查看: 1291|回复: 0
region.BooleanOperation(BooleanOperationType.BoolSubtract, region1)异常
发表于 2015-5-29 10:46:41 | 显示全部楼层 |阅读模式
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                        Entity entity = tr.GetObject(entityID, OpenMode.ForWrite) as Entity;
                        Entity entity2 = tr.GetObject(entityID2, OpenMode.ForWrite) as Entity;
                        DBObjectCollection curveSegments = new DBObjectCollection();
                        curveSegments.Add(entity);
                        DBObjectCollection regions = Region.CreateFromCurves(curveSegments);
                        DBObjectCollection curveSegments2 = new DBObjectCollection();
                        curveSegments2.Add(entity2);
                        DBObjectCollection regions2 = Region.CreateFromCurves(curveSegments2);
                        Region region = regions[0] as Region;
                        Region region1 = regions2[0] as Region;
                        region.BooleanOperation(BooleanOperationType.BoolSubtract, region1);
entity和entity2是2个闭合的polyline
相交
BooleanOperation前region 和region2面积都不是0
BooleanOperation后region 面积为0    region.BooleanOperation(BooleanOperationType.BoolSubtract, region1);有异常
测试环境是c#2010+autoccad2013
高手帮助看下。这个问题困扰我几天了
GMT+8, 2025-5-1 22:54 , Processed in 0.190905 second(s), 24 queries , Gzip On.
