楼主: ljcgq
怎样将柱体表面的闭和曲线按照柱坐标的角度等分成小段?
 楼主| 发表于 2004-2-23 20:46:00 | 显示全部楼层
命令: _appload 已成功加载 TT.lsp。
命令:
命令:
命令: 指定对角点:
命令: tt 選閉合曲線: ; 错误: no function definition: VLAX-ENAME->VLA-OBJECT
发表于 2004-2-23 21:04:00 | 显示全部楼层
要加载(vl-load-com)以支持VLISP扩展函数
 楼主| 发表于 2004-3-6 18:54:00 | 显示全部楼层
谢谢meflying 龙龙仔,我运行了,但是返回的好象不是柱坐标
 楼主| 发表于 2004-3-6 18:57:00 | 显示全部楼层
meflying 龙龙仔 --不好意思,我对vl很生,能把你的程序思路给我解释一下么?
发表于 2004-5-20 09:10:00 | 显示全部楼层
;;只列出點表
;;展開的計算就交給你(LJCGQ)
指令: TTT
選閉合曲線:
中心點:
半徑: 50
等分角度: 1
(defun C:TTT
(/ HOLDOSMODE HOLDECHO PT PT1 PT2 OBJ CPT RAD ANG PT_LIST N AA)
(setq OBJ (vlax-ename->vla-object (car (entsel "\n選閉合曲線: "))))
(setq CPT (trans (getpoint "\n中心點: ") 1 0))
(setq RAD (getdist "\n半徑: ")
N 0
(while (progn
(initget 7)
(setq ANG (getreal "\n等分角度: "))
(/= 0 (rem 360 ANG))
(setq HOLDECHO (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "_.ucs" "")
(setq HOLDOSMODE (getvar "osmode"))
(setvar "osmode" 0)
(setq SS (ssadd))
(while (> 360 (* N ANG))
(setq PT1 (polar CPT (/ (* (* N ANG) pi) 180) RAD))
(setq PT2 (list (car PT1) (cadr PT1) 1))
(command "_.line" PT1 PT2 "")
(ssadd (entlast) SS)
(setq PT (vlax-safearray->list
(vlax-variant-value
(vla-intersectwith
OBJ
(vlax-ename->vla-object (entlast))
acextendotherentity
(setq PT_LIST (cons PT PT_LIST))
(setq N (1+ N))
(command "_.erase" SS "")
;;測試
(setq AA (reverse PT_LIST))
(command "3dpoly" (nth 0 AA))
(apply 'command (cdr AA))
(command "c")
(command "_.ucs" "p")
(setvar "osmode" HOLDOSMODE)
(setvar "cmdecho" HOLDECHO)
 楼主| 发表于 2004-5-20 21:59:00 | 显示全部楼层
谢谢斑竹,我回去完善。
GMT+8, 2025-11-11 07:57 , Processed in 0.164746 second(s), 19 queries , Gzip On.
