查看: 2669|回复: 3
[求助]如何批量给线段标注上编号和长度?
发表于 2015-7-8 09:52:20 | 显示全部楼层 |阅读模式
如何实现给图中的线段批量编号和标注长度(非用标注工具,而是直接输入长度数字)?
发表于 2015-7-8 17:29:54 | 显示全部楼层
  (defun c:bzline ()
    (setq ss (ssget '((0 . "LINE"))))
    (setq i 0)
    (repeat (sslength ss)
      (setq e (ssname ss i))
      (setq el (entget e))
      (setq obj (vlax-ename->vla-object e))
      (setq start (vlax-curve-getStartPoint obj))
      (setq end (vlax-curve-getendPoint obj))
      (setq l (vlax-curve-getDistAtPoint obj end))
      (setq str (strcat "BH=" (rtos (1+ i)) " Long=" (rtos l 2 3) "m"))
      (entmake
        (list '(0 . "TEXT")
              (cons 1 str)
              (cons 10 (mapcar '(lambda (x y) (/ (+ x y) 2.)) start end))
              (cons 40 1)
              (cons 50 (angle start end))
      (setq i (1+ i))
 楼主| 发表于 2015-7-9 16:13:01 | 显示全部楼层
newbuser 发表于 2015-7-8 17:29
(defun c:bzline ()
    (setq i 0)
谢谢NEWBUSER,的确NB,完美地解决了我的问题,我是要下决心来学习LSP了。
发表于 2018-4-24 00:46:40 | 显示全部楼层
圆如何标示??
GMT+8, 2025-5-3 01:37 , Processed in 0.174139 second(s), 27 queries , Gzip On.
