查看: 1297|回复: 2
各位大侠个给看看错在哪里了,谢谢
发表于 2015-6-16 13:58:08 | 显示全部楼层 |阅读模式
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Windows;
using System.Windows.Controls;
using System.Windows.Input;
using System.Windows;
using System;
[assembly: CommandClass(typeof(insFst.Commands))]
namespace insFst
    public class Commands
        public bool _added = false;
        [CommandMethod("RTB")]
        public void RibbonTextBox()
            if (!_added)
                RibbonControl rc = ComponentManager.Ribbon;
                RibbonTab rt = null;
                foreach (RibbonTab tab in rc.Tabs)
                    if (tab.Name == "Plug-ins")
                        rt = tab;
                        break;
                if (rt == null)
                    rt = new RibbonTab();
                    rt.Title = "Custom";
                    rt.Id = "ID_CUSTOMRIBBONTAB";
                    rc.Tabs.Add(rt);
                RibbonPanelSource rps = new RibbonPanelSource();
                rps.Title = "Notifying Textbox";
                RibbonPanel rp = new RibbonPanel();
                rp.Source = rps;
                rt.Panels.Add(rp);
                RibbonItem ri0 = new RibbonItem { Text = "90",};
                RibbonItem ri1 = new RibbonItem { Text = "-90", };
                RibbonCombo tb = new RibbonCombo();
                tb.CommandHandler = new ComboBoxCommandHandler();
                tb.Items.Add(ri0);
                tb.Items.Add(ri1);
                rps.Items.Add(tb);
                rt.IsActive = true;
                _added = true;
        public static void Print(string s)
            Document doc =
              Autodesk.AutoCAD.ApplicationServices.
              Application.DocumentManager.MdiActiveDocument;
            doc.Editor.WriteMessage(s);
    public class ComboBoxCommandHandler : ICommand
        #pragma warning disable 67
        public event EventHandler CanExecuteChanged;
        #pragma warning restore 67
        public bool CanExecute(object parameter)
            return true;
        public void Execute(object parameter)
            RibbonCombo tb = parameter as RibbonCombo;
           if (tb != null)
                Commands.Print( tb.Text );
我想实现的功能,就是在Cad的命令行中显示下拉框中的值
请各位大侠给看看哪里错了,为什么红色字体处设置断点后,不执行呢,我同样是RibbonTextBox,RibbonButton都执行,为什么,还是说RibbonCombo不这么写吗
发表于 2015-6-16 18:53:31 | 显示全部楼层
看不懂
发表于 2015-6-17 16:52:18 | 显示全部楼层
你确定是RibbonCombo, 而不是RibbonComboBox?
ComponentManager.Ribbon中ComponentManager 是什么?
编译不过去,不知道你是怎么编译过得!
还是看一下例子:http://www.cnblogs.com/junqilian/archive/2012/06/18/2553662.html
GMT+8, 2025-5-1 22:41 , Processed in 0.179821 second(s), 27 queries , Gzip On.
