查看: 2463|回复: 1
如何累计计算线段的长度?
发表于 2004-1-11 19:15:00 | 显示全部楼层 |阅读模式
发表于 2012-6-20 15:16:01 | 显示全部楼层
;;;程序名:zz.LSP
;;;功  能:计算线段和多义线的长度
(princ "\n程序:统计线段长度 命令:zz")
(defun C:zz (/ CURVE TLEN SS N SUMLEN)
(vl-load-com)
(setq SUMLEN 0)
(setq SS (ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
(setq N 0)
(repeat (sslength SS)
(setq CURVE (vlax-ename->vla-object (ssname SS N)))
(setq TLEN (vlax-curve-getdistatparam CURVE (vlax-curve-getendparam CURVE)))
(setq SUMLEN (+ SUMLEN TLEN))
(setq N (1+ N))
(princ (strcat "\n共选择 " (itoa (sslength SS)) " 条线段,线段总长:" (rtos SUMLEN 2 0) "毫米。"))
GMT+8, 2025-5-1 12:31 , Processed in 0.170831 second(s), 24 queries , Gzip On.
