查看: 1253|回复: 5
Mirror出来的图形怎么设为acadentity变量
发表于 2015-6-21 23:32:14 | 显示全部楼层 |阅读模式
试了一下,
dim cc=acadentity
dim dd=acadentity
mirror_Point1( 0 to 2) as double
.....................(略)
然后使用
Set dd = cc.Mirror mirror_Point1, mirror_Point2 或者set dd=cc.Mirror 都不行,
我想把镜像出来的acadentity作为变量,请问该如何写?
 楼主| 发表于 2015-6-22 11:26:52 | 显示全部楼层
有哪位大虾,帮忙解答一下,感谢感谢!祝端午快乐!
 楼主| 发表于 2015-6-22 18:25:08 | 显示全部楼层
在线坐等
发表于 2015-6-22 18:58:19 | 显示全部楼层
  1. Sub Example_Mirror()
  2.     ' This example creates a lightweight polyline
  3.     ' and then mirrors that polyline.
  4.
  5.     ' Create the polyline
  6.     Dim plineObj As AcadLWPolyline
  7.     Dim points(0 To 11) As Double
  8.     points(0) = 1: points(1) = 1
  9.     points(2) = 1: points(3) = 2
  10.     points(4) = 2: points(5) = 2
  11.     points(6) = 3: points(7) = 2
  12.     points(8) = 4: points(9) = 4
  13.     points(10) = 4: points(11) = 1
  14.     Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
  15.     plineObj.Closed = True
  16.     ZoomAll
  17.
  18.     ' Define the mirror axis
  19.     Dim point1(0 To 2) As Double
  20.     Dim point2(0 To 2) As Double
  21.     point1(0) = 0: point1(1) = 4.25: point1(2) = 0
  22.     point2(0) = 4: point2(1) = 4.25: point2(2) = 0
  23.
  24.
  25.     ' Mirror the polyline
  26.     Dim mirrorObj As AcadLWPolyline
  27.     Set mirrorObj = plineObj.Mirror(point1, point2)
  28.
  29.     ZoomAll
  30.     Dim objEnt As AcadEntity
  31.     Set objEnt = mirrorObj
  32.     MsgBox objEnt.ObjectName
  33. End Sub
 楼主| 发表于 2015-6-22 21:49:50 | 显示全部楼层
zzyong00 发表于 2015-6-22 18:58
感谢老大,发现基本上就老大一个人回帖
顺便请教一下,我想用 Select acSelectionSetAll, , , FilterType, FilterData 只选择模型空间的,不对布局空间进行选择,该怎么弄?谢谢!
发表于 2015-6-22 23:08:44 | 显示全部楼层
组码67        值为空或0时即指图元在模型空间,如果为1指在图形空间
GMT+8, 2025-5-26 05:42 , Processed in 0.177403 second(s), 23 queries , Gzip On.
