查看: 13517|回复: 25
合并一根直线上的两根线段
发表于 2004-2-12 19:13:00 | 显示全部楼层 |阅读模式
Sub uniteline()
Dim returnobj As AcadEntity, basepnt As Variant, pnt1 As Variant, pnt2 As Variant, pnt3 As Variant, pnt4 As Variant
Dim line1 As Variant, line2 As Variant
choose1:
ActiveDocument.Utility.GetEntity returnobj, basepnt, "选择第一根线段:"
Select Case returnobj.ObjectName
Case "AcDbLine" '第一根为line
Set line1 = returnobj
pnt1 = line1.StartPoint: pnt2 = line1.EndPoint
Case "AcDbPolyline" '第一根为lwpolyline
If line1.Area > 0.000001 Then '判断是否为直线
ActiveDocument.Utility.Prompt "您选择的不是一根线段,请重新选择"
GoTo choose1
Else
End If
pnt1 = basepnt
pnt2 = basepnt
basepnt = line1.Coordinates
pnt1(0) = basepnt(0): pnt1(1) = basepnt(1)
pnt2(0) = basepnt(2): pnt2(1) = basepnt(3)
If pnt1(0) = pnt2(0) Then '垂直
For i = 1 To (UBound(basepnt) + 1) / 2
If pnt1(1) > basepnt(2 * i - 1) Then pnt1(1) = basepnt(2 * i - 1)
If pnt2(1) < basepnt(2 * i - 1) Then pnt2(1) = basepnt(2 * i - 1)
Next i
Else '不垂直
If pnt1(0) > basepnt(2 * i - 2) Then
pnt1(0) = basepnt(2 * i - 2)
Else
End If
If pnt2(0) < basepnt(2 * i - 2) Then
pnt2(0) = basepnt(2 * i - 2)
Else
End If
Next i
End If
Case Else
GoTo choose1
End Select
choose2:
ActiveDocument.Utility.GetEntity returnobj, basepnt, "选择第二根线段:"
If returnobj.Handle = line1.Handle Then
ActiveDocument.Utility.Prompt "线段二与线段一重复,请重新选择"
GoTo choose2
Else
End If
Case "AcDbLine" '第二根为line
Set line2 = returnobj
pnt3 = line2.StartPoint: pnt4 = line2.EndPoint
Case "AcDbPolyline" '第二根为lwpolyline
If line2.Area > 0.000001 Then '判断是否为直线
GoTo choose2
Else
End If
pnt3 = basepnt
pnt4 = basepnt
basepnt = line2.Coordinates
pnt3(0) = basepnt(0): pnt3(1) = basepnt(1)
pnt4(0) = basepnt(2): pnt4(1) = basepnt(3)
If pnt3(0) = pnt4(0) Then '垂直
If pnt3(1) > basepnt(2 * i - 1) Then pnt3(1) = basepnt(2 * i - 1)
If pnt4(1) < basepnt(2 * i - 1) Then pnt4(1) = basepnt(2 * i - 1)
Next i
Else '不垂直
If pnt3(0) > basepnt(2 * i - 2) Then
pnt3(0) = basepnt(2 * i - 2)
Else
End If
If pnt4(0) < basepnt(2 * i - 2) Then
pnt4(0) = basepnt(2 * i - 2)
Else
End If
Next i
End If
Case Else
GoTo choose2
End Select
If pnt2(0) = pnt1(0) Then '垂直
If (pnt2(0) = pnt3(0)) And (pnt3(0) = pnt4(0)) Then
If pnt1(1) > pnt2(1) Then
basepnt = pnt1: pnt1 = pnt2: pnt2 = basepnt
End If
If pnt1(1) > pnt3(1) Then
basepnt = pnt1: pnt1 = pnt3: pnt3 = basepnt
End If
If pnt1(1) > pnt4(1) Then
basepnt = pnt1: pnt1 = pnt4: pnt4 = basepnt
End If
If pnt4(1) < pnt2(1) Then
basepnt = pnt4: pnt4 = pnt2: pnt2 = basepnt
End If
If pnt4(1) < pnt3(1) Then
basepnt = pnt4: pnt4 = pnt3: pnt3 = basepnt
End If
GoTo unite '合并
Else
ActiveDocument.Utility.Prompt "线段一与线段二不在同一直线上,无法合并."
End If
Else '不垂直
If pnt1(0) > pnt2(0) Then
End If
If pnt1(0) > pnt3(0) Then
End If
If pnt1(0) > pnt4(0) Then
End If
If pnt4(0) < pnt2(0) Then
End If
If pnt4(0) < pnt3(0) Then
End If
If (Abs((pnt3(1) - pnt1(1)) * (pnt2(0) - pnt1(0)) - (pnt3(0) - pnt1(0)) * (pnt2(1) - pnt1(1))) + Abs((pnt4(1) - pnt1(1)) * (pnt2(0) - pnt1(0)) - (pnt4(0) - pnt1(0)) * (pnt2(1) - pnt1(1)))) < 0.000001 Then
GoTo unite '合并
Else
End If
End If
End
unite:
Select Case line1.ObjectName
Case "AcDbLine"
line1.StartPoint = pnt1: line1.EndPoint = pnt4
line2.Delete
ActiveDocument.Utility.Prompt "线段一与线段二已合并."
Case "AcDbPolyline" Do While UBound(line1.Coordinates) > 4 '新增
pnt2 = line1.Coordinates
For i = 1 To (UBound(pnt2) - 2)
ReDim basepnt(0 To (UBound(pnt2) - 2))
basepnt(i) = pnt2(i)
Next i
line1.Coordinates = basepnt
Loop '新增
ReDim basepnt(0 To 3)
basepnt(0) = pnt1(0): basepnt(1) = pnt1(1)
basepnt(2) = pnt4(0): basepnt(3) = pnt4(1)
line2.Delete
Case Else
End Select
End Sub
发表于 2016-10-19 16:33:39 | 显示全部楼层
楼主的程序真是太好了,正需要的啊。
发表于 2020-8-5 17:58:34 | 显示全部楼层
谢谢众位坛友代码分享!
 楼主| 发表于 2004-2-12 19:18:00 | 显示全部楼层
本程序可以合并同一直线上的两根线段,可以使line和polyline, 合并后的线段属性同第一根线段.
还可以跟完善一些,比如选择线段是可以通过框选等.哪位高手能否提供框选方法,不胜感激!
发表于 2004-2-12 19:54:00 | 显示全部楼层
好程序!
先谢!
发表于 2004-2-13 12:55:00 | 显示全部楼层
好像不用写这么长吧?
 楼主| 发表于 2004-2-13 19:27:00 | 显示全部楼层
少是可以少几行,但我认为没什么意义.我选取的可以是line也可以是polyline,如果高手有更好的算法请赐教,谢谢.
发表于 2004-2-13 19:55:00 | 显示全部楼层
choose1和choose2可以写成一个单独的函数,因为内容是一样的。如以下函数,除可取得图元外,同样把图元的两个端点均取得,而且端点已经进行了排序,这样可以更方便,也更清晰。
  1.   Function GetLine(PromptTxt As String, ByRef Point1 As Variant, ByRef Point2 As Variant) As AcadEntity
  2.      Dim ent As AcadEntity
  3.        Dim pnt As Variant
  4.        Dim p1(2) As Double
  5.        Dim p2(2) As Double
  6.        On Error Resume Next
  7.        ThisDrawing.Utility.GetEntity ent, pnt, PromptTxt
  8.        Do
  9.                Select Case ent.ObjectName
  10.                        Case "AcDbLine"
  11.                                Set GetLine = ent
  12.                                Point1 = ent.StartPoint
  13.                                Point2 = ent.EndPoint
  14.                                If ThisDrawing.Utility.AngleFromXAxis(Point1, Point2) >= PI Then
  15.                                        Point1 = ent.EndPoint
  16.                                        Point2 = ent.StartPoint
  17.                                End If
  18.                                Exit Do
  19.                        Case "AcDbPolyline"
  20.                                If UBound(ent.Coordinates) = 3 Then
  21.                                        p1(0) = ent.Coordinates(0): p1(1) = ent.Coordinates(1)
  22.                                        p2(0) = ent.Coordinates(2): p2(1) = ent.Coordinates(3)
  23.                                        If ThisDrawing.Utility.AngleFromXAxis(p1, p2) >= PI Then
  24.                                                p2(0) = ent.Coordinates(0): p2(1) = ent.Coordinates(1)
  25.                                                p1(0) = ent.Coordinates(2): p1(1) = ent.Coordinates(3)
  26.                                        End If
  27.                                        Set GetLine = ent
  28.                                        Point1 = p1: Point2 = p2
  29.                                        Exit Do
  30.                                End If
  31.                End Select
  32.                ThisDrawing.Utility.Prompt vbCr & "所选对象不符合要求,请重新"
  33.        Loop
  34. End Function
  35. Public Function PI() As Double
  36.    PI = Atn(1) * 4
  37. End Function
另外,为什么要判断是否垂直,其它对于线来说,如第1条线是P1和P2点,第2条线是P3和P4点,这样如果第1线与第2线的角度是一样,而且第1线的角度与P1P3点的角度一样的话,则可判断两条线是在同一线上。
这样的话,就剩下4个点的排序了,因为两组点已经排好序,所以也就简单。
 楼主| 发表于 2004-2-13 20:29:00 | 显示全部楼层
判断垂直是为了按y值排序,否则按x值排序,总之p1,p4分别为最外侧的两个点.
如果四个点分别为p1(1,0),p2(2,0),p3(3,0),p4(3,1),那么p1p2角度等于p1p3角度,但是他们不在同一直线上.
对于polyline,可能不只两个端点,多端点的情况也要考虑.
choose1和choose2是可以合并,但要另外写一个函数,我不想这么做,整个功能写在一个sub内,看起来方便.
发表于 2004-2-14 10:53:00 | 显示全部楼层
好像对pl只是支持仅有两个端点的pl,未免有些遗憾。
 楼主| 发表于 2004-2-14 18:58:00 | 显示全部楼层
不是呀,只要是同一直线上的pl,多少端点都可以,你可以试试嘛.
发表于 2004-2-15 05:43:00 | 显示全部楼层
我测试的时候是不行的,当pl有多个交点的时候
GMT+8, 2025-5-24 19:36 , Processed in 0.213103 second(s), 25 queries , Gzip On.
