查看: 1004|回复: 1
为什么不能获取属性值?
发表于 2015-7-9 08:55:29 | 显示全部楼层 |阅读模式
我用.net的方法读取块里的属性
Private Function DbxGetBlocksData(btr As BlockTableRecord, doc As Document) As Dictionary(Of String, String)
        Dim dic As New Dictionary(Of String, String)
        Dim db As Database = doc.Database
        Using trans As Transaction = db.TransactionManager.StartTransaction
            For Each obj_id As ObjectId In btr
                Dim ent As Entity = trans.GetObject(obj_id, OpenMode.ForRead)
                If ent.GetType.Name = "AttributeDefinition" Then
                    Dim adf As AttributeDefinition = ent
                   dic.Add(adf.Tag, adf.TextString)
                   daf.Tag可以获取属性名称,但是daf.TextString的值始终是"",请问一下是为什么?
                End If
            Next
        End Using
        Return dic
    End Function
 楼主| 发表于 2015-7-9 10:58:15 | 显示全部楼层
搞定了,贴上来,免得以后忘了。
    Dim brf_ids As ObjectIdCollection = btr.GetBlockReferenceIds(True, False)
                Dim br As BlockReference
                For Each brf_id As ObjectId In brf_ids
                    Dim obj As Object = brf_id.GetObject(OpenMode.ForRead)
                    If obj.GetType.Name = "BlockReference" Then
                        br = obj
                        If br.Name.StartsWith("股份公司-") Then
                            For Each att_id As ObjectId In br.AttributeCollection
                                Dim att As AttributeReference = att_id.GetObject(OpenMode.ForRead)
                                If att.Tag.StartsWith("名称{") Then
                                    dObj.PaperName = att.TextString
                                End If
                                If att.Tag.StartsWith("图号{") Then
                                    dObj.PaperCode = att.TextString
                                End If
                            Next
                            Exit For
                        End If
                    End If
                Next
GMT+8, 2025-5-1 22:54 , Processed in 0.167898 second(s), 23 queries , Gzip On.
