查看: 1853|回复: 8
闭合平行线!
发表于 2015-6-17 11:42:20 | 显示全部楼层 |阅读模式
5明经币
求小程序,能闭合2条平行的多段线!
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
发表于 2015-6-17 11:42:21 | 显示全部楼层
  1. (vl-load-com)
  2. (defun lwpts(lwen / lwdt)
  3.         (setq lwdt (entget lwen))
  4.         (vl-remove-if-not '(lambda(e1) (equal (car e1) 10)) lwdt)
  5. )
  6. (defun c:bh()
  7.         (prompt "\nSelect 2 lwpolylines:")
  8.         (setq ss (ssget '((0 . "lwpolyline"))))
  9.         (or ss (setq ss (ssadd)))
  10.         (setq len (sslength ss) m 0)
  11.         (if (/= len 2)
  12.                 (princ "\n不是2根! ---程序退出......")
  13.                 (progn
  14.                         (setq en1 (ssname ss 0) en2 (ssname ss 1))
  15.                         (setq data1 (lwpts en1) data2 (lwpts en2))
  16.                         (setq pt1 (cdar data1) pt2 (cdr (last data1)))
  17.                         (setq pt3 (cdar data2) pt4 (cdr (last data2)))
  18.                         (setq dis1 (distance pt1 pt3) dis2 (distance pt1 pt4))
  19.                         (if (> dis1 dis2)(setq ptx pt3 pt3 pt4 pt4 ptx ptx nil))
  20.                         (entmake (list '(0 . "LINE") (cons 10 pt1) (cons 11 pt3)))
  21.                         (setq ss (ssadd (entlast) ss))
  22.                         (entmake (list '(0 . "LINE") (cons 10 pt2) (cons 11 pt4)))
  23.                         (setq ss (ssadd (entlast) ss))
  24.                         (setvar "cmdecho" 0)
  25.                         (setvar "peditaccept" 1)
  26.                         (command "pedit" "m"  ss "" "j" "" "")
  27.                         (setvar "peditaccept" 0)
  28.                         (setvar "cmdecho" 1)
  29.                 )
  30.         )
  31.         (princ)
  32. )
发表于 2015-6-21 11:12:31 | 显示全部楼层
不错,但能不能改成支持LINE线?
 楼主| 发表于 2015-6-24 09:19:56 | 显示全部楼层
可以了谢谢!
 楼主| 发表于 2015-6-24 09:22:20 | 显示全部楼层
能不能加点,闭合后同时填充上,图案名称是  ANSI36  那个!
发表于 2015-6-24 14:59:33 | 显示全部楼层
  1. (vl-load-com)
  2. (defun lwpts (lwen)
  3. (vl-remove-if-not '(lambda(a) (= (car a) 10)) (entget lwen))
  4. )
  5. (defun c:bh()
  6. (prompt "\nSelect 2 lwpolylines:")
  7. (if (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
  8.           (= (sslength ss) 2)) (progn
  9.   (setq en1 (ssname ss 0) en2 (ssname ss 1))
  10.   (setq data1 (lwpts en1) data2 (lwpts en2))
  11.   (setq pt1 (cdar data1) pt2 (cdr (last data1)))
  12.   (setq pt3 (cdar data2) pt4 (cdr (last data2)))
  13.   (setq dis1 (distance pt1 pt3) dis2 (distance pt1 pt4))
  14.   (if (> dis1 dis2)(setq ptx pt3 pt3 pt4 pt4 ptx ptx nil))
  15.   (entmake (list '(0 . "LINE") (cons 10 pt1) (cons 11 pt3)))
  16.   (ssadd (entlast) ss)
  17.   (entmake (list '(0 . "LINE") (cons 10 pt2) (cons 11 pt4)))
  18.   (ssadd (entlast) ss)
  19.   (setvar "cmdecho" 0)
  20.   (setvar "peditaccept" 1)
  21.   (command "_.pedit" "m" ss "" "j" "" "")
  22.   (command "_.HATCH" "ANSI36" "" "" "L" "")
  23.   (setvar "peditaccept" 0)
  24.   (setvar "cmdecho" 1)
  25. )
  26.   (princ "\n不是2根! ---程序退出......")
  27. )
  28. (princ)
  29. )
 楼主| 发表于 2015-6-25 08:12:49 | 显示全部楼层
ZZXXQQ 发表于 2015-6-24 14:59
命令后 ,选不中线
发表于 2015-6-25 11:47:58 | 显示全部楼层
"LWPOYLINE"改"LWPOLYLINE"
 楼主| 发表于 2015-6-25 12:34:53 | 显示全部楼层
可以了,谢谢!
GMT+8, 2025-5-1 12:12 , Processed in 0.198115 second(s), 28 queries , Gzip On.
