查看: 840|回复: 2
删除对象的问题
发表于 2015-6-15 08:29:37 | 显示全部楼层 |阅读模式
各位大侠:
              环境(vs2010+cad2010);我是根据数据库中的坐标(100,200,0),找到一个类型为Blockreference的块参照,然后删除掉,为什么不行呢??
我用这个函数返回根据坐标获取的块对象:
BlockReference blk = getBlkForPt(new Point3d(float.Parse("290"), float.Parse("621.3606"), 0));
blk.Erase(true);
这样删除不对吗???恳请大侠们指点一二,小妹在此不胜感激
发表于 2015-6-15 09:37:29 | 显示全部楼层
  1.         [CommandMethod("t_1")]
  2.         public void Test1()
  3.         {
  4.             var doc = Application.DocumentManager.MdiActiveDocument;
  5.             var ed = doc.Editor;
  6.             var db = doc.Database;
  7.             var res =
  8.                 ed.SelectAll(
  9.                     new SelectionFilter(
  10.                         new TypedValue[]
  11.                         {
  12.                             new TypedValue(0, "insert"),
  13.                             new TypedValue(10, new Point3d(100, 200, 0))
  14.                         }));
  15.             if(res.Status != PromptStatus.OK)
  16.                 return;
  17.             using (var tr = db.TransactionManager.StartTransaction())
  18.             {
  19.                 var id = res.Value.GetObjectIds()[0];
  20.                 var ent = tr.GetObject(id, OpenMode.ForWrite);
  21.                 ent.Erase();
  22.                 tr.Commit();
  23.             }
  24.         }
按点查找可能还是会出些问题 通常是在该点为中心的范围内查找
 楼主| 发表于 2015-6-15 10:21:47 | 显示全部楼层
飞狐大哥:
            我这个坐标点是固定的,而且这个坐标点肯定对应这个块参照,我是这么写的
private BlockReference getBlkForPt(Point3d dataBasePt)
            Document doc = app.DocumentManager.MdiActiveDocument;
            BlockReference resultBlk = null;
            using (DocumentLock d = doc.LockDocument())
                using (Transaction trans = doc.TransactionManager.StartTransaction())
                    BlockTable BlkTab = (BlockTable)trans.GetObject(doc.Database.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord btr = (BlockTableRecord)trans.GetObject(BlkTab[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                    foreach (ObjectId ID in btr)
                        Entity Ent = trans.GetObject(ID, OpenMode.ForWrite) as Entity;
                        if (Ent != null)
                            if (Ent is BlockReference)
                                BlockReference Blk = (BlockReference)Ent;
                                Blk.Unhighlight();
                                Point3d pt = Blk.Position;
                                Point3d p1 = new Point3d(pt.X, pt.Y, 0);
                                double a = p1.DistanceTo(dataBasePt);
                                if (p1.DistanceTo(dataBasePt) <= 0.1)
                                    resultBlk = Blk;
                                    Blk.Highlight();
            return resultBlk;
我这么写就把坐标对应的块参照找到了,而且高亮显示,然后怎么删除呢
GMT+8, 2025-5-1 23:04 , Processed in 0.195189 second(s), 23 queries , Gzip On.
