楼主: 我还有梦想
[讨论] 各位老师看看。
发表于 2015-6-6 12:04:52 | 显示全部楼层
ymcui 发表于 2015-6-3 13:49
推广应用:1.把“温室”改为输入需要的文字,2.字高固定改为可选择。冒昧修改,敬请ymcui君见谅。
(defun c:tt ()
(command "layer" "M" "标注" "C" "6" "" "LT" "CONTINUOUS" "" "");设置一个标注图层
  (setvar "cmdecho" 0)
  (defun ebox (e / pa pb)
        (Vlax-Invoke-Method (Vlax-Ename->Vla-Object e ) 'GetBoundingBox 'pa 'pb )
        (setq pa (trans (vlax-safearray->list pa) 0 1)
                  pb (trans (vlax-safearray->list pb) 0 1)
        (list pa pb)
(setq TextHeight (getdist "\n请输入文字高度:(默认0.8)"))
    (if (= TextHeight nil) (setq TextHeight 0.8))
(setq qz (getstring "\n请输入需要的文字: "))
(while
  (setq ss (ssget":s" '((0 . "LWPOLYLINE"))))
  (repeat (setq i (sslength ss))
        (setq e (ssname ss (setq i (1- i)))
                  box (ebox e)
                  P3 (mapcar '* '(0.5 0.5 0.5)(mapcar '+ (car Box) (cadr Box)))
        (vl-cmdf "-text" "j" "M" p3 TextHeight 0 qz)
  (setvar "cmdecho" 1)
  (PRINC)
发表于 2015-6-6 13:56:51 | 显示全部楼层
(defu ...
这样是不是要好点
  1. (defun c:tt ()
  2. (command "layer" "M" "标注" "C" "6" "" "LT" "CONTINUOUS" "" "");设置一个标注图层
  3.   (setvar "cmdecho" 0)
  4.   (defun ebox (e / pa pb)
  5.         (Vlax-Invoke-Method (Vlax-Ename->Vla-Object e ) 'GetBoundingBox 'pa 'pb )
  6.         (setq pa (trans (vlax-safearray->list pa) 0 1)
  7.                   pb (trans (vlax-safearray->list pb) 0 1)
  8.         )
  9.         (list pa pb)
  10.   )
  11. ;(setq TextHeight (getdist "\n请输入文字高度:(默认0.8)"))
  12. ;    (if (= TextHeight nil) (setq TextHeight 0.8))
  13. (setq qz (getdist "\n请输入需要的文字:<温室> "))
  14. (if (= qz nil) (setq qz "温室"))
  15. (while
  16.   (setq ss (ssget":s" '((0 . "LWPOLYLINE"))))
  17.   (repeat (setq i (sslength ss))
  18.         (setq e (ssname ss (setq i (1- i)))
  19.               box (ebox e)
  20.               p1 (car box)
  21.         p2 (cadr box)
  22.         p3 (list (car p2) (cadr p1))
  23.               P4 (mapcar '* '(0.5 0.5 0.5)(mapcar '+ p1 p2))
  24.               TextHeight (* 0.5 (min (distance p1 p3) (distance p2 p3)))
  25.         )
  26.         (vl-cmdf "-text" "j" "M" p4 TextHeight 0 qz)
  27.   )
  28.   (setvar "cmdecho" 1)
  29.   (PRINC)
  30. )
  31. )
发表于 2015-6-6 17:49:43 | 显示全部楼层
ymcui 发表于 2015-6-6 13:56
这样是不是要好点
很好,谢谢。
发表于 2015-6-6 18:20:39 | 显示全部楼层
这样是不是要好点
第13行应为:(setq qz (getstring "\n请输入需要的文字<温室>: "))
GMT+8, 2025-7-16 17:32 , Processed in 0.158845 second(s), 19 queries , Gzip On.
