楼主: 3stone
[单线变双线,并保留原线]
发表于 2012-7-30 10:46:11 | 显示全部楼层
怎么才能偏移到当前图层呢?
发表于 2012-9-6 11:58:51 | 显示全部楼层
支持、是很方便,
发表于 2014-6-4 10:56:11 | 显示全部楼层
将原线换到另外一个定义好的图层,让原线变成虚线(command “change”。。。)
发表于 2014-9-20 10:41:36 | 显示全部楼层
(defun c:x2 (/ ss vss dist)
    (vl-load-com)
   (princ "\n单线变双v.1.1-------by 无痕.2004.2\n选择要变双的曲线:")
   (setq ss (ssget  '((0 . "Arc,Circle,Ellipse,Line,LwPolyline,Polyline,Spline,XLine")) )
  vss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
         dist (getdist "\n输入偏移距离:"))
   (vlax-for obj vss (vla-offset obj dist)(vla-offset obj (- 0 dist))(vla-erase obj));删除原线
这个未删除原线,求教
GMT+8, 2025-7-18 11:32 , Processed in 0.171487 second(s), 20 queries , Gzip On.
