查看: 3114|回复: 9
求助各位:编一个能连接断开的SPLINE线的LISP程序
发表于 2004-2-21 21:34:00 | 显示全部楼层 |阅读模式
求助各位:编一个能连接断开的SPLINE线的LISP程序,
可以用来连接两跟断开的SPLINE线,比如:等高线,小路,......,也可以用在接图上
拜托了!!!!!!!!!!!
 楼主| 发表于 2004-2-22 16:56:00 | 显示全部楼层
呵呵,找到了,不用麻烦大家了,是 BDYCAD 编的程序
发表于 2004-2-23 23:58:00 | 显示全部楼层
这个程序在哪我也在找呢?
发表于 2005-2-5 16:19:00 | 显示全部楼层
找到了请发给我好吗
baoshun01@21cn.com
发表于 2005-3-25 22:33:00 | 显示全部楼层
能否把程序给发上来给大家共享?
发表于 2005-3-31 08:47:00 | 显示全部楼层
r2006好像已增加这样的功能.
Join Objects
Use to combine similar objects into a single object. You can also create
complete circles and ellipses from arcs and elliptical arcs. You can join
■ Arcs
■ Elliptical arcs
■ Lines
■ Polylines
■ Splines
The object to which you want to join similar objects is called a source object.
Objects to be joined must be located in the same plane. Additional restrictions
for each type of objects are described in the command.
NOTE When joining two or more arcs (or elliptical arcs), the arcs are joined
counterclockwise beginning from the source object.
发表于 2011-1-10 12:06:07 | 显示全部楼层
楼主,请你共享下好吗?
发表于 2011-1-10 18:38:45 | 显示全部楼层
样条曲线连接程序演示如下:
发表于 2011-1-10 18:40:46 | 显示全部楼层
pedit命令CAD自带
发表于 2011-1-12 23:58:45 | 显示全部楼层
没看懂,不知道什么意思。
GMT+8, 2025-5-25 22:05 , Processed in 0.185499 second(s), 24 queries , Gzip On.
