查看: 5441|回复: 12
[求助]请帮忙编这个程序
发表于 2004-1-30 17:27:00 | 显示全部楼层 |阅读模式
在原有图的两条样条曲线上,先选择①,后选择②,最终形成③形状的“示坡线”,如有哪位大虾帮忙,我将感激不尽!!
发表于 2004-1-30 18:33:00 | 显示全部楼层
  1. ;函数:GetInterPOint
  2. ;功能:返回两个对象的所有交点
  3. ;参数:  ent1、ent2  均为ename对象
  4. (vl-load-com)
  5. (defun GetInterPoint (ent1 ent2 / ax_ent_1 ax_ent_2 intpoints points i)
  6.    (setq ax_ent_1 (vlax-ename->vla-object ent1)
  7.                ax_ent_2 (vlax-ename->vla-object ent2)
  8.    )
  9.    (setq intpoints (vla-intersectwith ax_ent_1 ax_ent_2 acextendnone))
  10.    (setq intpoints (vlax-variant-value intpoints))
  11.    (setq i 0)
  12.    (if (> (vlax-safearray-get-u-bound intpoints 1) 0)
  13.        (repeat (/ (+ 1
  14.                            (- (vlax-safearray-get-u-bound intpoints 1)
  15.                                  (vlax-safearray-get-l-bound intpoints 1)
  16.                            )
  17.                      )
  18.                      3
  19.                )
  20.            (setq points (append points (list (list
  21.                (vlax-safearray-get-element intpoints i)
  22.                (vlax-safearray-get-element intpoints (+ i 1))
  23.                (vlax-safearray-get-element intpoints (+ i 2))
  24.            )))
  25.            )
  26.            (setq i (+ 3 i))
  27.        )
  28.    )
  29.    points
  30. )(defun err(msg)
  31.    (princ msg)
  32.    (setvar "osmode" os)
  33.    (setvar "cmdecho" cmd)
  34.    (setq *error* errtmp)
  35.    (command "_.undo" "e")
  36.    (princ)
  37. )(defun c:test( / ent1 ent2 entv1 entv2 pts param11 param12 param21 param22 param1 param2 i n2 pt1 pt2)
  38.    (setq os (getvar "osmode"))
  39.    (setq cmd (getvar "cmdecho"))
  40.    (command "_.undo" "be")
  41.    (setvar "osmode" 0)
  42.    (setvar "cmdecho" 0)
  43.    (setq errtmp *error*)
  44.    (setq *error* err)
  45.    (setq ent1 (car (entsel "\nSelect the first line...")))
  46.    (setq ent2 (car (entsel "\nSelect the second line...")))
  47.    (if (not n)
  48.        (setq n (getint "\n输入密度:"))
  49.        (progn (setq n2 (getint (strcat "\n输入密度<" (itoa n) ">:")))
  50.            (if n2
  51.   (setq n n2)
  52.            )
  53.        )
  54.    )
  55.    (setq pts (GetInterpoint ent1 ent2))
  56.    (setq entv1 (vlax-ename->vla-object ent1))
  57.    (setq entv2 (vlax-ename->vla-object ent2))
  58.    (setq param11 (vlax-curve-getParamAtPoint entv1 (car pts)))
  59.    (setq param12 (vlax-curve-getParamAtPoint entv1 (cadr pts)))
  60.    (setq param21 (vlax-curve-getParamAtPoint entv2 (car pts)))
  61.    (setq param22 (vlax-curve-getParamAtPoint entv2 (cadr pts)))
  62.    (setq i 1)
  63.    (setq param1 (/ (- param12 param11) n))
  64.    (setq param2 (/ (- param22 param21) n))
  65.    (repeat (1- n)
  66.        (setq pt1 (vlax-curve-getPointAtParam ent1 (+ param11 (* param1 i))))
  67.        (setq pt2 (vlax-curve-getPointAtParam ent2 (+ param21 (* param2 i))))
  68.        (if (= (* (/ i 2) 2) i)
  69.            (setq pt2 (list (/ (+ (car pt1) (car pt2)) 2.0)
  70.                (/ (+ (cadr pt1) (cadr pt2)) 2.0)
  71.                (/ (+ (last pt1) (last pt2)) 2.0)
  72.                ))
  73.        )
  74.        (command "_.line" pt1 pt2 "")
  75.        (setq i (1+ i))
  76.    )
  77.    (setvar "osmode" os)
  78.    (setvar "cmdecho" cmd)
  79.    (setq *error* errtmp)
  80.    (command "_.undo" "e")
  81.    (princ)
  82. )
 楼主| 发表于 2004-1-30 18:59:00 | 显示全部楼层
非常感谢,我真没想到这么快就给了回复。我真心祝愿“明经CAD社区”越办越红火,同时我要把这个好网站介绍给我的亲朋好友。
 楼主| 发表于 2004-1-30 19:24:00 | 显示全部楼层
程序很好用,如果能定出短线与长线之间的间距能固定一个参数(如:2.0mm),然后程序自动进行画线,而无需输入密度。
                                                 __|__|__         就是“|”之间的间距固定一个参数
发表于 2004-1-30 20:15:00 | 显示全部楼层
(if (not n)
(if n2
(setq n n2)
将以上部分去掉,改为: (setq n 10) 其中,10可以改为适当数字,你可以多改几次以调整。 这种方法是根据两点间的程度进行等分,间距(其实也不能算间距,因为不平行),根据图形大小不同,间距会不同
 楼主| 发表于 2004-1-30 21:30:00 | 显示全部楼层
短线能否垂直于①,这样看起来比较美观。
发表于 2004-1-31 12:49:00 | 显示全部楼层
垂直于1,但在1上不均匀。可以做到在1上均匀,但垂直于2,如果垂直于1又1上均匀,将比较复杂。看是否可以就这样。。。
  2. ;功能:返回两个对象的所有交点
  4. (vl-load-com)
  8.    )
  11.    (setq i 0)
  13.        (repeat (/ (+ 1
  16.                            )
  17.                      )
  18.                      3
  19.                )
  24.            )))
  25.            )
  27.        )
  28.    )
  29.    points
  31.    (princ msg)
  36.    (princ)
  37. )(defun c:test( / ent1 ent2 pts param11 param12 param1 i pt1 pt2)
  47.    (setq n 10)
  48.    (setq pts (GetInterpoint ent1 ent2))
  49.    (setq param11 (vlax-curve-getParamAtPoint ent2 (car pts)))
  50.    (setq param12 (vlax-curve-getParamAtPoint ent2 (cadr pts)))
  51.    (setq i 1)
  52.    (setq param1 (/ (- param12 param11) n))
  53.    (repeat (1- n)
  54.        (setq pt2 (vlax-curve-getPointAtParam ent2 (+ param11 (* param1 i))))
  55.        (setq pt1 (vlax-curve-getClosestPointTo ent1 pt2))
  56.        (if (= (* (/ i 2) 2) i)
  57.            (setq pt2 (list (/ (+ (car pt1) (car pt2)) 2.0)
  58.                (/ (+ (cadr pt1) (cadr pt2)) 2.0)
  59.                (/ (+ (last pt1) (last pt2)) 2.0)
  60.                ))
  61.        )
  62.        (command "_.line" pt1 pt2 "")
  63.        (setq i (1+ i))
  64.    )
  65.    (setvar "osmode" os)
  66.    (setvar "cmdecho" cmd)
  67.    (setq *error* errtmp)
  68.    (command "_.undo" "e")
  69.    (princ)
  70. )
参与人数 1金钱 +10 收起 理由
004 + 10
发表于 2004-2-1 02:06:00 | 显示全部楼层
http://www.xdcad.com/forum/showthread.php?postid=752371#post752371
参与人数 1金钱 +10 收起 理由
004 + 10
发表于 2004-2-1 02:10:00 | 显示全部楼层
楼上的怎么看不见啊?
发表于 2004-2-1 02:15:00 | 显示全部楼层
这是测绘用的吧!
自然斜坡的!
最好能按第二条线等分、法线!
GMT+8, 2025-5-25 03:10 , Processed in 0.205523 second(s), 33 queries , Gzip On.
