楼主: sunredday
如何将几条线段焊接成一个整体
发表于 2004-1-26 13:52:00 | 显示全部楼层
(defun C:vvv (/ s1 n1 n e1 e2 z k a)
(vl-load-com)
(princ
"\n½«ËùѡʵÌåÁ¬³É¶àÒåÏߣ¬²¢ÅÐ¶ÏÆäÊÇ·ñ±ÕºÏ. °æÈ¨ËùÓУºTH.ÑÔÎ÷Ôç¶þ"
(setq z (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "undo" "be")
(setq s1 (ssget))
(setq n1 (sslength s1))
(setq n 0)
(while (< n n1)
(setq e1 (ssname s1 n))
(setq e2 (entget e1))
(if (/= nil e2)
(setq a (cdr (assoc 0 e2)))
(if (= a "LINE")
(progn (command "pedit" e1 "y" "j" "all" "" "")
(setq k (entlast)) (if (/= (vlax-curve-isClosed k) t) (command "change" k "" "p" "c" 7 "")
(command "change" k "" "p" "c" 30 "")
(if (= a "arc")
) (setq n (1+ n))
(setvar "cmdecho" z)
(command "undo" "e")
(prin1)
发表于 2004-1-26 14:23:00 | 显示全部楼层
直接在命令行里输入不行吗?
发表于 2004-1-26 14:25:00 | 显示全部楼层
直接在命令行里输入就行了。
发表于 2004-1-30 16:13:00 | 显示全部楼层
各位大虾我很,还是没有懂,我用的是CAD2002,能不能再说得仔细一点,在这里先感谢了,
GMT+8, 2025-5-19 13:04 , Processed in 0.163842 second(s), 18 queries , Gzip On.
