Text = PtPick(0)
  6. TextBox2.Text = PtPick(1)
  7. UserForm1.Show
  8. Dim blkObj As AcadBlock
  9. Dim insPnt(0 To 2) As Double
  10.
  11.     '设定图块对象的原点坐标
  12.     insPnt(0) = 0: insPnt(1) = 0: insPnt(2) = 0
  13.     '在Blocks集合中创建名为TestBlock1的块对象
  14.     Set blkObj = ThisDrawing.Blocks.Add(insPnt, "TestBlock1")
  15.
  16.
  17.
  18.     '-------------------------------------------------------------
  19. Dim cirObj As AcadCircle
  20. Dim center(0 To 2) As Double
  21. Dim radius As Double
  22. center(0) = TextBox1.Text: center(1) = TextBox2.Text: center(2) = 0
  23. radius = 0
  24. radius = Val(TextBox3.Text)
  25.     Set cirObj = blkObj.AddCircle(center, radius)
  26.     cirObj.color = acRed
  27.
  28.
  29.     Dim lineObj As AcadLine
  30.     Dim sPnt(0 To 2) As Double, ePnt(0 To 2) As Double
  31.
  32.     sPnt(0) = center(0): sPnt(1) = center(1): sPnt(2) = 0
  33.     ePnt(0) = center(0) + 60: ePnt(1) = center(1) + 80: ePnt(2) = 0
  34.
  35.     '创建一条直线
  36.     Set lineObj = blkObj.AddLine(sPnt, ePnt)
  37. '-------------------------------------------------------------
  38.     '本段代码将把TestBlock1块对象插入到模型空间
  39.
  40.     Dim blkRefObj As AcadBlockReference
  41.
  42.
  43.     Dim insertPnt(0 To 2) As Double
  44.
  45.     '指定模型空间的插入点
  46.     insertPnt(0) = 120: insertPnt(1) = 100: insertPnt(2) = 0
  47.
  48.     '插入图块
  49.     Set blkRefObj = ThisDrawing.ModelSpace.InsertBlock(insertPnt, "TestBlock1", 1#, 1#, 1#, 0#)
  50.
  51.
  52.     blkRefObj.Update
  53. End Sub
发表于 2015-7-14 07:33:05 | 显示全部楼层
你的问题是什么?
GMT+8, 2025-5-26 05:52 , Processed in 0.153605 second(s), 23 queries , Gzip On.
