查看: 779|回复: 1
Coordinate出错
发表于 2015-6-15 14:45:24 | 显示全部楼层 |阅读模式
下面这段,在最后一句 Po = acc.Coordinate(0),总是出错   跳出  运行错误‘424’:要求对象 ,
调试了一下只要把Po = acc.Coordinate(0)这句注释掉就没有问题,确认了myset里有3个polyline,不知道为什么会出错。
Sub kk()
  Dim beginpoint(2) As Double
  Dim endpoint(2) As Double
  Dim aac As AcadEntity
  Dim Po As Variant
  Dim flag As Boolean
  Dim myset As AcadSelectionSet
  Dim filtertype(0) As Integer
  Dim filterdata(0) As Variant
  beginpoint(0) = 0: beginpoint(1) = 0
  endpoint(0) = 0: endpoint(1) = 100.1
flag = flase
For Each myset In ThisDrawing.SelectionSets
    If myset.Name = "drawletter" Then
       flag = True
       Exit For
    End If
Next
If flag = True Then
   myset.Delete
End If
Set myset = ThisDrawing.SelectionSets.Add("drawletter")
     filtertype(0) = 0
     filterdata(0) = "*POLYLINE"
     myset.Select acSelectionSetAll, , , filtertype, filterdata
  Set aac = myset.Item(1)
End Sub
发表于 2015-6-15 16:57:09 | 显示全部楼层
Po = acc.Coordinate(0)(0)
Po = acc.Coordinates(0)
GMT+8, 2025-5-26 05:42 , Processed in 0.140968 second(s), 23 queries , Gzip On.
