查看: 1625|回复: 3
求一个云线的lisp
发表于 2015-6-2 19:13:11 | 显示全部楼层 |阅读模式
10明经币
-->1. 框选生成云线,云线图层为当前日期,每天云线颜色不一样
-->2. 图层非打印,云线绘制完点击外面某点,绘制直线,
    如果不输批注,按空格,则默认文字为(某月某日修改)
-->3. 启动命令R1(框选画云线),R2(选择对象云线),R12(设置云线宽度)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2015-6-2 19:13:12 | 显示全部楼层
发表于 2017-11-8 14:54:31 | 显示全部楼层
求程序```````````
发表于 2017-12-28 17:08:00 | 显示全部楼层
凑了一个,自己改下适合自己用的就行了
(defun c:yun (/ #err99 $orr c pt pt2 r snap)  ;云线原作者 langjs
  (defun #err99 (s)
    (command ".UNDO" "E")
    (setvar "CECOLOR" c)
    (setvar "OSMODE" snap)
    (setq *error* $orr)
  (setq $orr *error*)
  (setq *error* #err99)
  (setvar "CMDECHO" 0)
  (command ".UNDO" "BE")
  (setvar "OSMODE" 0)
  (setq c (getvar "CECOLOR")
snap (getvar "OSMODE")
  (while (progn
    (if (null rbak)
      (setq rbak (* 0.8 (getvar "DIMSCALE") (getvar "DIMTXT")))
    (initget "A C ")
    (if (= (setq pt (getpoint "\n指定第一个角点或 [弧长(A)/颜色(C)]:"))
    "A"
      (setq r (getreal (strcat "\n指定弧长 <" (rtos rbak 2 3) ">:")))
      (if (= pt "C")
        (setq cdbak (cdr (car (acad_truecolordlg '(62 . 1)))))
    (not (= (type pt) 'list))
  (if r
    (setq rbak r)
  (if cdbak
    (command "color" cdbak)
    (command "color" 1)
  (while (not (setq pt2 (getcorner pt "\n指定另一个角点:"))))
        (command "layer" "s" "gm3" "")
(command "_rectang" pt pt2)
(command "layer" "s" "gm1" "")
  (command "_revcloud" "A" rbak rbak "O" "" (entlast) "N")
;--文字标示
(setq va (getvar "lunits"))
(setq date0 (menucmd "m=$(edtime,$(getvar,date),日期:YYYY-MO-DD:)" ))
(if (= va 2)     (progn        (setq vaa 3)       (setq vab 6)     )
(progn        (setq vaa 0.125)       (setq vab 0.25)     )   )
(PROGN
(setq le1 (getpoint "\n Specify the first point: "))
(setq le2 (getpoint "\n Specify the second point: "))
(setq str (getstring "\n输入说明:"))
(command "qleader"   le1 le2  "" "50"  date0  str  "" )
(setq ssa (ssget "X" '((0 . "LWPOLYLINE") (8 . "gm3"))))
(command "erase" ssa "" )
  (setq *error* $orr)
GMT+8, 2025-5-1 12:18 , Processed in 0.194771 second(s), 25 queries , Gzip On.
