楼主: 钾肥
自己编写的一个LISP有问题!哪位帮忙解决一下
发表于 2004-1-4 19:36:00 | 显示全部楼层
具体用途不清楚,所以不好判断
但你的程序倒不是坐标系的问题,而是两条平行线只要不是水平或垂直就会有问题
你少点取了一个参数(平行线的角度)
 楼主| 发表于 2004-1-4 21:39:00 | 显示全部楼层
这个程序主要是用来画风管或线槽等物体的断口的!
不知道这么取!
你知道吗?
发表于 2004-1-9 08:50:00 | 显示全部楼层
看看这样是否可行
  1. (defun err(msg)
  2.   (princ msg)
  3.   (setvar "osmode" os)
  4.   (setvar "cmdecho" cmd)
  5.   (setq *error* errtmp)
  6.   (princ)
  7. )
  8. (defun c:test( / pt1 pt2 pt3 ptCenter)
  9.   (setq os (getvar "osmode"))
  10.   (setq cmd (getvar "cmdecho"))
  11.   (setq errtmp *error*)
  12.   (setq *error* err)
  13.   (setq pt1 (getpoint "\n输入第一点:"))
  14.   (setq pt2 (getpoint "\n输入第二点:"))
  15.   (setvar "osmode" 0)
  16.   (setvar "cmdecho" 0)
  17.   (setq pt1 (trans pt1 1 0))
  18.   (setq pt2 (trans pt2 1 0))
  19.   (command "_.ucs" "")
  20.   (setq ptCenter (list (/ (+ (car pt1) (car pt2)) 2)
  21.                        (/ (+ (cadr pt1) (cadr pt2)) 2)
  22.                        0.0))
  23.   (setq ang (angle pt1 pt2))
  24.   (if (> ang pi)
  25.     (setq ang (- ang pi))
  26.   )
  27.   (cond
  28.     ((equal (/ pi 2) ang 0.00001) (setq pt3 nil))
  29.     (t (setq pt3 (polar ptCenter (- ang) (/ (distance pt1 pt2) 2))))
  30.   )
  31.   (command "_.line" pt1 pt2 "")
  32.   (if pt3
  33.     (command "_.line" ptCenter pt3 "")
  34.   )
  35.   (command "_.ucs" "p")
  36.   (setvar "osmode" os)
  37.   (setvar "cmdecho" cmd)
  38.   (setq *error* errtmp)
  39.   (princ)
  40. )
GMT+8, 2025-8-21 07:16 , Processed in 0.157865 second(s), 19 queries , Gzip On.
